Bonding Plexiglass
Old November 14th 06, 02:24 AM posted to rec.aviation.homebuilt
David Melby Cavalier
Default Bonding Plexiglass
I'm looking for some info on products to use to bond plexiglass
windshields and other windows in the airframe. I know some guys use
laminating epoxy. I'm sure there are other products as good or better.
Anybody with experience?
Also, anybody with experience with products like zolatone or similiar?
Old November 14th 06, 03:07 AM posted to rec.aviation.homebuilt
Kyle Boatright
There is a clear adhesive called "Lexel" (or is it Lexcel?) that works well
on lexan and plexiglass.
You can find tubes of it in the caulk section of most hardware stores and
home improvement centers.
"David Melby Cavalier" wrote in message
Old November 14th 06, 03:22 AM posted to rec.aviation.homebuilt
Charlie[_2_]
try
http://www.matronics.com/searching/search.html
& search for 'gluing canopy'
Old November 16th 06, 03:53 AM posted to rec.aviation.homebuilt
J.Kahn
A chum at work building an RV-9 just did his canopy with an aerospace
bonding material specially for plexi that cost 15 bucks or so for a
tube. The bonding agent has to allow for thermal expansion of the
canopy so it goes in in about a 1/8 inch thick layer, that is achieved
using spacers as the stuff is injected into the joint. I'll get the
name tomorrow.
John K
Old November 18th 06, 03:42 AM posted to rec.aviation.homebuilt
its called "sikaflex". Do a google search
Old November 21st 06, 12:20 AM posted to rec.aviation.homebuilt
J.Kahn
That's the one...
Plexiglass protective paper jerry wass Home Built 29 January 7th 06 05:57 AM
Working with plexiglass in winter Ben Jackson Owning 2 December 15th 05 07:43 PM
Bonding fibreglass to aluminum pcoopy Home Built 0 December 30th 04 08:20 PM
Shinn brake linings - bonding vice riveting Michael Horowitz Owning 0 July 12th 04 04:47 PM
Combining MEK with Plexiglass - good or bad? [email protected] Owning 0 June 24th 04 06:09 AM
