I've considered the hand impact driver as I actually own one, but I'm
tentative due to the aluminum case. Any positive/negative experiences? Jim "David Lesher" wrote in message ... "Jim Burns" writes: The plug only sticks out 1 thread. It's been painted over, and from scraping the paint off, it looks like pipe dope in the thread. I haven't tried valve grinding compound yet, maybe a combination of heat and compound with a new oxide hex key with a ratchet will work. Motorcycle people have many of the those plugs to deal with & swear by the hand-impact drivers; you preload them with a twist and hit it with a hammer. The hammer keeps the key deeply seated. Buy a 1/2" square drive key from Snap-on or such. I concur with the preheating but also suggest getting some Kroil Oil from Kano labs. It makes Liquid Wrench look like mouse milk. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
![]() On Nov 6, 12:33 pm, "Jim Burns" wrote: I've considered the hand impact driver as I actually own one, but I'm tentative due to the aluminum case. Any positive/negative experiences? The impact driver isn't going to hurt the case but the lack of control from a swinging hammer just might cause you to strip out the hex in a situation where a wrench handle in knowledgeable hands, wouldn't. What is the hex key size? 3/16 inch? NRP |
....or damage the ring gear which is just ahead of the plug ;( I didn't have
it with me last night, so I really don't know if I can get "straight on" the plug to use the impact driver. Yep, it's 3/16". Jim "nrp" wrote in message oups.com... On Nov 6, 12:33 pm, "Jim Burns" wrote: I've considered the hand impact driver as I actually own one, but I'm tentative due to the aluminum case. Any positive/negative experiences? The impact driver isn't going to hurt the case but the lack of control from a swinging hammer just might cause you to strip out the hex in a situation where a wrench handle in knowledgeable hands, wouldn't. What is the hex key size? 3/16 inch? NRP |
If the 3/16 hex key looks or feels like it is slipping, you might try a
carefully filed-down 5 millimeter hex key driven in. Sandblast the filed surfaces for a better grip. You should be able to get that plug out. Any overhauler has to, to clean the oil galleries. I'm out of ideas now..........! |
![]() Lycomings have the temp probe in the oil screen or oil filter adapter, at the back of the engine. I've never seen one in the front of the case, perhaps since Lycoming specifies max oil temp entering the engine, not halfway through it. Are you sure you need to remove that plug? Dan |
It's a JPI probe install, secondary to the factory oil temp.
Jim wrote in message oups.com... Lycomings have the temp probe in the oil screen or oil filter adapter, at the back of the engine. I've never seen one in the front of the case, perhaps since Lycoming specifies max oil temp entering the engine, not halfway through it. Are you sure you need to remove that plug? Dan |
"Jim Burns" wrote in message
... I've considered the hand impact driver as I actually own one, but I'm tentative due to the aluminum case. Any positive/negative experiences? Jim I've pounded on a lot of aluminium cases on motorcycles... What you DON'T want to do is twist the handle very far (1/8 turn max). And you would want to start out moderately and kinda build up with the hammer blows - don't start with a 5 pound sledge, eh? -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Fouled plug IO 470 | [email protected] | General Aviation | 7 | January 29th 06 06:03 PM |
Plug fouled | Denny | Owning | 9 | September 2nd 05 05:58 AM |
Plug replacements for O-360-A3A | [email protected] | Owning | 3 | August 20th 05 10:39 PM |
ICOM Headset Adaptor Plug | Ron Wanttaja | Home Built | 3 | June 2nd 05 07:54 AM |
Helicopter headset plug - help needed | NewsGroups | Home Built | 4 | September 8th 04 05:21 PM |
