FADEC = complex
Old November 24th 06, 11:30 PM posted to rec.aviation.piloting
Morgans[_2_]
Default FADEC = complex
Yes, backup battery or alternator. The latter is a better choice I'd
think, since a battery only gives about an hour. If it's belt-driven
though, it seems risky to me.
You would get a dedicated battery for the FADEC, the ones I've seen are
smaller than a motorcycle battery and this would easily outlast your fuel
supply at any power setting that keeps you aloft. It draws very little
currrent.
In all fairness, you have to consider the drain of current to run a fuel pump,
if it is a low wing that has an electric fuel pump that runs all the time, and
also any other absolutely essential drains on the emergency battery. Still, it
would have plenty of endurance to get down for a precautionary landing, if
things were going wrong in a major way, like that.
The exception might be on a ferry flight accross the Atlantic, or something. A
"wise" pilot with a plane that had systems that had to have electricity to keep
the fan going would pack an extra battery along, and a way to connect it to the
emergency buss.
Are you reading this NW Pilot? g Seriously.
Jim in NC
Is this a Complex Plane? [email protected] Piloting 12 December 7th 05 03:19 AM
Commercial rating: complex aircraft required aircraft for practical test? Marc J. Zeitlin Piloting 22 November 24th 05 04:11 AM
Complex / High Performance / Low Performance R.T. Owning 22 July 6th 04 08:04 AM
Experience transitioning from C-172 to complex aircraft as potential first owned aircraft? Jack Allison Owning 12 June 14th 04 08:01 PM
Complex Aircraft Question Chris General Aviation 5 October 18th 03 04:40 AM
