Springfield, IL too.
I haven't been everywhere. At least a 1/4 century ago, during the Cold War, the FAA began to build new, secure buildings for all their offices and towers, moving them into buildings the feds controlled, rather than being in terminal buildings controlled by local airport boards. All these new buildings have the same sort of security in the landscaping, access and structure. "Judah" wrote in message .. . | "Jim Macklin" wrote in news:kD89h.31 | : | | Wichita, Kansas tower was removed from terminal building and | located in a secure building with no place to hide a bomb. | | Topeka, Kansas, the tower was moved into the center of the | airport behind the fences. | | All over the country, towers are being relocated, still on | the airport, but in a secure new building. | | This doesn't sound like all over the country. This sounds like all over | Kansas. | | I've seen The Wizard of Oz, and maybe some terrorists have too, but I gotta | tell you that I don't think Kansas is all that high on the International | Terrorist Target list... | | I can't speak for Militiamen in or near Oklahoma, tho. |
![]() Jim Macklin wrote: Springfield, IL too. I haven't been everywhere. At least a 1/4 century ago, during the Cold War, the FAA began to build new, secure buildings for all their offices and towers, moving them into buildings the feds controlled, rather than being in terminal buildings controlled by local airport boards. All these new buildings have the same sort of security in the landscaping, access and structure. See Denver. The controllers have to go thru the same TSA screening that passengers do to get to work. |
That will change with the new tower, when is it scheduled to
begin construction? "Newps" wrote in message . .. | | | Jim Macklin wrote: | | Springfield, IL too. | | I haven't been everywhere. | | At least a 1/4 century ago, during the Cold War, the FAA | began to build new, secure buildings for all their offices | and towers, moving them into buildings the feds controlled, | rather than being in terminal buildings controlled by local | airport boards. All these new buildings have the same sort | of security in the landscaping, access and structure. | | | | See Denver. The controllers have to go thru the same TSA screening that | passengers do to get to work. |
CITY AND COUNTY OF DENVER
DEPARTMENT OF AVIATION NOTICE OF INVITATION FOR BIDS CONTRACT NO. CE 64023 Parking Structure Mod 4 West Denver, Colorado January 30, 2006 Sealed bids for Contract No. CE 64023, Parking Structure Mod 4 West will be received no later than 2:00 PM, March 23, 2006 (ADDENDUM #5) Local Time at the Elrey Jeppesen Terminal Building, Denver International Airport, 8400 Peña Blvd., Denver, Colorado 80249-6235, Level 6, northwest corner of the inner core and south of the Denver Health Medical Center in the room marked PRESS INTERVIEW ROOM. Bids must be time stamped no later than 2:00 PM, March 23, 2006 (ADDENDUM #5), immediately after which a public bid opening will commence. Any bids to be submitted more than one hour prior to Bid Opening shall be submitted at the office of Technical Services, attention Nathan Jones, Room 8810, Airport Office Building (AOB), Denver International Airport, 8500 Peña Blvd., Denver, CO 80249-6340. GENERAL STATEMENT OF WORK: This project will construct a parking structure for approximately 1667 cars in five floors. The precast structure will be located on the west side of the terminal, south of the existing parking structures and terminal. The structure will be precast concrete with field applied concrete deck topping. The project will also involve the construction of a retaining wall to support the level 4 roadway. The Level 2 access roadway will be realigned to expand the building site. The surface parking lots will be reconfigured for the Level 2 access road work. The T-1 roadway north of the porject site will be lower to accommodate bus and truck trafffic. The existing parking module 3 west will be modified for the attachment of vehicle/pedestrian bridges between the existing parking modules and the module 4 west. DOCUMENTS AVAILABLE: Contract documents, including specifications, in the form of CDs, will be available for purchase at the Technical Services Office, Department of Aviation, Room 8810 Airport Office Building, 8500 Peña Boulevard, Denver, Colorado 80249, at a cost of $1,250.00 per set (no refund) beginning January 31, 2006. You will be receiving two CDs with two separate checks necessary and payable to Airport Revenue Fund in the amounts of $250.00 and $1000.00. The $1000 check is refundable as specified in the Sensitive Security Information section below. SENSITIVE SECURITY INFORMATION (SSI): The Code of Federal Regulations (CFR) 49 Part 1520 describes the handling and protection of SSI and, among other things, the release of information that the Transportation Secuirty Administration(TSA) has determined may reveal a systemic vulnerability of the aviation system or a vulnerability of aviation facilities to attack. A protion if this project has been designated as containing Sensitive Security Information(SSI). Therefore with the SSI designation, special documentation release, control and tracking procedures will be in effect. 1) Documents Available: Contract documents, including specifications, will be available at the Technical Services Office, Department of Aviation, Room 8810 Airport Office Building, 8500 Peña Boulevard, Denver, Colorado 80249 on January 31, 2006. 2) A Security Deposit for each serialized compact disc containing the SSI information in the amount of One Thousand Dollars and no cents ($1,000.00) (refundable) is required. Payment will be accepted in the form of a check made payable to: Airport Revenue Fund. 3) A person of responsibility within the Bidder's organization must pick up the documents and be prepared to sign, in the presence of a Denver International Airport representative, a confidentiality and non-disclosure Agreement. A copy of this agreement can be obtained from the following website: http://www.flydenver.com/biz/bizops/biz_forms.asp. Documents will not be released to courier services, company delivery drivers, messengers, etc. Documents will only be released to a person having the designation of Project Manager, Superintendent or higher in the Bidder's organization. The Project Manager, Superintendent, President, Owner or etc must have a business card with the organizational position title clearly indicated. Documents will not be released unless these conditions are met. 4) The Bidder must be prepared to control and track the release of the bid documents to subcontractors, suppliers, material men, etc according to the guidelines outlined in the Department of Aviation Standard Policies and Procedures No. 6003. A copy of the Department of Aviation Standard Policies and Procedures No. 6003 can be obtained from the following website: http://www.flydenver.com/biz/bizops/biz_forms.asp. 5) The Security Deposit will be refunded to the Bidder upon return of the serialized compact disc along with the SSI RETURN OR DESTRUCTION COMPLIANCE FORM contained in the Department of Aviation Standard Policies and Procedures No. 6003. PREQUALIFICATION: Each bidder must be pre-qualified in the category of CE-5, Structural Contractor, and must request special permission to be prequalified on a project-by-project basis for contracts over Twenty-five Million Dollars ($25,000,000.00) in accordance with the City's Rules and Regulations Governing Prequalification of Contractors. Each bidder must have submitted a prequalification application and request special permission a minimum of seven (7) calendar days prior to the bid opening date. Applications must be returned to the Department of Public Works, Wastewater Management Division, Prequalification Section, 2000 West 3rd Avenue, Denver, CO 80223. To view the Rules and Regulations and to obtain a prequalification application, please visit our website at http://www.denvergov.org/admin/templ...ification2.pdf, or call 303.446.3466 for prequalification information ONLY. PRE-BID CONFERENCE AND INSPECTION: All bidders are invited to a pre-bid conference at 10:00 AM, February 7, 2006, at the Elrey Jeppesen Terminal Building, Denver International Airport, 8400 Peña Blvd., Denver, CO 80249-6235, Level 6, northwest corner of the inner core and south of the Denver Health Medical Clinic in the room marked PRESS INTERVIEW ROOM. A site visit will be conducted immediately following the Pre-Bid Conference. SMALL BUSINESS ENTERPRISE PARTICIPATION: Construction, reconstruction and remodeling contracts made and entered into by the City and County of Denver are subject to Article VII, Division 1 of Chapter 28 of the Denver Revised Municipal Code, (D.R.M.C.) and all Small Business Enterprise Utilization and Equal Employment Opportunity Rules and Regulations adopted by the Director of the Small Business Opportunity Division (formerly known as the Mayor's Office of Contract Compliance). Article VII, Division 1 of Chapter 28 of the D.R.M.C. directs the Director of the Small Business Opportunity Division to establish a project goal for expenditures on construction, reconstruction and remodeling work contracted by the City and County of Denver. The specific goal for this project is 12% Small Business Enterprise (SBE) Participation. Project goals must be met with certified participants as set forth in Section 28-206, D.R.M.C. or through the demonstration of sufficient good faith effort under Section 28-208, D.R.M.C. For compliance with good faith effort requirements under Section 28-208 (b) (2) (a) the SBE percentage solicitation level required for this project is 50%. The Director of the Small Business Opportunity Division urges all participants in City construction, reconstruction and remodeling projects to assist in achieving these goals. NON DISCRIMINATION IN THE AWARD OF CITY CONTRACTS: It is the policy of the City and County of Denver to prohibit discrimination in the award of construction contracts and subcontracts for public improvements. Further, the City and County of Denver encourages contractors to utilize minority and women owned businesses and to divide the construction work into economically feasible units or segments to allow the most opportunity for subcontracting. MISCELLANEOUS: As its best interests may appear, the City and County of Denver reserves the right to reject any or all bids and to waive informalities in bids. The work under the Contract is subject to minimum wage rates established by the City and County of Denver Career Service Board. Vicki Braunagel & Turner West Co-Managers of Aviation Publication Dates: January 30, 2006, January 31, 2006, February 1, 2006 "Jim Macklin" wrote in message ... | That will change with the new tower, when is it scheduled to | begin construction? | | | | "Newps" wrote in message | . .. || || || Jim Macklin wrote: || || Springfield, IL too. || || I haven't been everywhere. || || At least a 1/4 century ago, during the Cold War, the FAA || began to build new, secure buildings for all their | offices || and towers, moving them into buildings the feds | controlled, || rather than being in terminal buildings controlled by | local || airport boards. All these new buildings have the same | sort || of security in the landscaping, access and structure. || || || || See Denver. The controllers have to go thru the same TSA | screening that || passengers do to get to work. | | |
![]() Jim Macklin wrote: CITY AND COUNTY OF DENVER DEPARTMENT OF AVIATION NOTICE OF INVITATION FOR BIDS If you knew anything about Denver you would know what's going on. The tower controllers have to park in a remote parking lot and take a bus and a tram to the terminal. Walk thru the terminal and go thru security to get to the entrance to the tower. It literally takes a half hour to get to work once you've parked your car at the airport. |
I guess they don't want the controllers bringing their car
bombs. "Newps" wrote in message . .. | | | Jim Macklin wrote: | | CITY AND COUNTY OF DENVER | | | DEPARTMENT OF AVIATION | | | NOTICE OF INVITATION FOR BIDS | | If you knew anything about Denver you would know what's going on. The | tower controllers have to park in a remote parking lot and take a bus | and a tram to the terminal. Walk thru the terminal and go thru security | to get to the entrance to the tower. It literally takes a half hour to | get to work once you've parked your car at the airport. | |
"Documents will only be released to
a person having the designation of Project Manager, Superintendent or higher in the Bidder's organization. The Project Manager, Superintendent, President, Owner or etc must have a business card with the organizational position title clearly indicated. " Dumb requirement. Can you say "Laser Printer"? |
![]() Jim Macklin wrote: That will change with the new tower, when is it scheduled to begin construction? That is the new tower. |
Then when do they build the new terminal?
"Newps" wrote in message . .. | | | Jim Macklin wrote: | That will change with the new tower, when is it scheduled to | begin construction? | | That is the new tower. |
Jim Macklin wrote:
That will change with the new tower, when is it scheduled to begin construction? There is no new tower contemplated at DEN, to my knowledge. |
RUTHLESSLY KILL TERRORIST PSYCHOPATHS BUSH, CHENEY, RUMSFELD, Robert Mueller, Keith Alexander, Mathew Hayden and John Negroponte | AmerGovtPsychopathsExposer | Home Built | 17 | November 20th 06 12:01 AM |
RUTHLESSLY KILL TERRORIST PSYCHOPATHS BUSH, CHENEY, RUMSFELD, Robert Mueller, Keith Alexander, Mathew Hayden and John Negroponte | AmerGovtPsychopathsExposer | Owning | 0 | November 17th 06 11:41 PM |
Using free online approach plates | mvgossman | Instrument Flight Rules | 22 | November 1st 06 12:24 AM |
legal to use home-printed IFR plates? | Marty Ross | Instrument Flight Rules | 29 | January 4th 06 05:25 PM |
Approach Plates on PDA (PIREP) | Stan Prevost | Instrument Flight Rules | 10 | December 18th 04 04:21 AM |
