When trailers go bad OR How not to tow your Wright Brothers machine
Old November 15th 06, 07:43 PM posted to rec.aviation.homebuilt
wright1902glider
Default When trailers go bad OR How not to tow your Wright Brothers machine
Ernest Christley wrote:
I've welded a Delta together with a HF torch, and everyone that I can
get to inspect them (and I ask everyone) thinks they are just fine.
Just keep the tip clean and you'll have no problem. Gas welding torches
have been around for over 100yrs, and there really isn't that many ways
to drill an orifice in a piece of copper/brass/whatever those things are
made of.
I wouldn't want to do extensive welding of 1/4" anything with a gas
torch, though...unless maybe it was the dead of winter. A TIG or
wirefed MIG are much more useful there.
Thanks Ernest. If the HF torch is good enough for all of that plumbing,
it should work fine for me. Not too much 1/4" steel in a trailer, but
there is a little. What size tanks do you recommend? Size is an issue,
but the "porta-torch" tanks look a little small for any serious
project.
Harry
Old November 17th 06, 02:48 AM posted to rec.aviation.homebuilt
Ernest Christley
Default When trailers go bad OR How not to tow your Wright Brothersmachine
made of.
project.
Harry
When I was heavy in it, doing lots of frame welding, I borrowed my
uncle's bottles. They're the largest ones that you can actually buy.
By Federal regulations, no one will sell you the larger bottles. But I
often had trouble getting Uncle's bottles exchanged until I set up a
relationship with a single vendor.
Now that I'm done with all the big welding, I think the little portable
bottles have the benefits of not having to lug around all that weight,
or losing lots of gas to leak down as it sits in the corner. I'll
probably settle on the intermediate size that the plumbers carry. It's
plenty enough to do something useful, but not a whole airplane, but
small enough to be fairly portable.
Old November 17th 06, 05:31 AM posted to rec.aviation.homebuilt
Roger (K8RI)
On Fri, 17 Nov 2006 02:48:31 GMT, Ernest Christley
made of.
project.
Harry
I lease one size down from the large tanks. Normally that's plenty of
capacity *unless* doing a lot of heavy duty cutting, thick welding, or
a lot of heating with the "rosebud" tip. Then you go through both
tanks in a hurry. Even in my small shop which is for my own use
(although I find myself doing the occasional job for family), welding
and repairing horse trailers, building fixtures for the airplane, guy
anchors for the big tower, I have gone through three exchanges in
about 4 years. So I use up about one fill a year. Welding the thick
stuff, as long as it's not upside down, it probably easier than
regular welding and certainly easier than the thin stuff, or at least
it is for me. At least the refils are inexpensive.
Mine are definatly not protable except for the two wheel cart and
could be hauled around in a pick up truck with a rack. That's why I
have 75 feet of hose. What I need is a 125 feet for my MIG welder
with the remote wire feed.
www.rogerhalstead.com
Article: America Has Grounded the Wright Brothers Tom Sixkiller Owning 66 January 3rd 04 05:55 PM
Article: America Has Grounded the Wright Brothers Tom Sixkiller Piloting 71 January 3rd 04 05:55 PM
NEXT ON NOVA: "Wright Brothers' Flying Machine" Larry Dighera Piloting 0 December 13th 03 02:32 AM
