"K l e i n" wrote in message
oups.com... Gary Drescher wrote: K l e i n wrote: I think the appropriate maneuver for this situation from the Commercial Pilot syllabus would be half of a lazy-8. Why not a simple steep turn? It's easy to pre-calculate the turn radius for a given airspeed, bank angle, and crosswind component. In this case, they had plenty of room if they'd planned and executed the turn properly. They tried and failed to perform a simple steep turn because they apparently did not precalculate the maneuver. Or they precalculated incorrectly, or they calculated correctly but executed it poorly. The PIC was a PP and presumably not yet schooled in the lazy-8, Has anyone established which of the pair was the PIC? The NTSB report said nothing about that. however the CFI obviously possessed a Commercial ticket and presumably was schooled in this maneuver. The lazy-8 is not an aerobatic maneuver and the Cirrus would have been capable of performing it. Sure, but beforehand there'd have been no reason to plan to do a half-lazy-8 rather than a steep turn; and by the time they knew their turn wasn't going to turn out well, it was probably too late to do anything else. p.s. I have performed lots of lazy-8's in aircraft ranging from gliders to Turbo Commanders. The maneuver is easy, beautiful and lots of fun. Yup. --Gary |
"K l e i n" wrote in message oups.com... Gary Drescher wrote: K l e i n wrote: I think the appropriate maneuver for this situation from the Commercial Pilot syllabus would be half of a lazy-8. Why not a simple steep turn? It's easy to pre-calculate the turn radius for a given airspeed, bank angle, and crosswind component. In this case, they had plenty of room if they'd planned and executed the turn properly. They tried and failed to perform a simple steep turn because they apparently did not precalculate the maneuver. Or they precalculated incorrectly, or they calculated correctly but executed it poorly. Sure, but beforehand there'd have been no reason to plan to do a half-lazy-8 rather than a steep turn; and by the time they knew their turn wasn't going to turn out well, it was probably too late to do anything else. I think that's exactly the point. Doing a half lazy 8 calls for a clearing turn under normal circumstances when flying out over the gridded landscape of Iowa. In the rotorcraft filled, obstruction strewn, distraction filled low ceiling environs of the East River, a half lazy 8 would require some forethought and a deep breath. A steep turn is what was needed and apparently not done. That part of the NYC VFR corridor should be for rotorcraft only - have they done that yet? |
Has anyone established which of the pair was the PIC? The NTSB report said nothing about that. There will most likely never be an answer to this question. -- Peter |
On Fri, 10 Nov 2006 12:51:04 -0500, "Peter R."
wrote in : Gary Drescher wrote: Has anyone established which of the pair was the PIC? The NTSB report said nothing about that. There will most likely never be an answer to this question. Hasn't the FAA ruled in the past, that the CFI or ATP is always culpable as PIC regardless? |
Lidle crash: who is wrong? | Blasto | Piloting | 57 | October 20th 06 08:05 AM |
VQ-1's P4M-1Q crash off China - 1956 | Mike | Naval Aviation | 0 | May 6th 06 11:13 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Four Winds 192 Crash into the Miami Federal Reserve Building, a year ago today | Billgran | Home Built | 3 | December 6th 03 03:22 PM |
