Mxsmanic wrote: Ron Garret writes: Just ask ATC for a clearance. If they aren't too busy they will just give you one. If they are busy you will need to contact flight service by radio to file an IFR flight plan, then get back in touch with ATC to activate it. Do I have to work out a whole list of waypoints and stuff to give to them? Nope, they (actually their computer) will figure that out for you. Can I just ask for IFR clearance to my destination (or to some specific point where I expect to find VMC again), without specifying waypoints or altitudes? Yep. Usually I have a VFR flight plan which in fact does include waypoints, because I've worked something out with a chart beforehand, but not always. If I've filed a VFR flight plan that mentions way points, can I refer to it when asking ATC for IFR clearance? Nope, ATC has no access to VFR flight plans. In other words, just convert part of the VFR flight plan to an IFR flight plan? Nope. Landing somewhere first is also an option. Yes, but if I can't see anything out the window, this is not without risk (mainly from conflicting traffic, even if I have instruments that allow me to land in poor visibility). If you can't see anything out the window and you are VFR then you're already screwed. Time to declare an emergency. Yes, you can switch from IFR to VFR at any time by simply telling ATC that you are "canceling IFR." Do I get in trouble if I file VFR, encounter IMC, and have to ask for IFR clearance as a result? Not unless you actually enter IMC without an IFR clearance. I know I'm not supposed to take off in IMC, but it seems like on a trip of substantial length, it's hard to guarantee that it will all be fair weather, especially in some regions of the world (the area around Seattle seems very pretty, although it also seems that one can rarely _see_ the area around Seattle). That's why having a plan B is always advisable. Why? People fly IFR in VFR conditions all the time. I recall reading that the vast majority of private pilots (80%?) are not instrument rated, and that many accidents involving small planes occur when non-IR pilots fly into IMC and become disoriented. So I assume that it's rare for the pilot of a small plane to fly IFR "unofficially" while under VFR. It sounds like a lot of them have no idea how to do it. I have no idea what you mean by 'flying IFR "unofficially"'. It's true that many people don't have instrument ratings. Those people have fewer options when flying cross-country. It's much better to be IFR the whole way if there's any chance of encountering instrument conditions anywhere on the flight. Because ... ? I'll leave that as an exercise for you to figure out. rg |
Ron Garret writes:
If you can't see anything out the window and you are VFR then you're already screwed. Time to declare an emergency. Well, if you are equipped for instrument flight and rated for it and there isn't too much traffic, I wouldn't call it an emergency, although you do need to get flight separation services or get back to VMC as quickly as possible. I have no idea what you mean by 'flying IFR "unofficially"'. Flying using instruments even though you haven't filed an instrument flight plan. For example, my habit of flying with a GPS or by following VORs rather than looking for landmarks out the window. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote: Ron Garret writes: If you can't see anything out the window and you are VFR then you're already screwed. Time to declare an emergency. Well, if you are equipped for instrument flight and rated for it and there isn't too much traffic, I wouldn't call it an emergency, Then you are missing something very fundamental: there is more to IFR flight than simply flying by reference to instruments. It is also flying according to a much more rigidly planned and stylized repertoire of routes and maneuvers designed to keep you from hitting not only other airplanes but also (and more importantly) terrain. That is why even instrument-rated pilots flying instrument-equipped planes die on a regular basis as a result of VFR flight into IMC. although you do need to get flight separation services or get back to VMC as quickly as possible. That takes time. How are you going to keep from hitting things in the meantime? I have no idea what you mean by 'flying IFR "unofficially"'. Flying using instruments even though you haven't filed an instrument flight plan. For example, my habit of flying with a GPS or by following VORs rather than looking for landmarks out the window. Flying using instruments is NOT the same thing as flying IFR. rg |
![]() "Ron Garret" wrote That takes time. How are you going to keep from hitting things in the meantime? His simulator will not hit anything, and if it does, the game will start over again. Ron, just tell him to go ask the simulator folks. They have all of the information he needs to know, for his game. -- Jim in NC |
Ron Garret writes:
Then you are missing something very fundamental: there is more to IFR flight than simply flying by reference to instruments. It is also flying according to a much more rigidly planned and stylized repertoire of routes and maneuvers designed to keep you from hitting not only other airplanes but also (and more importantly) terrain. That is why even instrument-rated pilots flying instrument-equipped planes die on a regular basis as a result of VFR flight into IMC. If you have the right instruments, and an instrument rating, and ATC to provide separation, why would it be dangerous? I know that most IFR flights are rigidly planned, but it appears that they don't have to be. You need to know where you are and where you are going, but you don't have to plan every detail in advance. That takes time. How are you going to keep from hitting things in the meantime? All it takes is a call to ATC. If you already know your instruments and you already have your navaids and what-not set up, you already know where you are and where you are going, irrespective of what you can see out the window. You just look out the window for separation and as an additional sanity check on your navigation, or just for sightseeing. If visibility drops, you're covered, except for separation--whence the call to ATC when you approach IMC. Flying using instruments is NOT the same thing as flying IFR. What are the differences? ATC provides separation and guidance for IFR flights, but besides that, what changes? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote: Ron Garret writes: Then you are missing something very fundamental: there is more to IFR flight than simply flying by reference to instruments. It is also flying according to a much more rigidly planned and stylized repertoire of routes and maneuvers designed to keep you from hitting not only other airplanes but also (and more importantly) terrain. That is why even instrument-rated pilots flying instrument-equipped planes die on a regular basis as a result of VFR flight into IMC. If you have the right instruments, and an instrument rating, and ATC to provide separation, why would it be dangerous? Because ATC only provides separation from other airplanes. It does not provide separation from terrain. Also, with VFR into IMC situations you often don't have contact with ATC. So you have to get out your chart, try to figure out where you are (not all planes have moving map GPS), find the right frequency, dial it in, call them up, wait for a response... and all the time you have to fly the plane without being able to see where you're going. It's not so easy in real life as it might appear in a sim. I know that most IFR flights are rigidly planned, but it appears that they don't have to be. You need to know where you are and where you are going, but you don't have to plan every detail in advance. And what will you do if your GPS fails? That takes time. How are you going to keep from hitting things in the meantime? All it takes is a call to ATC. No. ATC does not provide terrain separation. If you already know your instruments and you already have your navaids and what-not set up, you already know where you are and where you are going, irrespective of what you can see out the window. Those are all big IFs. You just look out the window for separation and as an additional sanity check on your navigation, or just for sightseeing. If visibility drops, you're covered, except for separation--whence the call to ATC when you approach IMC. Sure. But you keep switching the topic back and forth between "when you approach IMC" and when you are IN IMC. Those are two very different circumstances. Flying using instruments is NOT the same thing as flying IFR. What are the differences? ATC provides separation and guidance for IFR flights, but besides that, what changes? The major differences a 1) in IMC you cannot rely on your peripheral vision. This makes a much bigger difference than you might imagine (and you can't experience it in simulation unless you have a lot of monitors). 2) approach to landing must be done in a much more stylized and pre-planned way in order to avoid terrain that you can't see. 3) if you don't have a moving-map GPS you have to twiddle a lot of knobs in the right way at the right time, which adds to your workload. The combination of all three of these factors makes for a very different experience. rg |
Ron Garret writes:
Because ATC only provides separation from other airplanes. It does not provide separation from terrain. If you know your position and altitude, charts will provide you with separation from terrain. There are probably moving-map systems that will do the same, although I'm not personally familiar with them (it's certainly feasible to a large extent). Also, with VFR into IMC situations you often don't have contact with ATC. You call them when you see the clouds or fog coming. So you have to get out your chart, try to figure out where you are (not all planes have moving map GPS), find the right frequency, dial it in, call them up, wait for a response ... and all the time you have to fly the plane without being able to see where you're going. If I'm flying the plane, I'll already know where I am based on instruments, irrespective of weather conditions. I'm not going to start looking at the chart and instruments only as I approach the IMC. Additionally, I'll avoid aircraft that do not appear to have instrumentation adequate to make IFR flight safe and reliable (in addition to legal). It's not so easy in real life as it might appear in a sim. Maybe. How much of it have you done in a sim? I wouldn't call instrument flight in a sim easy--most sim pilots don't know how to do it. And what will you do if your GPS fails? Since I'll already know the nearest VORs and I'll be tuned to them, I can go with that. I often do, anyway, as it's sometimes easier than fooling with the GPS. However, if all radio navaids fail, I'm in a bit more of a quandry, as I have very little experience so far with dead reckoning. Fortunately, it's relatively unlikely that I would have a total failure of all navaids at the same time that I happen to get stuck in IMC. And, by definition, if you have no instruments, you cannot fly IFR. No. ATC does not provide terrain separation. I can provide terrain separation myself. In most cases I will already be thousands of feet above the highest terrain in the area, out of sheer prudence, and I have charts and navigational equipment to tell me where I am and how high the terrain below happens to be. I only need ATC for separation from other aircraft (TCAS helps in this respect, but I'm assuming I wouldn't have that onboard, and it's not 100% reliable). Hopefully I'll have a radar altimeter, too, although it's only useful in certain situations. Those are all big IFs. That depends on your personal policies as a pilot. If you routinely make use of instruments to verify your position, you'll already know where you are if you lose visual contact with the outside world. You'll just have to be a bit more careful since you won't be able to double-check anything visually. And you'll need ATC to help you stay clear of other aircraft. Sure. But you keep switching the topic back and forth between "when you approach IMC" and when you are IN IMC. Those are two very different circumstances. Visually, yes. But depending on how much you routinely use your instruments, it might not be that much different in other ways. I might well look for landmarks out the window in good weather. But that would not prevent me from keeping track of a VOR or two, and looking at the GPS display or EHSI occasionally to make sure that all information sources agree on my position. If I see unavoidable IMC approaching, I call ATC for separation services, and I watch my instruments more carefully. One of the things I like about aviation is that it _is_ possible to fly without any external visibility at all (excluding landing and take-off, which are special circumstances). All you need is a few instruments, a couple of charts, and knowledge of how to use them. I find it fascinating that I can fly for hours with nothing but fog out the window, then descend below the weather and see a runway directly ahead of me, _exactly where the instruments and charts promised it would be_. It is very reassuring. It proves that if you follow the rules, and you are careful and diligent, and you know your procedures, you can always find your way home. Ultimately the only thing you have to worry about is other aircraft ... and that's where ATC comes into play. The major differences a 1) in IMC you cannot rely on your peripheral vision. If you are flying with instruments, you're not relying on peripheral vision, either. If you are flying with instruments, visual contact with the outside world is only one of several sources of information. It helps you to make sure that all is well, but if it abruptly becomes unavailable, you still know exactly where you are, if you know how to use your instruments. In anything other than the severest of clear weather all the way to the horizon, in the daytime, I'd be nervous relying on visual cues alone. If it were required for a test, I could do it, but left to my own devices, I'd look for confirmation from instruments and charts. Mountains and rivers tend to look the same after a while; I want to know if that twisty little river ahead really is the one that I think it is before I try to follow it home. This makes a much bigger difference than you might imagine (and you can't experience it in simulation unless you have a lot of monitors). I can "turn my head" in a sim, but it is true that visibilty is in most ways much more limited than in real life (although I can look directly backwards in the sim, whereas the aircraft would block much of my view in real life). 2) approach to landing must be done in a much more stylized and pre-planned way in order to avoid terrain that you can't see. That's how I land already. I consider a purely visual landing to be sloppy. I always check the instruments to see if I'm really at the altitude I appear to be at, if I'm really aligned as I should be, and so on. Even in perfect weather, I may still be tuned to the ILS for a straight-in approach, just to make sure that my glide path and alignment agree with the instruments. Additionally, I always try to navigate in a way and plan ahead in a way that allows me a straight-in approach. I'll fly a pattern if I have to, but otherwise straight in is preferable. Even for flying a pattern, I'll check instruments. 3) if you don't have a moving-map GPS you have to twiddle a lot of knobs in the right way at the right time, which adds to your workload. Yes, but planning ahead seems to help a little. It makes me nervous if I don't have at least a VOR or beacon or something that I can use to double-check that I really am where I think I am, no matter how familiar the view out the window might be. I like to be sure that the little airstrip I see up ahead really is the airstrip I'm looking for. I'm especially vigilant about this because I understand that airports are hard to recognize in real life, even though they are already hard to recognize in the sim. The combination of all three of these factors makes for a very different experience. If one flies purely visually and is suddenly thrust into a situation where visual information is unavailable, I can see how panic would set in. But if one is already scanning instruments with an awareness of one's position derived therefrom, a sudden transition into low visibility should be far less stressful. Some pilots are willing to fly aircraft that don't provide the minimum necessary for instrument flight, but I don't think I'd be very sanguine about trying that myself, no matter how great the weather might seem. I spend a lot of time thinking "what if?" -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() "Mxsmanic" wrote I can provide terrain separation myself. You always have separation from terrain, as long as the legs on your desk don't collapse. You fly a computer, man. Get over yourself. -- Jim in NC |
Mxsmanic wrote: The major differences a 1) in IMC you cannot rely on your peripheral vision. If you are flying with instruments, you're not relying on peripheral vision, either. You'd be surprised. This makes a much bigger difference than you might imagine (and you can't experience it in simulation unless you have a lot of monitors). I can "turn my head" in a sim Not the same thing at all I'm afraid. Yes, but planning ahead seems to help a little. Indeed. The combination of all three of these factors makes for a very different experience. If one flies purely visually and is suddenly thrust into a situation where visual information is unavailable, I can see how panic would set in. But if one is already scanning instruments with an awareness of one's position derived therefrom, a sudden transition into low visibility should be far less stressful. Less stressful to be sure. But you'd be amazed how different it can be if you really can't see out the window and your (real not simulated) life is on the line. Some pilots are willing to fly aircraft that don't provide the minimum necessary for instrument flight, but I don't think I'd be very sanguine about trying that myself, no matter how great the weather might seem. I spend a lot of time thinking "what if?" Southern California in the summer is pretty safe for VFR flight. rg |
Disclaimer -- I am still a student pilot, so take what I say with a
grain of salt. :-) Mxsmanic writes: I can provide terrain separation myself. In most cases I will already be thousands of feet above the highest terrain in the area, out of sheer prudence, and I have charts and navigational equipment to tell me where I am and how high the terrain below happens to be. I only need ATC for separation from other aircraft (TCAS helps in this respect, but I'm assuming I wouldn't have that onboard, and it's not 100% reliable). Hopefully I'll have a radar altimeter, too, although it's only useful in certain situations. AFAIK, the majority of GA planes have neither radar altimeters nor TCAS. Those are much more common on jets. Most jets are flown commercially, and commercial flights amost always fly IFR from takeoff to landing, no matter what the weather. Your assumptions may be a little off... In anything other than the severest of clear weather all the way to the horizon, in the daytime, I'd be nervous relying on visual cues alone. If it were required for a test, I could do it, but left to my own devices, I'd look for confirmation from instruments and charts. Mountains and rivers tend to look the same after a while; I want to know if that twisty little river ahead really is the one that I think it is before I try to follow it home. Quick confirmation is okay. But if you are flying either IFR or VFR in VMC, you probably don't want to keep your head in the cockpit too much -- your primary responsibility is to look outside to avoid hitting other planes. Even in the best weather spotting other planes is hard, if the weather is less than optimal you need to be looking even harder! That is no time to be focusing on your instruments -- you can only do that safely if you have ATC keeping the other planes away from you -- and you can only assume ATC is able to do that if you either flying in IMC (and so can assume no VFR traffic) or are in airspace where ATC provides separation for all planes (not just IFR traffic), such as class A or B airspace. Some pilots are willing to fly aircraft that don't provide the minimum necessary for instrument flight, but I don't think I'd be very sanguine about trying that myself, no matter how great the weather might seem. I spend a lot of time thinking "what if?" Bad or marginal weather is usually pretty easy to spot from a distance. If you are flying a plane without an IFR rating, or without IFR equipment, the trick is to just avoid the bad weather. Is it foggy? Don't fly. About to rain, and may rain hard enough to obstruct vision? Don't fly. Storm front between you and your destination? Turn around or land. If you are conservative in your flying decisions, the dreaded "visual flight into IMC" will never happen. The trick is to have the judgement and willpower to remain conservative, and to keep your margin of safety and resist the urge to fly... (And if you want to fly more often in worse weather, first acquire the necessary training and a better plane.... Of course, this can cost big $$$...) Chris |
