AC motor voltage conversion?
Old November 22nd 06, 11:40 PM posted to rec.aviation.homebuilt
Jarhead
Default AC motor voltage conversion? IT'S 240 Volts, NOT 220...
"T o d d P a t t i s t" wrote in message
| john smith wrote:
| Ahhh! But where does the 240 come from?
| Does it not come from two of the three legs of a Y or Delta?
| It doesn't matter where the 240 comes from, it matters what
| the phase of each wire is relative to some reference. The
| US (and Europe, but at twice the voltage) use a 3-wire,
| single-phase, mid-point neutral distribution system for most
| residential loads. If you use the neutral as the reference,
| then there are two opposite phase wires or split phases. If
| you use the opposite wire as the ref, then there is a single
| phase 240 volt signal.
| Commercial sites receive 3-phase power, not single phase.
| The voltage difference between two of the three legs in that
| system is 208 volts, not 240 volts
| These are square root and cube root functions.
| No they are not - they are trig functions depending on phase
| angle.
| If they were 180 out of phase, it would cancel.
| Phase depends on the reference. You can ignore the neutral
| and just see it as a single phase 240 volt system using
| either hot lead as the reference. If you prefer, you can
| think of one hot lead as being the reference, the neutral as
| having a 120 volt signal on it and the other hot lead as
| having a 240 volt signal in phase with the 120 volt signal
| on the neutral.
| (Remove DONTSPAMME from address to email reply.)
| Make a commitment to learn something from every flight.
| Share what you learn.
Came across this:
If you have three phase (Y or Wye, which is fairly commonly provided to
businesses or industries but not common in homes) electricity, you can
get a ``sort of'' 240 volt circuit out of it by running between any two
of the three phases. The phase difference is only 120° instead of 180°
so one ends up with only 208 VAC or so between the wires. This is enough
to run most 240 VAC devices simply because the manufacturers aren't
fools and know that Y/Wye supplies are fairly common. This is also true
for a lot of computer equipment that requires 240 VAC (like some racks
or uninterruptible power supplies (UPS) or some big-iron computers).
Taken from this site:
http://www.phy.duke.edu/~rgb/Beowulf...ok/node60.html
Jarhead
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 100,000 Newsgroups
---= East/West-Coast Server Farms - Total Privacy via Encryption =---
Japanese firm sold Libya uranium conversion plant Dav1936531 Military Aviation 2 March 17th 04 03:47 PM
PIREP: Headsets Inc conversion of Dave Clark DC10-13.4s Paul Tomblin Piloting 0 January 20th 04 01:46 PM
Mini 500, Helicycle, Turbine, Joe Rinke, Rinke Aerospace, Rick Stitt, Conversion, Kit TurbineMini Richard Rotorcraft 0 January 15th 04 11:48 PM
TRUTH OF THE MINI-500 TURBINE CONVERSION Dennis Chitwood Rotorcraft 10 January 7th 04 05:33 PM
Auto conversion cost post Richard Riley Home Built 13 December 28th 03 12:52 PM
