Garmin 530 WAAS upgrade - what's involved?
Old November 23rd 06, 11:03 PM posted to rec.aviation.ifr
Ron Natalie
Default Garmin 530 WAAS upgrade - what's involved?
John R. Copeland wrote:
Antenna replaced? If it's broken, maybe.
Nothing in the upgrade itself would require that.
And if the cable works OK before the upgrade, it'll work OK afterward.
While the WAAS satellites use the same (L1) frequencies as the
others..rumor has it that the existing antennas Garmin sold with
the 530/430 have a hard time seeing low enough on the horizon to
meet the C146a specs.
Old November 24th 06, 12:30 AM posted to rec.aviation.ifr
Ron Lee
I find that hard to believe. Do you know the elevation angle
requirement? I will check how low it picks up soon.
Ron Lee
Old November 28th 06, 10:31 PM posted to rec.aviation.ifr
Glasair
It's true. I was at the AOPA convention at Palm Springs and talked
with the Garmin rep. The antenna is replaced to upgrade to WAAS and
included in the $1500 price. I have a homebuilt Glasair so replacing
the antenna won't be any problem or added shop expense since I do it
myself. Of course it will be convenient if it has the same footprint
as the old one.
When the first announced their much delayed WAAS upgrade program, you
had to pre-sign-up with a shop to get the $1500 price. But now it
seems they are just giving it to everyone.
Ron Lee
Old November 29th 06, 01:35 AM posted to rec.aviation.ifr
Ron Lee
I called Garmin about this last week and that was what I was told.
Ron Lee
Old November 29th 06, 02:11 AM posted to rec.aviation.ifr
Roy N5804F
What did Garmin tell you Ron ?
Roy
"Ron Lee" wrote in message
Ron Lee
Old November 29th 06, 05:45 PM posted to rec.aviation.ifr
Ron Lee
Roy
That the $1500 price is independent of having to be registered for the
upgrade last year. If you registered....$1500. If you did not....
$1500
Ron Lee
Old December 1st 06, 01:47 AM posted to rec.aviation.ifr
Peter R.
$1500
Maybe those of us who registered will get a free coffee mug or something.
Peter
Old November 29th 06, 12:40 PM posted to rec.aviation.ifr
Ron Natalie
Garmin is still offering the 1500 price I believe. The list price of
the -W version of the units by the way is exactly $1500 higher than
the non-W version as well.
Old November 29th 06, 04:11 PM posted to rec.aviation.ifr
Jon
Ron,
As you know, the MOPS has gone through several revs, but my copy of
DO-229A specifies 10.-deg. They've released 229D and I believe it
hadn't changed between C and D, but the mask angle is now 5.-deg.
As an aside, remember the issues with some of the early 129 boxes? As I
recall, there was no specific requirement for any particular mask
angle. 7.5-deg (then 5.0-deg in a later version) was the recommended
value. Basically, as long as the rcvr. manuf. could prove that
Integrity was being maintained, it didn't really matter what mask angle
was chosen...
But it did/does. Effects such as local multipath come into play at the
low angles.
When examining the Availbility/Integrity tradespace, those on the
conservative side would rather take the Availability hit in order to
maintain Integrity. Conservative in this context meaning 'safe' as
opposed to Right Wing
Ron Lee
Regards,
Jon
Garmin 530 WAAS? Al G Instrument Flight Rules 53 November 21st 06 11:30 PM
Garmin 430/530 WAAS upgrade reminder Nov 15 Paul kgyy Owning 18 November 22nd 05 07:22 PM
Garmin 430/530 WAAS upgrade reminder Nov 15 Paul kgyy Instrument Flight Rules 18 November 22nd 05 07:22 PM
More info on GNS 430/530 WAAS upgrade PPT33R Instrument Flight Rules 33 June 24th 05 02:21 PM
WAAS and Garmin 430/530 DoodyButch Owning 23 October 13th 03 04:06 AM
