On Wed, 22 Nov 2006 20:11:12 GMT, john smith wrote:
In article , "Peter Dohm" wrote: 180 degree out-of-phase" voltage level. Are you certain you don't mean 120- or 240-degrees out of phase? How does one get two lines 180-degrees out of phase? 240V single phase, commonly supplied to single family dwellings, has a center tap and two hot leads which are 180 degrees out of phase to supply higher powered items such as air conditioning and electric stoves. In addition, approximately half of the lower powered items, such as lights and the refrigerator, are powered by each of the two legs to the center tap--which is approximately ground potential. Ahhh! But where does the 240 come from? Does it not come from two of the three legs of a Y or Delta? These are square root and cube root functions. If they were 180 out of phase, it would cancel. In north american residential and in most cases rural electricity, the 220 is NOT derived from a delta or wye connected three phase, but from a simple center tapped power transformer on a single phase line (or one leg of a three phase line - not 2). 208 is derived from 3 phase, and is only found in SOME buildings where 3 phase is required for other purposes, such as multi-unit residential buildings with 3 phase elevators, or commercial/industrial applications. Even in many of these situations, a center tapped transformer (single phase) is used to provide the 120/240 single phase domestic power.(at least in Ontario Canada) -- Posted via a free Usenet account from http://www.teranews.com |
Japanese firm sold Libya uranium conversion plant | Dav1936531 | Military Aviation | 2 | March 17th 04 03:47 PM |
PIREP: Headsets Inc conversion of Dave Clark DC10-13.4s | Paul Tomblin | Piloting | 0 | January 20th 04 01:46 PM |
Mini 500, Helicycle, Turbine, Joe Rinke, Rinke Aerospace, Rick Stitt, Conversion, Kit | TurbineMini Richard | Rotorcraft | 0 | January 15th 04 11:48 PM |
TRUTH OF THE MINI-500 TURBINE CONVERSION | Dennis Chitwood | Rotorcraft | 10 | January 7th 04 05:33 PM |
Auto conversion cost post | Richard Riley | Home Built | 13 | December 28th 03 12:52 PM |
