Eric Greenwell wrote:
Doug Haluza wrote: Current flows in a complete circuit--direction is arbitrary and irrelevant. What actually happens in many cases of applicance damage is not voltage surges, it's ground potential difference. If your power, telephone, cable TV and water services do not enter at the same point and have common grounding, they can have different "gound" potentials relative to each other. Even if lightning does not strike your house directly, it disturbs the ground potential for a large area. This is why telephones, televisions and refrigerators with ice makers are often damaged--they are connected to two different systems. If the surge protector has a cable or phone jack connector in addition to the AC sockets, would that protect the TV or telephone? To the extent that the surge protector is able, yes. However, the cheap power strip surge protectors that people often have are unlikely to absorb a lighting strike. If this is your goal, make sure you purchase one that says it can handle it. The good ones have attached equipment guarantees, where they'll pay for damage if their stuff fails to protect your stuff. -- Michael Ash Rogue Amoeba Software |
Michael Ash wrote:
To the extent that the surge protector is able, yes. However, the cheap power strip surge protectors that people often have are unlikely to absorb a lighting strike. If this is your goal, make sure you purchase one that says it can handle it. ... Show me a surge protector with numbers that can 'absorb' or therefore eliiminate surges? Myth purveyors - those who never looked inside nor read a manufacturer datasheet - believe a surge protector somehow stops or absorbs what three miles of sky could not. An appliance connects directly to AC mains when plugged into a power strip protector. What is 'in series' to absorb those joules? Nothing. There is no electrical dam inside that power strip protector. Absorbing is not a protector function. But with profits so high, myth promoters need you to make that assumption and hope you ignore those numbers. How many joules? They are shunt mode devices. They become conductors only during a transient - shunting a transient to all other wires. IOW transient now has even more wires to find earth ground destructively via adjacent appliances. Yes, adjacent protectors have even contributed to damage of a powered off appliance. What is the shunt path to earth? Reread the Carswell story. That transient will seek any path to earth. Give it a better, non-destructive path; no damage. That is what 'whole house' protectors and lightning rods accomplish because they provide a shorter path to earth. Nothing absorbed by protector or lightning rod. Effective protectors are best located farther from an appliance and as close to earth ground as is possible ... to shunt to earth. But again. Show me the numbers. Do you really believe a protector rated for but hundreds of joules will absorb thousands or millions of joules? There is no stopping or blocking of lightning as plug-in protector manufacturers hope you believe. Lightning damage is made irrelevant by installing a so inexpensive and properly sized 'whole house' protector on AC mains where that wire enters the building AND earthed to same electrode used by telephone and cable TV. Effective protectors are found in Lowes, Home Depot, and electrical supply houses using responsible brand names such as Intermatic, Siemens, Cutler-Hammer, Leviton, Square D, and GE. Effective protector for a typically most destructive lightning path costs about $1 per protected appliance. That protector also does not stop or absorb anything. A protector is only as effective as its earth ground. Effective protectors make a short and temporary connection to earth. Cheap power strips include those $150 Monster Cable products sold in Circuit City. How do you know they are cheap? Where is the dedicated earthing wire? No earth ground means no effective protection. |
![]() somewhere, in some safety bulletin somewhere, or maybe in the soaring magazine, is a truly FRIGHTENING account by Ken Sorenson when his plane (while flying) was struck by lightening.....glass and carbon, but you would be amazed. Ken was flying in a contest at Moriarty when it happened. He was able to land safely, after the cockpit exploded from the pressure wave.... I don't think anyone wants to "experiment" like that! Micki and Charlie-Lite |
w_tom wrote:
Michael Ash wrote: To the extent that the surge protector is able, yes. However, the cheap power strip surge protectors that people often have are unlikely to absorb a lighting strike. If this is your goal, make sure you purchase one that says it can handle it. ... Show me a surge protector with numbers that can 'absorb' or therefore eliiminate surges? Myth purveyors - those who never looked inside nor read a manufacturer datasheet - believe a surge protector somehow stops or absorbs what three miles of sky could not. An appliance connects directly to AC mains when plugged into a power strip protector. What is 'in series' to absorb those joules? Nothing. There is no electrical dam inside that power strip protector. Absorbing is not a protector function. But with profits so high, myth promoters need you to make that assumption and hope you ignore those numbers. How many joules? "Says it can handle it" is more than technical specs. A good attached equipment guarantee is the best way to say that it can handle a strike. This gives the manufacturer a good financial incentive to build their equipment well, and if they fail then they'll pay you for the equipment lost. Of course they won't recover lost data, but that's why you should make backups anyway. -- Michael Ash Rogue Amoeba Software |
Guarantee is obviously so chock full of exemptions as to only convince
the naive. Plug-in protectors do not claim to provide protection. It provides protection from a typically non-destructive transient. Then phrase the claim so that naive will assume that is protection from all types of surges. Same half-truth word games got so many to believe Saddam had WMDs. That plug-in protector does not claim to handle anything. Have doubts? Then put up their numerical specifications for each type of transient. Little hint. No such numerical claims exist. But then tobacco companies also successfully promoted claims in 1950s and 1960s that smoking provided better health. Yes, many also believed those myths. Hardware protectors that are effective are those that have that dedicated earthing wire. Effective solutions also costs tens of times less money. Plug-in protectors avoid discussion about earthing to sell grossly profitable and often grossly undersized protectors. They are good at getting others to strongly endorse myths - as demonstrated in this thread. Where are the numbers? Not provided because so many know only using subjective reasoning. So where are numerical specs that "says it can handle it"? Numbers don't exist for same reason an American president could proclaim Saddam had WMDs. No numbers - just subjective claims. Sufficient to have many promote myths rather than ask some embarrassing questions. Home protection including appliances has always been about earthing - as even Ben Franklin demonstrated in 1752. Michael Ash wrote: "Says it can handle it" is more than technical specs. A good attached equipment guarantee is the best way to say that it can handle a strike. This gives the manufacturer a good financial incentive to build their equipment well, and if they fail then they'll pay you for the equipment lost. Of course they won't recover lost data, but that's why you should make backups anyway. |
![]() On Nov 24, 6:19 pm, "w_tom" wrote: That plug-in protector does not claim to handle anything. Humor for the day. Have doubts? Then put up their numerical specifications for each type of transient. Little hint. No such numerical claims exist. A bs argument. You have never provided a link to any site that has the specs you say are required. If you could look at the nice pictures in the IEEE guide you could see power wires have MOVs H-N, H-G, N-G - covering all modes. In addition, common mode surges (H & N lift away from G) coming in on the power line are converted to transverse mode surges (H lifts away from N & G) by the N-G bond in US services. Hardware protectors that are effective are those that have that dedicated earthing wire. Your religious views on earthing are not shared by the IEEE or NIST. Plainly described in the IEEE guide - protection is by clamping, not earthing. They are good at getting others to strongly endorse myths - as demonstrated in this thread. Where are the numbers? Not provided because so many know only using subjective reasoning. I have provided links from the IEEE and NIST that say plug-in surge suppressors are effective. You have provided your myths and subjective reasoning. -- bud-- |
Check this guy out (click view profile in Google groups)!
He keeps on posting the same answers in different group discussions that have to do with lightning strikes. Amateur lightning enthusiast? Industry advocate? Surge protector vendor? Who knows... bud-- wrote: On Nov 24, 6:19 pm, "w_tom" wrote: That plug-in protector does not claim to handle anything. Humor for the day. Have doubts? Then put up their numerical specifications for each type of transient. Little hint. No such numerical claims exist. A bs argument. You have never provided a link to any site that has the specs you say are required. If you could look at the nice pictures in the IEEE guide you could see power wires have MOVs H-N, H-G, N-G - covering all modes. In addition, common mode surges (H & N lift away from G) coming in on the power line are converted to transverse mode surges (H lifts away from N & G) by the N-G bond in US services. Hardware protectors that are effective are those that have that dedicated earthing wire. Your religious views on earthing are not shared by the IEEE or NIST. Plainly described in the IEEE guide - protection is by clamping, not earthing. They are good at getting others to strongly endorse myths - as demonstrated in this thread. Where are the numbers? Not provided because so many know only using subjective reasoning. I have provided links from the IEEE and NIST that say plug-in surge suppressors are effective. You have provided your myths and subjective reasoning. -- bud-- |
SSA and IRS | Pete Reinhart | Soaring | 12 | October 12th 06 07:59 PM |
SSA in Crisis: Can It Heal Itself? [LONG] | [email protected] | Soaring | 45 | October 5th 06 04:15 PM |
"For military, 'Lightning' strikes again" | Mike | Naval Aviation | 0 | September 18th 06 03:17 PM |
AOPA Truth Squad | skylunelives | Piloting | 29 | January 13th 06 04:42 AM |
OUCH! Lightning hits airplane......... | Aardvark | Piloting | 4 | February 8th 04 04:46 PM |
