Earlier, noel.wade wrote:
Where is your glider's CG envelope? Dick Schreder generally recommended 25% to 40% of MAC; most sailplanes are similar. I generally recommend 25% to 35% for the HP-18. Basically, work back through the wing dimensions to find out what the MAC is. Then find the spot on the wing where its chord is the same as the MAC. Then find the longitudinal location of that wing station. That's what the CG envelope relates to. The final Article on the HP-18 shows how find the CG envelope in relation to MAC and determine minimum and maximum cockpit weights from it. The one thing in the Article I take issue with is that Dick assumes that the mean chord is the same as the average chord, but they're not the same. However, the difference is so small that it makes no practical difference in this particular case: http://www.soaridaho.com/Schreder/Sc...976_HP-18.html Thanks, Bob K. |
Weight and Balance Formula, Can one calculate the envelope | Joe Wasik | Piloting | 12 | September 29th 04 08:15 AM |
Stupid question about flight testing and "the envelope" | Scott Ferrin | Military Aviation | 12 | January 7th 04 03:56 AM |
