Lancair Legacy
Old November 8th 06, 06:35 AM posted to rec.aviation.homebuilt
Roger (K8RI)
Default Lancair Legacy
On Wed, 08 Nov 2006 02:28:45 GMT, "Capt.Doug"
"Roger (K8RI)" wrote in message
BTW I see some environmental groups are pushing for the elimination of
lead in Avgas. Then I won't be able to use either engine.
Reset the timing and use different power settings. Some parts of the world
already don't have avgas (and no FAA to stifle experimenting).
With that high compression engine? You can't even get an STC for an
alternative fuel.
D.
www.rogerhalstead.com
Old November 8th 06, 02:26 PM posted to rec.aviation.homebuilt
jmk
alternative fuel.
Time to get GAMI back on the stick and get PRISM certified. Then your
engine would run on Jet-A okay. Trouble is, with their new contracts
with Cirrus, I'm afraid PRISM is small potatoes on the back burner.
Old November 9th 06, 02:58 AM posted to rec.aviation.homebuilt
Capt.Doug
alternative fuel.
Where STCs are not a consideration, high RPMs and less than full MAP can
allow the use of autogas. Performance may take a hit, and sometimes timing
must be retarded for the turbocharged engines, but it works. I ran autogas
in my first Aztec (NOT US registered!!!!!!) for years. The only difference
was that I had to turn on the boost pumps on above 7000' for vapor lock.
D.
Old November 9th 06, 09:41 AM posted to rec.aviation.homebuilt
Roger (K8RI)
On Thu, 09 Nov 2006 02:58:44 GMT, "Capt.Doug"
alternative fuel.
To me performance is paramount.
I'm building the G-III to go as fast as possible. Long haul and some
serious play.
I don't even run the Debonair under 75% except for maneuvers, a rough
ride, and landing. That engine IO-47N (260 HP) doesn't qualify for an
STC either. My goal is to get similar HP to the one shown in
KitPlanes this month.
D.
Old November 12th 06, 03:40 AM posted to rec.aviation.homebuilt
Capt.Doug
"Roger (K8RI)" wrote in message To me performance is paramount.
serious play.
What influenced your decision to go with the G-III as opposed to another
fast type like Lancair, Venture, or SX300?
D.
Old November 13th 06, 09:06 AM posted to rec.aviation.homebuilt
Roger (K8RI)
On Sun, 12 Nov 2006 03:40:45 GMT, "Capt.Doug"
serious play.
Wellll...When I started the G-III Lancair was relatively new, but I'd
still choose the G-III due to the aerobatic capability. It's a much
more rugged design, but I have to admit the IV, IV-P, and Legacy are
the prettiest go places airplanes built.
Venture was a great plane even if they did look a bit like a tadpole
but they weren't around long. The SX 300 is also a good traveling
plane, but as I recall the tail is a bit small. I'm even going with an
extended rudder and ventral fin for better low speed control and less
tail wag and high speed and altitude. (IF I ever get it done)
The G-III is heavy for its size and it is over engineered. I like
that. I never flew a Venture or an SX 300 but I liked the control
harmony and feel of the G-III the best. I also liked the response and
vertical penetration. I also liked the idea if I want down in a hurry
I can just roll inverted and pull. :-)) Depending on my location...
What I don't like about the older G-III kits is the amount of labor
involved. They take as much or more labor than some plans built
planes which probably makes it one of the most labor intensive kits on
the market. OTOH getting what they call a "jump start" kit which
removes a lot of hours also removes a lot of money from the budget.
D.
BWB has finished his Lancair Legacy... John Ammeter Home Built 1 June 6th 06 04:11 AM
A friend of mine is building a Legacy and has a question.... John Ammeter Home Built 14 April 23rd 06 11:17 PM
Date of effect now 1 October 2004 for revised IGC-approvals for certain legacy types of GNSS flight recorder Ian Strachan Soaring 0 March 15th 04 02:32 PM
Date of effect now 1 April 2004 for revised IGC-approval for certain legacy types of GNSS flight recorder Ian Strachan Soaring 56 December 2nd 03 08:08 AM
Lancair Legacy 2000 Randy L. Simulators 6 October 9th 03 09:56 PM
