OLC Problems
Old November 20th 06, 07:35 PM posted to rec.aviation.soaring
Ramy
Default OLC Problems
There are also serious time zone and calendar issues as a result of
javascript errors, which requires multiple steps to get around. But
apparently it is more important to the OLC team to provide a google
earth link than fix their bugs. Can't even use olc to review other's
flights anymore...
It's about time that someone with spare time and talent will develope a
US alternative to olc, without all the hassles and politics.
Ramy
Doug Haluza wrote:
Greg Arnold wrote:
Tim Taylor wrote:
I get on about 50% of the time. Does anyone know how to contact the
admins for the OLC, I have a flight with a zero score that I don't know
how to fix.
Don't bother to contact the OLC admins in Europe -- I have 4 flights
with zero scores, and they don't know how to fix any of them. Doug
Haluza in the USA is doing a good job, but he doesn't have the access to
the website necessary to fix the problems.
Recently, the website seems to be down every evening in the USA --
almost like the people in Europe turn off the server when they go to
bed. Maybe they are trying to conserve electricity.
There is a problem with the OLC production server crashing, and they
have not been able to reproduce the problem on the development server,
so this will be a difficult problem to fix. In the mean time, it has to
be manualy rebooted when it crashes. The OLC team does get an SMS
message whenever this happens, so there is no need to notify them; but
someone has to be near a computer to fix it. Naturally if it happens
late at night, it does not get fixed until the next morning (German
time).
There are also problems in the scoring algorithm causing some flights
to get zero score. As the problems are fixed, the flights will be
re-scored, as some have been already, so please be patient. Keep
claiming your flights, since they can't be fixed if they are not
submitted by the Tuesday 24:00 local deadline.
Old November 20th 06, 09:24 PM posted to rec.aviation.soaring
hans
Default OLC Future
flights anymore...
Ramy
At least one nation has done it already, others have never joined the
OLC movement.
But is the world gliding community sufficiently powerful that we can
allow it to split it into many small communities?
Old November 20th 06, 11:38 PM posted to rec.aviation.soaring
Bob Gibbons
This is what I use,
http://www3.onlinecontest.org/olc-2....tml?country=US
In the US I find the calendar defaults to tomorrow's date, so I often
initially get a "no flights to report" notice.
Also, since there are apparently Javascript problems with their
calendar, using the mouse to select a new date does not usually work.
I have found that this bug can be avoided by using the upper calendar
arrows to move the date back a year and then return forward a year.
This seems to enable the mouse to select the desired date in the
calendar.
..... as I have said before regarding OLC2, avoiding these sorts of
problems is why we have "beta tests" before a production release.
We in the northern hemisphere are in our low season, pity our poor
brothern in the southern hemisphere entering their prime season with a
busted OLC.
Bob
On Mon, 20 Nov 2006 03:57:23 GMT, "P. Corbett "
Mal wrote:
Is anyone else having problems logging in to the OLC
I can usually log on using www3.onlinecontest.org but they keep saying
that there are no flights to report. It is hard to believe that there is
no one on the planet flying a glider, especially down under.
Can anyone pass-on the link they are using to view flights with the new
system?
Paul
ZZ
Old November 21st 06, 05:01 AM posted to rec.aviation.soaring
Jack
Default OLC Future
The world gliding community is ready for something that works. The
question is, who will provide it?
Jack
Old November 21st 06, 05:56 AM posted to rec.aviation.soaring
Ramy
Default OLC Future
From rumor central, someone is already working on it locally...
Ramy
Jack
Old November 21st 06, 01:57 PM posted to rec.aviation.soaring
kirk.stant
Default OLC Future
Hey, It worked!
Logged on this morning, checked out a flight down under via Google maps
(and the default map is better, too), then went back and found my
flight back on Oct 22 had finally been scored (not much, but a start).
Ok, I feel better now.
Keep up the good work, OLC gang - and just ignore (well, listen a
little) the whiners (yours truly included) - it's our grumpy season
now...
Kirk
66
Old November 21st 06, 05:13 PM posted to rec.aviation.soaring
Bruce Greef
Default OLC Future
kirk.stant wrote:
Hey, It worked!
now...
You mean there is a difference? ;-)
Kirk
66
Bruce
Old November 21st 06, 08:49 PM posted to rec.aviation.soaring
SAM 303a
Default OLC Future
It does work, but like SAP, you have to do it their way. Simply adapt your
habits, processes and products to their code and all will be well.
(sorry about the software humour in a soaring newsgroup)
"Jack" wrote in message
et...
Jack
Old November 22nd 06, 05:31 AM posted to rec.aviation.soaring
Frank Whiteley
Bruce Greef wrote:
Bob wrote:
If it is that unreliable and with the wealth of IT talent that we have
within the soaring community, I'm surprised that no one else has tried
to improve on the system!!
Bob
7U
Mal
www.mals.net
So far so good - I have been able to log on every time I tried (same timezone as
Germany). Now if the weather would just improve enough that there was a flight
worth uploading...
Bruce
Gone again
Frank
Old November 22nd 06, 02:15 PM posted to rec.aviation.soaring
The calendar is working today.
The 'suggested initial date' displayed will always be Euro time I
suspect until their scripts can detect local time zones, but a single
click on a calendar day with claimed flights now works.
Patience is the key. They had to get it running to take in new flight
logs, that's priority one. And how do you test this in a volunteer
development environment with the volume of countries, langauges and
Internet frailities? The testing they DID do must have worked before we
saw anything public.
Next they worried about auto claiming from SeeYou, Strepla, etc. I bet.
And those folks are responding, and again volume use draws out bugs,
and those will be fixed.
We are told that the regional results will return, as will Novice class
or whatever your country had before.
The Google Earth link may seem a frill, but my guess is the volunteer
who took on that component got it working before the other requirements
were ready. This feature is certainly one we can all use to promote
interest in our sport, and it's just plain fun to see flights from
around the world in such terrain detail. Whether they use the paved
strip or the grass! You can even decide whether the outlanding pilot
chose the best field (for when the imagery was taken anyway) ! My guess
is that by mid summer 2007 the complaints here will focus on what
country or state has the best or worst resolution in Google Earth!
It's free, it's fun, it's addictive. The proof of that is in the posts
showing frustration with getting a flight posted.
Let's give them support and suggestions and maybe reduce the anger a
notch or two. You know how you can feel as a club volunteer when
someone thinks your contributions are less than perfect.
Great work OLC and the volunteers in every country, and continued
success! ....Bringing more fun to an already fun sport!
Bob
Canada
Bob Gibbons wrote:
snip
GPS Reception Problems with 396 Dan Piloting 16 August 5th 06 04:01 AM
Mooney Engine Problems in Flight Paul Smedshammer Piloting 45 December 18th 04 09:40 AM
Chaplains urge couples to attend retreat to solve problems, By Kent Harris, Stars and Stripes Otis Willie Military Aviation 0 May 31st 04 03:46 AM
F22 Problems Paul F Austin Military Aviation 9 February 5th 04 02:27 AM
