Pipistrel Kit Aircraft now FAA 51% Accepted
Old November 24th 06, 11:11 PM posted to rec.aviation.soaring,rec.aviation.homebuilt
Opie
Default Pipistrel Kit Aircraft now FAA 51% Accepted
On Fri, 24 Nov 2006 04:36:22 GMT, USER wrote:
Ummm, well, no. Aircraft still have to go through the certification
process.
The 51%-certification is a nice-to-have, but in itself doesn't guarantee
the FAA
will certify the airplane as Experimental Amateur-Built. It's still
possible
for the FAA to reject certification of an individual aircraft.
C'mon Ron. You make it sound like the FAA guys are an officious bunch of
self righteous bureaucrats!
Old November 24th 06, 11:51 PM posted to rec.aviation.soaring,rec.aviation.homebuilt
process.
the FAA
possible
For the next (at least) two years, they'll be officious self-lefteous
bureaucrats. :-)
Old November 25th 06, 03:33 AM posted to rec.aviation.soaring,rec.aviation.homebuilt
Brad
Really? so the whole staff gets flipped?
Brad
BTW.......when did you last hear of a kit that wasn't accepted as
amateur built by the FAA?
process.
the FAA
possible
bureaucrats. :-)
Old November 25th 06, 06:21 AM posted to rec.aviation.soaring,rec.aviation.homebuilt
Christen Eagle is the only one I know about, but that was way back in the dawn
o' time. Otherwise, companies are not likely to advertise that they flunked. I
suspect the FAA is usually specific enough where the company knows what they
have to do for their plane to pass. Many companies undoubtedly work with the
FAA as they develop the kit...for instance, I'm sure Van's worked it all out
with the Feds before they started having the contractor partially complete kits
for delivery as quick-build kits.
The big thing, of course, is that the type's inclusion on the approved 51% list
is *not* a pre-requisite to a homebuilt getting certified. The only thing it
does is offer some protection against capricious FSDO decisions.
Old November 25th 06, 06:29 AM posted to rec.aviation.soaring,rec.aviation.homebuilt
Brad
They could still get a Experimental-Exhibition tho right? Not quite the
freedom a Amateur built COFA gives, but can still fly it.
The 2 sailplane kits I built and had inspected went thru the inspection
without any hassles. I was quite worried about the first kit; as it was
the first I ever built, and seemed to me to be quite complete when it
came out of the box. But, as you know, that manufacturer-builder check
list can be quite a handy tool!
I also want to give KUDO's to the Seattle MIDO, the two gentlemen I
worked with were quite professional, and very helpful.........hopefully
the next aircraft I build will be inspected by one of these fellows.
Cheers,
Brad
Old November 26th 06, 12:20 AM posted to rec.aviation.soaring,rec.aviation.homebuilt
Juan Jimenez[_1_]
"Brad" wrote in message
That depends where they stick you in the Exp/Exh structure. Some of the
subcategories are more restrictive than others.
Posted via a free Usenet account from http://www.teranews.com
Old November 25th 06, 01:34 PM posted to rec.aviation.soaring,rec.aviation.homebuilt
Ron Natalie
bureaucrats. :-)
Nope, congress doesn't appoint those bureaucrats, the president (one
child left behind) does.
Old November 26th 06, 12:18 AM posted to rec.aviation.soaring,rec.aviation.homebuilt
Juan Jimenez[_1_]
"Opie" wrote in message
process.
the FAA
possible
What else do they call themselves?
Old November 26th 06, 01:02 AM posted to rec.aviation.soaring,rec.aviation.homebuilt
Eric Greenwell
The ones I've worked with called themselves things like "Bob",
"Charlie", and "Sue", while they went out of their way to certify my
glider, set up our wave windows, and get me the waiver I requested.
"Transponders in Sailplanes" on the Soaring Safety Foundation website
www.soaringsafety.org/prevention/articles.html
"A Guide to Self-launching Sailplane Operation" at www.motorglider.org
Old November 26th 06, 02:50 PM posted to rec.aviation.soaring,rec.aviation.homebuilt
Juan Jimenez[_1_]
news:BI5ah.13303$_x3.11069@trndny02...
The ones I've worked with called themselves things like "Bob", "Charlie",
and "Sue", while they went out of their way to certify my glider, set up
Lucky you, you ran into the minority...
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 07:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
