FADEC = complex
Old November 22nd 06, 10:16 PM posted to rec.aviation.piloting
Mxsmanic
Default FADEC = complex
Matt Whiting writes:
I thought FADEC was simpler. :-)
Simpler when things are going well, much more complex when things go
wrong. Like all fly-by-wire systems.
Old November 23rd 06, 12:16 AM posted to rec.aviation.piloting
Newps
There is no change in complexity when things go wrong with FADEC.
Old November 23rd 06, 12:26 AM posted to rec.aviation.piloting
Mxsmanic
Newps writes:
Yes, there is, because digital systems have different failure modes
from those of analog systems, and digital failure modes are often
catastrophic failure modes.
Old November 23rd 06, 01:50 AM posted to rec.aviation.piloting
Newps
Mxsmanic wrote:
Newps writes:
Spoken like a sim pilot. If you had the slightest idea what the hell
you were talking about you would know that when the FADEC fails, usually
the computer goes belly up but it could be an electrical power loss, the
engine continues to run but does so at a very rich setting. If the
FADEC controls the prop then that goes to high RPM. The pilot doesn't
have to do anything except land and landing immediately isn't necessary
either. These failure modes are a requirement for certification.
Old November 23rd 06, 02:13 AM posted to rec.aviation.piloting
Kev
Newps wrote:
Mxsmanic wrote:
Newps writes:
FADEC controls the prop then that goes to high RPM. [..]
Seems like you just proved his statement that digital failure modes are
different. If my analog (mechanical in this case) prop control fails,
it doesn't affect my mixture at the same time, as you're saying FADEC
does.
At the same time: Mxsmanic, apparently they've designed FADEC to fail
without being catastrophic.
My own personal worry is coming automobiles with totally electronic
steering and brakes. I'm sorry, even thoughI design reliable embedded
systems and I still would hate owning a car like that :-)
Kev
Old November 23rd 06, 02:35 AM posted to rec.aviation.piloting
Mxsmanic
Kev writes:
The designed-for failure modes are never a problem. The problem with
digital systems is with unforeseen failures, which usually have no
correlation with real-world constraints and are often catastrophic
failures in consequence.
You always need a way to disconnect the computer, and it has to be a
mechanical disconnection, not just an option on the screen menu.
If you design embedded systems, you know why such a car would be
risky.
Old November 23rd 06, 02:37 AM posted to rec.aviation.piloting
Newps
different.
I never said they weren't different, only that the complexity of the
situation doesn't change. The pilot will be notified, probably by a red
light, that the FADEC failed. That's it, there's nothing for him to do.
Indeed in most cases there's nothing he could do even if he wanted.
does.
I didn't say that either. I meant to say that if the part of the FADEC
fails that controls the prop then the exact same thing happens there as
will happen to you, high RPM.
Old November 23rd 06, 02:34 AM posted to rec.aviation.piloting
Mxsmanic
Newps writes:
No, spoken like a computer specialist.
FADECs can fail in all sorts of ways, depending on the software bugs
they contain.
Old November 23rd 06, 05:09 AM posted to rec.aviation.piloting
Newps
they contain.
No, they cannot.
Old November 23rd 06, 06:44 AM posted to rec.aviation.piloting
Mxsmanic
Newps writes:
No, they cannot.
One day, you may be surprised.
Is this a Complex Plane? [email protected] Piloting 12 December 7th 05 03:19 AM
Commercial rating: complex aircraft required aircraft for practical test? Marc J. Zeitlin Piloting 22 November 24th 05 04:11 AM
Complex / High Performance / Low Performance R.T. Owning 22 July 6th 04 08:04 AM
Experience transitioning from C-172 to complex aircraft as potential first owned aircraft? Jack Allison Owning 12 June 14th 04 08:01 PM
Complex Aircraft Question Chris General Aviation 5 October 18th 03 04:40 AM
