Jantar 48-2 vs Pik20d
Old November 13th 06, 01:06 AM posted to rec.aviation.soaring
Jeff Runciman
Default Jantar 48-2 vs Pik20d
Hi guys,
It has been a while since I have posted here. I have
finally narrowed my search to 2 gliders. I am aware
of the following on each glider:
Jantar - Visibility during tow, and tight cockpit (I
am 5'10' 148 lbs so I fit ok).
Pik 20D - Thick wing mold, parts support, and flaps.
I am a low time glider pilot (27 hours), private pilot
(180 hours) and a high time hang glider pilot (560
hours). I am looking for input regarding the handling,
visibility during flight, problems with each glider,
and any other input.
Thank You,
Jeff Runciman
Old November 13th 06, 01:31 AM posted to rec.aviation.soaring
Jeff Runciman wrote:
Hi guys,
Thank You,
Jeff Runciman
Old November 13th 06, 01:50 AM posted to rec.aviation.soaring
Sorry about that last blank post. Did you write off ASW 19 and Pegasus
101? If so, why?
Here is a good PIK link:
http://www.appledor.net/tsillas/soaring/index.html
Craig
Hi guys,
Thank You,
Jeff Runciman
Old November 13th 06, 02:02 AM posted to rec.aviation.soaring
KM
Hi guys,
I have
Jeff, I asume you are talking about a Jantar Standard?When I was
shopping a few years ago I noticed that the price of an ASW20 was just
barely more than the PIK20D.So I went with the ASW20 as a first ship
and no complaints (Just be methodical about checking yourself out)!The
PIK is nice, but I think the ASW20 is just a bit faster and MUCH better
product support.Stick with the flaped ships if you can, you will be
alot happier than with a standard.
Another thing to consider is that with ships this old, sometimes you
just have to go after condition and not limit yourself to a peticular
type of ship.
Good Luck, you are just in time for shopping season.
Thank You,
Jeff Runciman
K Urban
Old November 13th 06, 02:09 AM posted to rec.aviation.soaring
Jack[_4_]
If you're considering a D-model PIK, the flaps are not such an
obstacle. It has flaps and spoilers. My B-model, has flaps only, and
some people are put off by that. All I can say is that I'm 5'10" and
225 lbs. I am a little tight in the shoulders in my PIK, but not
uncomfortable. I believe the PIKs will end up being among the most
durable sailplanes ever produced. I also believe you'll be happeir with
the PIKs performance.
Just my opinion...
Jack Womack
PIK-20B N77MA (TE)
Old November 13th 06, 02:11 AM posted to rec.aviation.soaring
Jeff Runciman
I have not written off any gliders yet. I have been
looking since 2005. I have not been able to find an
ASW 19 and the 101 has not been imported into Canada
yet. I would love to get a 101 as I have heard it
is a flapless ASW 20 but would be hard to bring into
Canada. It is also almost impossible to bring in an
experimental aircraft into Canada.
Jeff
ASW 19 and Pegasus
101? If so, why?
Craig
Hi guys,
(I
Thank You,
Jeff Runciman
Old November 13th 06, 02:21 AM posted to rec.aviation.soaring
Jeff Runciman
Thanks Jack.
Is there anything in particular that I should look
at on the D that may be a problem during inspection?
Jeff
not such an
flaps only, and
I'm 5'10' and
PIK, but not
among the most
be happeir with
Just my opinion...
Jack Womack
PIK-20B N77MA (TE)
Old November 13th 06, 02:22 AM posted to rec.aviation.soaring
Jeff Runciman
Thanks Jack.
Jeff
not such an
flaps only, and
I'm 5'10' and
PIK, but not
among the most
be happeir with
Just my opinion...
Jack Womack
PIK-20B N77MA (TE)
Old November 13th 06, 03:01 AM posted to rec.aviation.soaring
Jeff Runciman
Thanks Jack.
Jeff
not such an
flaps only, and
I'm 5'10' and
PIK, but not
among the most
be happeir with
Just my opinion...
Jack Womack
PIK-20B N77MA (TE)
Old November 13th 06, 03:03 AM posted to rec.aviation.soaring
Jeff Runciman
Thanks Jack.
Jeff
not such an
flaps only, and
I'm 5'10' and
PIK, but not
among the most
be happeir with
Just my opinion...
Jack Womack
PIK-20B N77MA (TE)
Jantar Std. 3 [email protected] Soaring 2 March 31st 05 10:50 PM
Jantar 2b at the Cinema :) Janusz Kesik Soaring 2 February 23rd 05 04:33 AM
Two-place Jantar?? Gary Boggs Soaring 7 August 22nd 04 07:14 PM
Jantar Std 3 wanted eR Soaring 1 May 18th 04 05:32 PM
Jantar 2A opinions sought Mark Navarre Soaring 4 November 18th 03 04:33 PM
