Thanks. If nothing else, we'll create an archive of what doesn't work!
![]() Jim "nrp" wrote in message ups.com... If you end up having to drill it out (ugh!), pressurize the galley from somewhere else with shop air so that any chips get blown back to you. I'm not a fan of EZ-outs for something that is extra tight, as you may end up distorting the threads in the case. Penetratiung lubes etc won't penetrate the threads if there is pipe dope in them. Instead the lube will probably get on the wrenching surfaces & make a stripout that much more likely. My read at least...... Still - good luck! nrp |
Fouled plug IO 470 | [email protected] | General Aviation | 7 | January 29th 06 06:03 PM |
Plug fouled | Denny | Owning | 9 | September 2nd 05 05:58 AM |
Plug replacements for O-360-A3A | [email protected] | Owning | 3 | August 20th 05 10:39 PM |
ICOM Headset Adaptor Plug | Ron Wanttaja | Home Built | 3 | June 2nd 05 07:54 AM |
Helicopter headset plug - help needed | NewsGroups | Home Built | 4 | September 8th 04 05:21 PM |
