Gentle take-offs at high speed
Old November 14th 06, 11:35 PM posted to rec.aviation.piloting
Jim Macklin
Default Gentle take-offs at high speed
The force required to keep many airplanes on the ground
increases drag and extends the take-off roll. Also, moving
the concentration of weight onto the nose wheel and off the
mainwheels will cause the airplane to wheelbarrow and
directional control will be lost.
The early and over rotation on the ground will get the plane
airborne but the high inducted drag will prevent
acceleration. Use the elevator to balance the airplane on
its wheels and rotate into a shallow climb attitude to have
the least total drag.
"Danny Dot" wrote in message
news |
| "EridanMan" wrote in message
| MX -
| snip
| Its interesting though - While most pilot's I talk too
(including my
| instructor) swear by this technique, I haven't seen much
'formal'
| mention of it in the literature... It strikes me as
being a cross
| between a traditional and 'soft-field' takeoff. The FAA
pilot's manual
| warns that "premature rotation" can lead to settling
back down on the
| runway, and suggests a 'proper' takeoff is simply to set
the Aircraft
| in Vy attitude initially and let it fly off the runway,
but my
| instructor has warned me against becoming dependent on
that technique,
| especially if I ever hope to fly out of high DA
airports...
| My high density technique is to accelerate with nose wheel
on the ground to
| my desired final climb speed. Wheels create less drag
than wings. If the
| end of the runway is met before the airspeed is met, take
off anyway.
| Danny Dot
| NASA culture is workplace bullying
| See www.mobbinggonemad.org
| I guess this is one of those areas where I'm still
actively learning a
| great deal.
| -Scott
| On Nov 12, 8:04 pm, wrote:
| Y'All,
| To learn something that is basically incorrect
presents TWO problems.
| If
| this is the first way you learned to perform it will be
your first
| selection
| of options when under stress.
| Secondly, the greatest single quality of knowing
something that has
| fundamental faults is that
| unlearning such a fault is the most difficult part of
you knowledge to
| remove.
| Learning to do something correctly FIRST is the most
important part of
| all
| performance.
| Think on it,
| Gene Whitt
| "Mxsmanic" wrote in
messagenews:93fcl21iie0d6cs8s2hir1euv9edosdfek@4ax .com...
| "Jim Macklin"
writes:
| In the real world, there is no way in hell to keep a
Baron
| on the ground at 100 knots.
| I'm sure that pushing the stick forward works well.
If there were no
| way to keep a Baron on the ground at 100 kts, then no
Baron could ever
| crash at a speed of more than 100 kts, since its
intense desire to fly
| would keep it from contacting the ground.
| Transpose mxsmanic and gmail to reach me by e-mail.
Crosswind Landings... But airspeed? Jmarc99 Soaring 21 October 4th 05 07:54 PM
Space Elevator Big John Home Built 111 July 21st 04 04:31 PM
IVO pireps wanted.. high performance/high speed... Dave S Home Built 8 June 2nd 04 04:12 PM
High Speed Passes & the FAA (long) JJ Sinclair Soaring 17 October 15th 03 12:16 AM
