Completely off-topic help needed :)
Old November 14th 06, 09:52 PM posted to rec.aviation.piloting
Tauno Voipio
Default Completely off-topic help needed :)
Andrew Gideon wrote:
On Tue, 14 Nov 2006 07:39:38 -0800, joe wrote:
You Can't tell by looking at the clouds......come on
Sure you can. If you get a snowflake in your eye when looking at the
clouds, it's snowing.
Laugh
- Andrew
And if the flake is embedded in a waterdrop?
Tauno Voipio
tauno voipio (at) iki fi
Old November 14th 06, 10:05 PM posted to rec.aviation.piloting
Morgans[_2_]
"Mortimer Schnerd, RN" mschnerdatcarolina.rr.com wrote in message
You definitely get some clues from the clouds. Every time I've ever seen it
snow, it's been cold but not too cold (right at freezing but not too much
below or above) and there has been a low heavy looking stratus layer of
clouds. They look relatively dark, indicating there's a lot of moisture and
the cloud layer is fairly deep. Now, when I see these conditions, it doesn't
necessarily snow. But every time I've seen it snow, I see those conditions.
I can tell if it is going to snow when seeing one of those clouds 50% of the
time! g
Jim in NC
Old November 14th 06, 11:58 PM posted to rec.aviation.piloting
Andrew Sarangan[_1_]
One of my 8 year old son's class assignment questions reads, "How can
you look at the clouds and know if it is about to snow?". Never having
seen snow, I hadn't the foggiest idea. Asked a few friends and none
knows either! A quick search on the internet but came up blank,
probably because I haven't given the keywords that might elicit the
correct answer. Wonder who here (Dubai, UAE) came up with such an
irrelevant question!
Any Canadians here who can help? Or anyone near Chicago (snows there,
right?)?
Thanks much in advance and apologies to the rest,
Ramapriya
If the clouds look darker in color, then precipitation is more likely.
If the surface temperature is below zero, then it is likely to turn to
snow. But there is not a whole lot more you can conclude.
Note that these are all probabilities with lots of exceptions. Dark
clouds don't always mean precipitation, you can get virga
(precipitation that do not reach the ground), and you can get rain when
the surface temperature is below zero (freezing rain), and you can get
snow when the surface temp is above freezing (sleet).
Having lived in Canada and the U.S. midwest, I have seen plenty of
snow, sleet, freezing rain and everything in between.
Soaring Flight Computer Comparison - Help needed Paul Remde Soaring 10 January 29th 04 07:35 PM
how many pounds thrust needed ? cdubya Soaring 10 September 14th 03 04:28 AM
E2-C wheel bearings needed CaptAro Restoration 1 July 19th 03 04:32 AM
