Since the original question was about landing speeds, I assume you
mean traps? Here is a topic for discussion..... The E/F "Rhino" comes in fast and heavy. The gear on Nimitz class is taking a heavy toll and is wearing out faster than the design was intended. The "Growler" will come in heavier and faster. Can the current configuration of the arresting gear handle it and not have catastrophic fatigue failure without major modification? On Wed, 22 Nov 2006 12:53:26 -0800, "W. D. Allen" wrote: The closer to the fuselage the greater the bending load on the wings due to lift forces. But at the fuselage is where the "swing" hinges are typically located, which makes for a complicated, and unnecessary, structural design problem. WDA end "DDAY" wrote in message nk.net... ---------- In article , "W. D. Allen" wrote: Those swing wing aircraft disappeared for probably the same reason swept wings are disappearing and ICBM rocket motor exhaust cone skirts are no longer used. The performance increase was not worth the mechanization complexity or maintenance. Yep, that's the theory that I'm working toward--a change in the definition of acceptable. I recently saw an ad for an Indian airpower expo and it featured a sleek concept model aircraft with swing wings. At first I was shocked and wondered if this means that the Indians are actually considering building such an aircraft. However, I soon noticed that the model appears to have three engine inlets--two on either side (like an F-18) and a large ventral one. That makes no sense and I think the model is notional. Other than that, I haven't seen any serious consideration of swing wings in many years. D -------------------------------------------------------------------------------- I am using the free version of SPAMfighter for private users. It has removed 917 spam emails to date. Paying users do not have this message in their emails. Try SPAMfighter for free now! |
Sorry,
To clarify, Landing speeds are not the only consideration. Lift on takeoff is the major consideration. Can you imagine a Tomcat with TF-30's trying to take off with wings swept? About 8000 ft maybe on a good day! (granted with 110-400's and wings extended about 2500 ft) On Thu, 23 Nov 2006 01:25:43 -0800, fudog50 wrote: Since the original question was about landing speeds, I assume you mean traps? Here is a topic for discussion..... The E/F "Rhino" comes in fast and heavy. The gear on Nimitz class is taking a heavy toll and is wearing out faster than the design was intended. The "Growler" will come in heavier and faster. Can the current configuration of the arresting gear handle it and not have catastrophic fatigue failure without major modification? On Wed, 22 Nov 2006 12:53:26 -0800, "W. D. Allen" wrote: The closer to the fuselage the greater the bending load on the wings due to lift forces. But at the fuselage is where the "swing" hinges are typically located, which makes for a complicated, and unnecessary, structural design problem. WDA end "DDAY" wrote in message ink.net... ---------- In article , "W. D. Allen" wrote: Those swing wing aircraft disappeared for probably the same reason swept wings are disappearing and ICBM rocket motor exhaust cone skirts are no longer used. The performance increase was not worth the mechanization complexity or maintenance. Yep, that's the theory that I'm working toward--a change in the definition of acceptable. I recently saw an ad for an Indian airpower expo and it featured a sleek concept model aircraft with swing wings. At first I was shocked and wondered if this means that the Indians are actually considering building such an aircraft. However, I soon noticed that the model appears to have three engine inlets--two on either side (like an F-18) and a large ventral one. That makes no sense and I think the model is notional. Other than that, I haven't seen any serious consideration of swing wings in many years. D -------------------------------------------------------------------------------- I am using the free version of SPAMfighter for private users. It has removed 917 spam emails to date. Paying users do not have this message in their emails. Try SPAMfighter for free now! |
The E/F "Rhino" comes in fast and heavy. The gear on Nimitz class is taking a heavy toll and is wearing out faster than the design was intended. The "Growler" will come in heavier and faster. Can the current configuration of the arresting gear handle it and not have catastrophic fatigue failure without major modification? I've heard the arresting gear is being overhauled on USS Reagan IOT support Operational Test for Growler. |
![]() "M. B." wrote in message news:1Fo9h.6234$J5.4129@trnddc04... Here is a topic for discussion..... The E/F "Rhino" comes in fast and heavy. The gear on Nimitz class is taking a heavy toll and is wearing out faster than the design was intended. The "Growler" will come in heavier and faster. Can the current configuration of the arresting gear handle it and not have catastrophic fatigue failure without major modification? I've heard the arresting gear is being overhauled on USS Reagan IOT support Operational Test for Growler. Of course, its a function of weight and speed (squared if I remember my HS physics correctly). The old RA-5C was pretty heavy and fast, the Whale was just heavy. The F-14 could come aboard at 52.8 (later 54.0 IIRC, don't know for sure, never flew the airplane with proper engines), but the speeds were in the mid 130's. Of course, the big deal on the Rhino (Grihno?) is bring back, so while the airframe is relatively light, if its weight gets up there and the speed gets into the high 140's .... R / John |
![]() fudog50 wrote: Since the original question was about landing speeds, I assume you mean traps? Here is a topic for discussion..... The E/F "Rhino" comes in fast and heavy. The gear on Nimitz class is taking a heavy toll and is wearing out faster than the design was intended. The "Growler" will come in heavier and faster. Can the current configuration of the arresting gear handle it and not have catastrophic fatigue failure without major modification? I have landed onboard Nimitz as well as other CVs same class in the Phantom, which I think was 'faster and heavier' than the 'Bug' series of A/C'...same for the RA-5 and Whale(altho I don't know if it was faster coming aboard than the F-4)..why would the Growler and Super bugs start to wear things out now? On Wed, 22 Nov 2006 12:53:26 -0800, "W. D. Allen" wrote: The closer to the fuselage the greater the bending load on the wings due to lift forces. But at the fuselage is where the "swing" hinges are typically located, which makes for a complicated, and unnecessary, structural design problem. WDA end "DDAY" wrote in message nk.net... ---------- In article , "W. D. Allen" wrote: Those swing wing aircraft disappeared for probably the same reason swept wings are disappearing and ICBM rocket motor exhaust cone skirts are no longer used. The performance increase was not worth the mechanization complexity or maintenance. Yep, that's the theory that I'm working toward--a change in the definition of acceptable. I recently saw an ad for an Indian airpower expo and it featured a sleek concept model aircraft with swing wings. At first I was shocked and wondered if this means that the Indians are actually considering building such an aircraft. However, I soon noticed that the model appears to have three engine inlets--two on either side (like an F-18) and a large ventral one. That makes no sense and I think the model is notional. Other than that, I haven't seen any serious consideration of swing wings in many years. D -------------------------------------------------------------------------------- I am using the free version of SPAMfighter for private users. It has removed 917 spam emails to date. Paying users do not have this message in their emails. Try SPAMfighter for free now! |
The RA-5C max trap was 50,000 pounds, at 139KIAS on-speed.
Maybe the numb-nutz has gone kinder/gentler since then. Frank wrote in message oups.com... fudog50 wrote: Since the original question was about landing speeds, I assume you mean traps? Here is a topic for discussion..... The E/F "Rhino" comes in fast and heavy. The gear on Nimitz class is taking a heavy toll and is wearing out faster than the design was intended. The "Growler" will come in heavier and faster. Can the current configuration of the arresting gear handle it and not have catastrophic fatigue failure without major modification? I have landed onboard Nimitz as well as other CVs same class in the Phantom, which I think was 'faster and heavier' than the 'Bug' series of A/C'...same for the RA-5 and Whale(altho I don't know if it was faster coming aboard than the F-4)..why would the Growler and Super bugs start to wear things out now? On Wed, 22 Nov 2006 12:53:26 -0800, "W. D. Allen" wrote: The closer to the fuselage the greater the bending load on the wings due to lift forces. But at the fuselage is where the "swing" hinges are typically located, which makes for a complicated, and unnecessary, structural design problem. WDA end "DDAY" wrote in message nk.net... ---------- In article , "W. D. Allen" wrote: Those swing wing aircraft disappeared for probably the same reason swept wings are disappearing and ICBM rocket motor exhaust cone skirts are no longer used. The performance increase was not worth the mechanization complexity or maintenance. Yep, that's the theory that I'm working toward--a change in the definition of acceptable. I recently saw an ad for an Indian airpower expo and it featured a sleek concept model aircraft with swing wings. At first I was shocked and wondered if this means that the Indians are actually considering building such an aircraft. However, I soon noticed that the model appears to have three engine inlets--two on either side (like an F-18) and a large ventral one. That makes no sense and I think the model is notional. Other than that, I haven't seen any serious consideration of swing wings in many years. D --------------------------------------------------------------------------- ----- I am using the free version of SPAMfighter for private users. It has removed 917 spam emails to date. Paying users do not have this message in their emails. Try SPAMfighter for free now! |
![]() Its a changed world. The Forrestals are now called "small decks" by those grizzled salts that operated from them, and Rhinos are "huge". Of course the gents who flew A-3s on the 27 charlies may have a different perspective... Frank Minich wrote: The RA-5C max trap was 50,000 pounds, at 139KIAS on-speed. Maybe the numb-nutz has gone kinder/gentler since then. Frank wrote in message oups.com... fudog50 wrote: Since the original question was about landing speeds, I assume you mean traps? Here is a topic for discussion..... The E/F "Rhino" comes in fast and heavy. The gear on Nimitz class is taking a heavy toll and is wearing out faster than the design was intended. The "Growler" will come in heavier and faster. Can the current configuration of the arresting gear handle it and not have catastrophic fatigue failure without major modification? I have landed onboard Nimitz as well as other CVs same class in the Phantom, which I think was 'faster and heavier' than the 'Bug' series of A/C'...same for the RA-5 and Whale(altho I don't know if it was faster coming aboard than the F-4)..why would the Growler and Super bugs start to wear things out now? On Wed, 22 Nov 2006 12:53:26 -0800, "W. D. Allen" wrote: The closer to the fuselage the greater the bending load on the wings due to lift forces. But at the fuselage is where the "swing" hinges are typically located, which makes for a complicated, and unnecessary, structural design problem. WDA end "DDAY" wrote in message nk.net... ---------- In article , "W. D. Allen" wrote: Those swing wing aircraft disappeared for probably the same reason swept wings are disappearing and ICBM rocket motor exhaust cone skirts are no longer used. The performance increase was not worth the mechanization complexity or maintenance. Yep, that's the theory that I'm working toward--a change in the definition of acceptable. I recently saw an ad for an Indian airpower expo and it featured a sleek concept model aircraft with swing wings. At first I was shocked and wondered if this means that the Indians are actually considering building such an aircraft. However, I soon noticed that the model appears to have three engine inlets--two on either side (like an F-18) and a large ventral one. That makes no sense and I think the model is notional. Other than that, I haven't seen any serious consideration of swing wings in many years. D --------------------------------------------------------------------------- ----- I am using the free version of SPAMfighter for private users. It has removed 917 spam emails to date. Paying users do not have this message in their emails. Try SPAMfighter for free now! |
![]() "Frank Minich" wrote in message ... The RA-5C max trap was 50,000 pounds, at 139KIAS on-speed. Maybe the numb-nutz has gone kinder/gentler since then. Frank I thought is was a bit faster, mid-140's. Thanks for the info. R / John |
fudog50 wrote in
: Since the original question was about landing speeds, I assume you mean traps? Here is a topic for discussion..... The E/F "Rhino" comes in fast and heavy. The gear on Nimitz class is taking a heavy toll and is wearing out faster than the design was intended. The "Growler" will come in heavier and faster. Can the current configuration of the arresting gear handle it and not have catastrophic fatigue failure without major modification? I would simply draw your attention to several designs that could have been or were operated off Enterprise class & later carriers. A3, F4, A5 & F111. All heavier (30-40+ tons) than the Rhino or Growler. I think the rough aim point for approach speeds is something like ` 140Kts +/-. IBM |
A-3B CLEO was 49k max landing, 117kias
A-3B non-CLEO was 47k, 117kias Later A-3B's with Cambered Leading Edge wing, noted by slats inboard of the engines. After 1965 most A-3's were versions: tankers, ECM, photo-recon, or the overweight EKA-3B (or ERA-3B?) which couldn't operate from a carrier. But that was after my time (Forrestal was 5 years old, had a starboard side mirror, God's gift to the fleet with a 600psi steam plant, and the Whale was a strategic bomber.) Joel McEachen VAH-5 Ian MacLure wrote: fudog50 wrote in : Since the original question was about landing speeds, I assume you mean traps? Here is a topic for discussion..... The E/F "Rhino" comes in fast and heavy. The gear on Nimitz class is taking a heavy toll and is wearing out faster than the design was intended. The "Growler" will come in heavier and faster. Can the current configuration of the arresting gear handle it and not have catastrophic fatigue failure without major modification? I would simply draw your attention to several designs that could have been or were operated off Enterprise class & later carriers. A3, F4, A5 & F111. All heavier (30-40+ tons) than the Rhino or Growler. I think the rough aim point for approach speeds is something like ` 140Kts +/-. IBM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 07:00 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
