backup for vacuum pump/attitude indicator failure
Old November 20th 06, 03:42 AM posted to rec.aviation.owning,rec.aviation.ifr
Mike Spera
Default backup for vacuum pump/attitude indicator failure
Kelly wrote:
I would be interested in getting opinions about backup systems for a
vacuum pump failure and/or AI failure.
..stuff snipped
Looks like I could get a 396
or installed electric AI for about the same price ($2200 or so). While
I haven't seen the panel page/"6-pack" page on the 396 or 496, I have
read (in Aviation Consumer) that it's good enough to keep control of
the airplane in an emergency situation. Obviously, the 396/496 has a
number of other neat features such as inflight weather, terrain info,
etc.
Funny you should ask. I covered up my AI and DG and tried flying via the
panel page on my 396. Downright freaky. I figured the lag would not be
too bad but it really does present a challenge. I suppose with practice
it might do. But in bumpy IMC I might be chasing the TC and altimeter
indications all over the place. The 496 has a faster refresh that may
make this less of an issue.
On the other hand, the lag might keep me from overworking the controls
as I often do in IMC on a bumpy day. You won't correct for every little
deviation because the unit won't update that fast.
I like the idea of that little box that had solid state gyros in it and
you would velcro to the floor and hook up to a PDA. Instant electric
gyros without the gyro wear and tear. If only you could USB the signal
into the 396...
Good Luck,
Mike
Backup Flight Data Recorder? Fox Two Soaring 14 August 27th 06 09:42 AM
Backup vacuum pump system STC'ed for Cherokee 180 Chuck Owning 6 September 18th 04 02:30 PM
Fllight Recorder Wars, Part II: What Backup to Use? Chip Bearden Soaring 13 March 31st 04 10:10 PM
Good AI backup, wish me luck Robert M. Gary Instrument Flight Rules 29 March 1st 04 05:36 PM
Solid State Backup AI Dan Truesdell Instrument Flight Rules 20 January 15th 04 09:53 PM
