Setting altimeters with no radio
Old November 15th 06, 03:57 AM posted to rec.aviation.piloting,rec.aviation.student
Newps
Default Setting altimeters with no radio
Doug wrote:
No one has mentioned using the manifold pressure guage as an altimeter.
Because you can't do it in the air, unless you stop the engine first.
Old November 15th 06, 04:51 AM posted to rec.aviation.piloting,rec.aviation.student
Jose[_1_]
Well, you can, sort of, but it probably won't help much. At full
throttle, the manifold pressure will max out at a value that has the
same relationship to altitude as an altimeter. I vaguely recall it's
something like an inch loss per thousand feet high.
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
Old November 15th 06, 05:37 AM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
On a normally aspirated engine, the MAP will be about 1 inch
per thousand feet from 29.92 plus about 1.5 inches for
induction losses on a running engine. So if the maximum
observed MAP is 23 inches, you are at about 5,500 feet
pressure altitude [give or take a thousand feet.
Turbocharged engines make such a check impractical.
"Jose" wrote in message
news | No one has mentioned using the manifold pressure guage
as an altimeter.
engine first.
At full
that has the
recall it's
| Jose
can't see where
Potter).
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 05:39 PM
(sorta OT) Free Ham Radio Course RST Engineering Piloting 43 January 24th 05 08:05 PM
1944 Aerial War Comes to Life in Radio Play Otis Willie Military Aviation 0 March 25th 04 10:57 PM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
