GPSMap 396 Power Cable
Old November 16th 06, 03:27 AM posted to rec.aviation.owning
Default GPSMap 396 Power Cable
Kobra wrote:
Just a thought...it might be stupid...but...does anyone think a little
silicon spray lubricant on the sides of the connector would help...or
graphite powder for that matter.
Silicone spray should be fairly harmless - the worst it can probably do
is get into the pins and sockets and prevent an electrical connection,
which means you would have to clean things up with electrical contact
cleaner, _NOT_ WD-40. If you spray the silicone onto a piece of plastic
and then use your finger or a small brush to apply it, sparingly, to the
connector, it might help keep it from going where you don't want it.
Graphite conducts electricity, so if it gets into the pins and sockets,
it might make a bunch of connections you don't want, like between power
and ground. Snap, crackle, pop...
Matt Roberds
Old November 20th 06, 05:03 AM posted to rec.aviation.owning
John_F
I have had two failures of the power plug. It is a very poorly
designed plug. It takes a lot of force to unmate the darn plug even
when you are very careful. After the second expensive failure I
peeled off the outer strip contacts, removed all of the unused inner
contacts, and used a half a drop of Gorilla glue to reattach the plug
body to the cap. It now mates and unmates very easy since only two
pins are mating. It has been working for several months with no more
failures. Garmin needs to redesign the plug body! They have used the
same crappy plug since at least the 296.
John
On Sun, 05 Nov 2006 23:08:42 GMT, Mike Spera
Well, we just broke the first power cable for the beast. I had read that
others were having problems with plug failures so I bought a spare a
while back. The plastic part that is physically plugged into the unit
separates from the back part of the connector molded to the cable. Total
operations until failu about 30.
I had been carefully grasping only the round base "barrel" part of the
connector avoiding the angled part. I always gently wiggle it from side
to side and top to bottom. This time it just separated.
I took a look at the new one to see if we could push it in part way
without bottoming it out. I figured perhaps bottoming it was putting too
much strain on the thing unnecessarily. But, partial insertion will not
work because the connectors on the outside round edge "snap" into place
after it is plugged most of the way in. Unless you reach that point, the
plug will just pop out.
First of all, why did they put a 90 degree angle on this thing? Totally
useless. Second, this cable is TOO SHORT to reach the cig lighter in
most GA planes. H-E-L-L-O! They also put an angled plug on the XM
antenna cable. I suppose they thought they were doing someone a favor.
When used on a particular yoke with a particular placement of the mount,
I could see how straight plugs might be a problem by sticking out the
back. Strange that they used a conventional BNC straight plug. Maybe the
top BNC does not interfere with the yokes they were concerned about.
Other manufacturers use a more conventional method of design with long
pins on the unit, a soft rubber plug, and some soft stays on the outer
round part of the plug to provide some friction against falling out.
Garmin uses 4 short pins, and then puts an additional 4 pins on the
outer barrel part of the plug. The whole assembly is hard plastic, so
they put a round profile on the outer pins that "snap" into place into
the concave receptacle. Nice try, but it does not stand up to normal
use. The spring tension on the outer pins is TOO HIGH.
I am considering putting together a multiplug to circumvent the failure
prone plugs on this unit. Garmin should really do it. At this point, I
would even pay for it... Another option is to REMOVE the outer pins.
They only use 2 and they are for voice data. Hmmmm......
Mike
PIREP: Garmin GMA340 impedance-matching audio cable Peter R. Owning 5 June 15th 06 02:30 PM
nicopress sleeve for stainless steel cable ls Home Built 3 December 6th 05 04:09 PM
PDA GPS power issues (i.trek Mouse) Mark Morissette Owning 8 March 24th 05 02:14 PM
Funny story about piloting [email protected] Piloting 0 December 20th 04 12:34 AM
