Setting altimeters with no radio
Old November 12th 06, 01:20 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
Default Setting altimeters with no radio
The question was IF no radio available to get a corrected
altimeter setting... if a GPS is available the GPS altitude
is better than no correction at all.
If I take-off in a airplane with no radio and fly through a
cold front in VFR, the altimeter setting is likely to change
enough to have a 500 foot or greater error with a 100 mile
flight. A GPS can be used to get closer than that.
Probably, most NORDO flights are at or below 3,000 AGL under
VFR. Terrain clearance is more critical to such a flight
based on the altimeter than is the mid-air collision problem
since the "rule" only applies above 3,000 AGL.
Someday, the rules may change, but within today's rules,
using GPS "as the best available" or only source is better
than no source at all.
"mike regish" wrote in message
| Well, kind of. Most, if not all altimeters now, compensate
for pressure
| variations to show geometric (if that's the right term for
it) altitude.
| With SA disables in the GPS system, altitude is much more
accurate than it
| was. How accurate, I don't know. When I compare my
altimeter with my GPS's,
| they're usually about 100' apart. I'm not sure which is
more accurate.
| mike
| "Stefan" wrote in message
| Jim Macklin schrieb:
| they give altitude, accurate to within a few feet.
just set the
| altimeter to read the same.
| NO, dont' do this. The whole aviation system (airspace,
separation...) is
| based on pressure altitude, not geometric altitude.
| Stefan
Old November 12th 06, 01:25 PM posted to rec.aviation.piloting,rec.aviation.student
Stefan
Agreed.
In such a flight you usually just look out of the window for terrain
clearance.
Stefan
Old November 12th 06, 01:38 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
Agreed also, but if at night, the ground can be hard to see
if there is no moon or ground lights. The question is some
what academic, even aircraft without radios often have a
handheld and altimeter settings can be had from ATIS, etc.
The point about GPS, it is accurate in relation to terrain.
It is not good for IFR separation or ATC boundaries.
corrected
altitude
| Agreed.
under
flight
for terrain
| clearance.
| Stefan
Old November 12th 06, 02:57 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
"Jim Macklin" writes:
It is dangerously inaccurate with respect to terrain.
Old November 12th 06, 02:56 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Unfortunately, no, it cannot.
GPS altitudes are especially dangerous to use near the ground, becuase
they are so inaccurate.
True, if you are far from the ground and you cannot see the ground.
Don't trust it to keep you clear of terrain at low altitudes.
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 05:39 PM
(sorta OT) Free Ham Radio Course RST Engineering Piloting 43 January 24th 05 08:05 PM
1944 Aerial War Comes to Life in Radio Play Otis Willie Military Aviation 0 March 25th 04 10:57 PM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
