Setting altimeters with no radio
Old November 13th 06, 12:34 AM posted to rec.aviation.piloting,rec.aviation.student
Jessica Taylor
Default Setting altimeters with no radio
Peter Duniho wrote:
".Blueskies." wrote in message
t...
What about GPS precision approaches...where does the glideslope
information come from?
WAAS?
WAAS is insufficient for a precision GPS approach.
Nonsense. A fully deployed WAAS can provide precision GPS appoaches with
performance comparable to ILS (Cat 1).
use "LAAS",
Not necessarily. In addition to WAAS, JPALS may be used in the future.
which is basically the same as WAAS except that the differential
station is much closer to the airport
LAAS transmits signals on the UHF band. WAAS does not. LAAS can eventually
provide more accuracy.
Old November 13th 06, 02:06 AM posted to rec.aviation.piloting,rec.aviation.student
Peter Duniho
"Jessica Taylor" wrote in message
Yes, congratulations. I was misinformed (behind the times, actually), and
for once you actually have the right answer.
Thank you for the correction.
Old November 13th 06, 02:50 AM posted to rec.aviation.piloting,rec.aviation.student
Jessica Taylor
Always a pleasure to help get you up to the times, Peter.
Old November 13th 06, 02:17 AM posted to rec.aviation.piloting,rec.aviation.student
Ron Lee
GPS precision approaches use "LAAS",
OK, who is this Jessica dudette? Seems to be uncannily knowledgeable.
It may depend on the meaning of "precision." If you assume any
approach with vertical guidance then WAAS does. If you mean CAT I or
better that depends on where WAAS is/gets to performance wise. It was
supposed to provide CAT I but has had problems.
I have not kept up to date on LAAS but last I heard it may or may not
be developed.
Ron Lee
Old November 13th 06, 02:54 AM posted to rec.aviation.piloting,rec.aviation.student
Bob Noel
Historically, "precision" wrt precision approach means only that it provides
vertical guidance.
Bob Noel
Looking for a sig the
lawyers will hate
Old November 13th 06, 04:54 AM posted to rec.aviation.piloting,rec.aviation.student
Peter Duniho
"Ron Lee" wrote in message
As Bob says, the word "precision" simply implies vertical guidance.
As for whether one can actually get Cat I minima with WAAS, I'm taking the
FAA's word for it. I didn't bother to look for any GPS LPV approaches
specifically to see that they actually exist. I just know that the FAA web
site says (via press release) that as of Oct 2004, they were starting to
roll out Cat I-equivalent GPS approaches.
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 05:39 PM
(sorta OT) Free Ham Radio Course RST Engineering Piloting 43 January 24th 05 08:05 PM
1944 Aerial War Comes to Life in Radio Play Otis Willie Military Aviation 0 March 25th 04 10:57 PM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
