VFR position reporting
Old November 21st 06, 02:39 AM posted to rec.aviation.piloting,rec.aviation.student
BT
Default VFR position reporting
ok.. so once again the non pilot asking so many questions knows better than
30yr multi thousand hour pilots.
I fully understand the "radar flight following", but I can make position
reports to FSS and they will know where to begin looking for me (between my
last report and my intended destination), so they would have a "flight
following paper trail" of where I have been, even if it is not real time
radar.
From what you tend to know or have about flight following or position
reporting, that same book will (should) have the format for position
reporting.
Oh, while you've got them on the line, give them a pilot report.
BT
"Mxsmanic" wrote in message
BT writes:
if you are making position reports
do you not then have flight following?
No, they are two different things. Normally you have one or the
other. If you have flight following, ATC has you on radar, and they
don't need position reports, as they know exactly where you are. If
you don't have flight following (because you haven't requested it, or
ATC has refused it, or you are not visible on radar), you can make
periodic position reports, so that people know where you are, in case
you crash.
From what I understand, you try to report to a FSS if you are making
position reports, but I'm not sure of the other details.
Old November 21st 06, 03:50 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
BT writes:
reporting.
I've been looking for the format, but I haven't found it thus far.
Old November 21st 06, 05:43 AM posted to rec.aviation.piloting,rec.aviation.student
BT
AIM 5-1-4 g. With Examples
For you, that would be the Airman's Information Manual, Chapter 5 Air
Traffic Prcedures, Section 1 Flight Plans, Part 4 VFR Flight Plan - VFR
Flights, paragraph g. Position Reporting. Example 1 and Example 2
BT
BT writes:
reporting.
Old November 21st 06, 06:19 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
BT writes:
Found it, thank you. The examples aren't very highly codified;
perhaps there is no rigid format.
Old November 22nd 06, 01:56 AM posted to rec.aviation.piloting,rec.aviation.student
BT
why does it need to be rigid? how much more rigid can you get?
This is me..
This is where I am..
This is where I am going..
what more do you need?
BT
BT writes:
Old November 22nd 06, 04:51 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
BT writes:
It doesn't have to be, but in information theory, the more rigid the
encoding, the greater than transfer of information. That's why the
phrasing of ATC communications is so highly conventionalized. That's
why METARs and TAFs have a highly specialized format.
Old November 22nd 06, 05:27 AM posted to rec.aviation.piloting,rec.aviation.student
Jim Logajan
Mxsmanic wrote:
BT writes:
I believe the transmission of weather information by use of abbreviated
METAR codes originated in the days of 10 character-per-second Teletypes (or
possibly even earlier). The ASR 33 Teletype (the model I'm personally
familiar with) could only print uppercase characters. At that slow rate of
printing and usingg such a limited character set, brevity was an asset.
I first learned to program in 1973 using Teletypes as input and output
device. A nice picture of an ASR 33 teletype is he
http://www.catb.org/~esr/writings/ta...l/ch02s02.html
GPS and old-fashioned thinking? G Farris Instrument Flight Rules 92 December 22nd 05 05:39 PM
ASRS/ASAP reporting systems - how confidential? Tim Epstein Piloting 7 August 4th 05 05:20 PM
