Garmin 530 WAAS?
Old November 18th 06, 08:03 PM posted to rec.aviation.ifr
Stan Prevost[_1_]
Default Garmin 530 WAAS?
"Sam Spade" wrote in message
I don't see any need for air data to make this work. It is a positive
course guidance oval, right? So, make the oval the correct dimensions for
containment in protected airspace. Then, the autopilot, flight director,
or hand-flying pilot will compensate for wind by simply remaining on the
yellow brick road.
My autopilot, S-Tec 55, won't do more than a 90% standard rate turn, and
that is only in the high-gain capture mode. If you make the predefined oval
large enough so that such a turn will get you rolled out on the inbound
course in the presence of a stiff xwind from either side, I suppose you can
make it work. For published holds, the containment airspace is already
defined, and may be constrained in some areas due to adjacent airspace and
ATC considerations.
  #52
Old November 18th 06, 08:32 PM posted to rec.aviation.ifr
Sam Spade
ATC considerations.
Restraintt of holding patterns for ATC purposes is very limited, the
most common being using 210 knots in place of 230 knot patterns.
  #53
Old November 18th 06, 11:00 PM posted to rec.aviation.ifr
Mike Adams[_2_]
Sam Spade wrote:
So far as I know, although a lot of them used (and still do with the
older birds) DME/DME updating, none of them used VOR/DME updating...well
unless that was all that the system could see...and often it would just
stay with IRU position rather than use a bad solution.
Yes, airline FMSs are capable of VOR/DME and DME/DME updating, but you are correct that these
modes don't get used much with GPS equipage.
Mike
  #54
Old November 21st 06, 11:30 PM posted to rec.aviation.ifr
Stan Prevost[_1_]
I have read the GNS430W manual and didn't see anything about positive course
guidance around a hold. I may have skipped a few words.
oval large enough so that such a turn will get you rolled out on the
inbound course in the presence of a stiff xwind from either side, I
suppose you can make it work. For published holds, the containment
airspace is already defined, and may be constrained in some areas due to
adjacent airspace and ATC considerations.
Restraintt of holding patterns for ATC purposes is very limited, the most
WAAS up with Garmin? Lakeview Bill Products 0 August 30th 06 12:30 AM
Garmin 430/530 WAAS upgrade reminder Nov 15 Paul kgyy Instrument Flight Rules 18 November 22nd 05 07:22 PM
Garmin GNS430 & WAAS Roy Page Owning 33 April 7th 05 04:02 AM
WAAS and Garmin 430/530 DoodyButch Owning 23 October 13th 03 04:06 AM
Garmin Behind the Curve on WAAS GPS VNAV Approaches Richard Kaplan Instrument Flight Rules 24 July 18th 03 01:43 PM
