Todays Cost of getting a PPL
Old November 6th 06, 04:54 AM posted to rec.aviation.piloting
Crash Lander[_1_]
Default Todays Cost of getting a PPL
"gpsman" wrote in message
Kyle Boatright wrote:
When you have 5 hours you haven't yet had the opportunity to have
learned the subtle points, nor develop much "touch" to lose.
The less you know and the less experience you have the less skills seem
to be necessary and the easier everything seems to be... since you
haven't yet broken the surface of knowledge or skill.
Point taken, but not entirely agreed with. The fact remains that a pilot who
is at the circuits part of the training, regardless of how many hours he's
taken to get there, has sufficient "touch" to be able to control the
aircraft with minimal to no input from an instructor. True, the instructor
must be with the student at all times, but the idea is for the student to
actually 'fly' the aircraft, with the instructor leaving the controls alone
unless necessary to avoid an incident. The fact I'm not solo yet doesn't
mean I can't fly. I can fly, well enough for circuits at least, just perhaps
not well enough to get myself out of trouble should anything untoward
happen, hence the requirement for the instructor to be with me. Surely if a
student can get an aircraft off the ground, around a full circuit, and back
on the ground again in one piece, without the instructor touching the
controls, he has enough "touch" to lose!
Oz/Crash Lander
Old November 6th 06, 05:52 AM posted to rec.aviation.piloting
Dudley Henriques
"Crash Lander" wrote in message
who is at the circuits part of the training, regardless of how many hours
he's taken to get there, has sufficient "touch" to be able to control the
alone unless necessary to avoid an incident. The fact I'm not solo yet
doesn't mean I can't fly. I can fly, well enough for circuits at least,
just perhaps not well enough to get myself out of trouble should anything
untoward happen, hence the requirement for the instructor to be with me.
Surely if a student can get an aircraft off the ground, around a full
circuit, and back on the ground again in one piece, without the instructor
touching the controls, he has enough "touch" to lose!
Oz/Crash Lander
You are absolutely right about this CL. A good instructor will only fly the
airplane long enough to demonstrate something to the student then give the
airplane right back to the student. For all intent and purposes, the student
should be the one actually on the controls from startup to shutdown.
By the time you get into the pattern you should have a good foundation of
the basics and all the pattern should be is an extension of those basics
flown to tighter and closer tolerances.
A good instructor knows exactly how far to let the student fly into an
error. The exceptional instructor starts talking the student into correcting
any error on their own, without physical intervention by the instructor.
There are of course times when an instructor has to correct physically, but
this should be viewed as the exception; not the rule!
Dudley Henriques
Old November 7th 06, 04:57 AM posted to rec.aviation.piloting
gpsman
Crash Lander wrote: brevity snip
Sure, no argument there. But the fact remains that the masters of
every fine skill feel the edge come off their technique after 24-48
hours. They notice that, the novice doesn't, since he hasn't yet
attained that edge.
That's why Yo-Yo Ma and his ilk still practice between gigs and can
coax better performance from inferior instruments.
You may not need his level of skill to fly, but you'd probably be best
off working toward it.
To me, flying is all about practicing precision and attention to
detail. If you can meet a master aerial agricultural sprayer ask him
to show you a GPS record of his spray patterns.
- gpsman
Naval Air Refueling Needs Deferred in Air Force Tanker Plan Henry J Cobb Military Aviation 47 May 22nd 04 03:36 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
