![]() wrote in message ... On 6-Nov-2006, "Jim Macklin" wrote: I would expect that the maximum speed was 4,000-6,000 mph. You'd be wrong. Mary Shafer, formally NASA's SR-71 Flying Qualities Lead Engineer at Dryden Flight Research Center, Edwards, CA, posted a reply to "Yeff" back on February 23, 1999 on rec.aviation.military: "Yeff" wrote: The story I always heard was that if any plane ever beat the Blackbirds speed record we'd just take a bird up and move the throttles forward a bit more and take it back. Sooth or myth? Has an SR-71 ever flown at max speed? (hoping against hope that Mary imparts more wisdom...) Yes. But it required permission of the Commander on a per-flight basis. The SR-71's usual limit is Mach 3.2, but flight at Mach 3.3 was allowed, and flown, with prior permission. There's no evidence that anyone has ever flown faster than Mach 3.3 (although it's possible that someone may have briefly dashed above 3.3, not cruised, but it's not documented). The cruise speed on the SR-71 is limited by CIT, compressor inlet temperature. The limit is 427 degC, per the Dash-1. Since the SR-71 is designed to fly Mach 3.2 (standard atmosphere), this temperature is reached at Mach 3.3, offering a fairly standard margin of safety. If operational conditions require going Mach 3.3 it's possible. Rather than flying Mach number, we fly CIT, cruising just a bit below the limit. This usually works out to Mach 3.23 but that's because the real atmosphere isn't the same as the standard atmosphere. Everything about the airplane is designed for Mach 3.2, including the inlet spike operation, etc. I've always assumed that the extra 0.1 Mach was a bonus, discovered in flight test, because the calculations were on the conservative side. If you'll check in Deja News, you'll find that Lednicer worked it out that the absolute airframe maximum is around Mach 3.5, because you get the bow shock impinging on the wing above that. Unfortunately, this can't be tested because the CIT limit is reached first. -- Mary Shafer NASA Dryden Flight Research Center, Edwards, CA SR-71 Flying Qualities Lead Engineer Of course I don't speak for NASA What a cool plane. I seen one in person at the Dayton Air Museum, it was smaller than I thought. But they had the Valkyrie there to and that thing is HUGE! --------------------------------------------------- DW |
Darkwing wrote:
cool plane. I seen one in person at the Dayton Air Museum, it was smaller than I thought. But they had the Valkyrie there to and that thing is HUGE! When the Smithsonian had there's in it's own temporary hangar it looked small. Now that I've had to walk around that thing a gazillion times it seems a lot larger. |
Ron Natalie wrote
When the Smithsonian had there's in it's own temporary hangar it looked small. RON!! I don't believe it! "their's".....:-) Bob Moore |
Bob Moore wrote:
Ron Natalie wrote When the Smithsonian had there's in it's own temporary hangar it looked small. RON!! I don't believe it! "their's".....:-) I hate spelling flames, but I guess I can handle an apostrophe flame. It's "theirs" and "its", as in "had theirs in its own temporary hangar". .... Alan -- Alan Gerber PP-ASEL gerber AT panix DOT com |
Alan Gerber wrote
It's "theirs" and "its", as in "had theirs in its own temporary hangar". Whoops! Bob |
Bob Moore wrote:
Whoops! Bob whoops or oops? I can never get totally comfortable with this language ![]() Ramapriya |
Alan Gerber wrote:
Bob Moore wrote: Ron Natalie wrote When the Smithsonian had there's in it's own temporary hangar it looked small. RON!! I don't believe it! "their's".....:-) I hate spelling flames, but I guess I can handle an apostrophe flame. It's "theirs" and "its", as in "had theirs in its own temporary hangar". Had "its" in "its" hangar. The Smithsonian is considered a singular entity. I spent too many years with Strunk & White's "Elements of Style". *sigh* |
Blanche wrote: The Smithsonian is considered a singular entity. Unless you're British :-) |
Then you would know that periods always go inside quotation marks. :-)
Blanche wrote: I spent too many years with Strunk & White's "Elements of Style". *sigh* |
Trivia: This is why periods always go inside the quotation marks (helps me
remember): In the old days of mechanical printing presses and manual typesetting, the letter pieces looked similar to the strikers on old typewriters; rectangular pieces of metal. A period piece [.] was only half as wide as a double-quote [' '] and if it was at the end of a line, which is common at the end of quotes or paragraphs, the half-width, full-heighth period piece could lean just a little and eventually wiggle lose. As the inking/printing mechanism moved over the wayward period, the piece could snap off and monkey up the works. To compensate for this, printing press operators and typesetters ignored the editors made a command decision: They started tucking the [.] inside the square [' '] piece in order to secure it and hold it still. According to an old typesetter at the Oregon State printing press, that's why the period goes inside the quote as such: [.][' '] (end of line) -c "RomeoMike" wrote in message ... Then you would know that periods always go inside quotation marks. :-) I spent too many years with Strunk & White's "Elements of Style". *sigh* |
