Jim Macklin schrieb:
they give altitude, accurate to within a few feet. just set the altimeter to read the same. NO, dont' do this. The whole aviation system (airspace, separation...) is based on pressure altitude, not geometric altitude. Stefan |
Well, kind of. Most, if not all altimeters now, compensate for pressure
variations to show geometric (if that's the right term for it) altitude. With SA disables in the GPS system, altitude is much more accurate than it was. How accurate, I don't know. When I compare my altimeter with my GPS's, they're usually about 100' apart. I'm not sure which is more accurate. mike "Stefan" wrote in message . .. Jim Macklin schrieb: they give altitude, accurate to within a few feet. just set the altimeter to read the same. NO, dont' do this. The whole aviation system (airspace, separation...) is based on pressure altitude, not geometric altitude. Stefan |
The question was IF no radio available to get a corrected
altimeter setting... if a GPS is available the GPS altitude is better than no correction at all. If I take-off in a airplane with no radio and fly through a cold front in VFR, the altimeter setting is likely to change enough to have a 500 foot or greater error with a 100 mile flight. A GPS can be used to get closer than that. Probably, most NORDO flights are at or below 3,000 AGL under VFR. Terrain clearance is more critical to such a flight based on the altimeter than is the mid-air collision problem since the "rule" only applies above 3,000 AGL. Someday, the rules may change, but within today's rules, using GPS "as the best available" or only source is better than no source at all. "mike regish" wrote in message . .. | Well, kind of. Most, if not all altimeters now, compensate for pressure | variations to show geometric (if that's the right term for it) altitude. | | With SA disables in the GPS system, altitude is much more accurate than it | was. How accurate, I don't know. When I compare my altimeter with my GPS's, | they're usually about 100' apart. I'm not sure which is more accurate. | | mike | | "Stefan" wrote in message | . .. | Jim Macklin schrieb: | they give altitude, accurate to within a few feet. just set the | altimeter to read the same. | | NO, dont' do this. The whole aviation system (airspace, separation...) is | based on pressure altitude, not geometric altitude. | | Stefan | | |
The question was IF no radio available to get a corrected altimeter setting... if a GPS is available the GPS altitude is better than no correction at all. Agreed. Probably, most NORDO flights are at or below 3,000 AGL under VFR. Terrain clearance is more critical to such a flight In such a flight you usually just look out of the window for terrain clearance. Stefan |
Agreed also, but if at night, the ground can be hard to see
if there is no moon or ground lights. The question is some what academic, even aircraft without radios often have a handheld and altimeter settings can be had from ATIS, etc. The point about GPS, it is accurate in relation to terrain. It is not good for IFR separation or ATC boundaries. "Stefan" wrote in message ... | Jim Macklin schrieb: | The question was IF no radio available to get a corrected | altimeter setting... if a GPS is available the GPS altitude | is better than no correction at all. | | Agreed. | | Probably, most NORDO flights are at or below 3,000 AGL under | VFR. Terrain clearance is more critical to such a flight | | In such a flight you usually just look out of the window for terrain | clearance. | | Stefan |
"Jim Macklin" writes:
The point about GPS, it is accurate in relation to terrain. It is dangerously inaccurate with respect to terrain. -- Transpose mxsmanic and gmail to reach me by e-mail. |
If I take-off in a airplane with no radio and fly through a cold front in VFR, the altimeter setting is likely to change enough to have a 500 foot or greater error with a 100 mile flight. A GPS can be used to get closer than that. Unfortunately, no, it cannot. Probably, most NORDO flights are at or below 3,000 AGL under VFR. Terrain clearance is more critical to such a flight based on the altimeter than is the mid-air collision problem since the "rule" only applies above 3,000 AGL. GPS altitudes are especially dangerous to use near the ground, becuase they are so inaccurate. Someday, the rules may change, but within today's rules, using GPS "as the best available" or only source is better than no source at all. True, if you are far from the ground and you cannot see the ground. Don't trust it to keep you clear of terrain at low altitudes. -- Transpose mxsmanic and gmail to reach me by e-mail. |
mike regish schrieb:
When I compare my altimeter with my GPS's, they're usually about 100' apart. I'm not sure which is more accurate. The point is not which one is more accurate. The point is that everybody uses the same frame of reference. Stefan |
My point is that they both are, basically, the same frame of
reference-height above sea level. mike "Stefan" wrote in message ... mike regish schrieb: When I compare my altimeter with my GPS's, they're usually about 100' apart. I'm not sure which is more accurate. The point is not which one is more accurate. The point is that everybody uses the same frame of reference. Stefan |
My point is that they both are, basically, the same frame of reference-height above sea level. Which is wrong. Stefan |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
(sorta OT) Free Ham Radio Course | RST Engineering | Piloting | 43 | January 24th 05 08:05 PM |
1944 Aerial War Comes to Life in Radio Play | Otis Willie | Military Aviation | 0 | March 25th 04 10:57 PM |
Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 03:30 AM |
