No. It isn't!
Karl "Doug" wrote in message oups.com... My IFR GPS, a King KLN90B is connected to the altimeter in my transponder. It is also adjustable to the barometric setting. |
In rec.aviation.piloting karl gruber wrote:
No. It isn't! Don't know about the 90B, but my 89B has an input from the transponder/encoder. You can use it for advisory VNAV. Since the input is pressure altitude, you need to keep the pressure setting current. Mode C is only accurate to 100 feet though, so you will see it jump up and down by that amount. There is also a page that shows the GPS calculated altitude. I've never seen it closer than a couple of hundred feet to the true altitude. (on the ground; it could be more acurate in the air, but I'd only be comparing it to the transponder or the regular altimeter and maybe they go crazy in the air, but they always agree within 100 feet of each other.) Sometimes I fly 50 feet higher or lower to make the GPS presure-supplied altitude read my assigned altitude so that my flight-aware track (and ATC) believe that I can maintain an altitude as well as an auto-pilot. ![]() Karl "Doug" wrote in message oups.com... My IFR GPS, a King KLN90B is connected to the altimeter in my transponder. It is also adjustable to the barometric setting. -- Don Poitras |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
(sorta OT) Free Ham Radio Course | RST Engineering | Piloting | 43 | January 24th 05 08:05 PM |
1944 Aerial War Comes to Life in Radio Play | Otis Willie | Military Aviation | 0 | March 25th 04 10:57 PM |
Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 03:30 AM |
