Compass swinging?
Old November 26th 06, 02:18 AM posted to rec.aviation.owning
Stan Prevost
Default Compass swinging?
"Matt Barrow" wrote in message
Also, this thing is much less prone to errors:
http://www.aircraftspruce.com/catalo...rd_compass.php
and http://www.pai700.com/index.html
Less prone to what kind of errors?
Old November 26th 06, 03:14 AM posted to rec.aviation.owning
Matt Barrow
"Stan Prevost" wrote in message
Turning, acceleration, deceleration...
Old November 26th 06, 03:49 AM posted to rec.aviation.owning
Stan Prevost
The ones I have flown with, and installed in my airplane, have those same
errors as the whiskey compass, because they work on the same principle, they
are just geared to indicate direction with a vertical card. They do seem to
be more stable in turbulence. Well, actually I haven't tested acceleration
and deceleration, but turning errors seem to be the same.
The main advantage I find in a vertical card compass is the more natural
presentation they give, it doesn't seem backward like the whiskey compass,
and matches the presenation on other directional instruments.
Old November 26th 06, 04:17 AM posted to rec.aviation.owning
M[_1_]
RST Engineering wrote:
C'mon Roy, you've been around airplanes long enough to know the real
answer -- "Why that compass card has been in the airplane since I bought
it."
Same reaction here. Doesn't everyone here have at least two GPS's
onboard that show a ground track bearing 10 times better than the
compass? No lecture about the difference between heading and ground
track please. We're all adults here.
In real life, ATC just wants you to fly from point A to point B in a
straight line. If you're being vectored in anything slower than 250
knots, ATC can't care less if you're flying a 180 degree track bearing
instead of holding a wobbling 185 heading in a 15 knots bumpy
crosswind. They eyeball your radar track after drinking half cup of
coffee, and turn you 10 degrees if need to.
Old November 26th 06, 09:47 AM posted to rec.aviation.owning
Roger[_4_]
On Sat, 25 Nov 2006 16:14:36 -0700, "Matt Barrow"
"Mike Noel" wrote in message
ps Check out:
http://www.firstmarkaerospace.com/standbycompass.asp
I've had a vertical card compass for years. The Deb had one in it when
I go it so I'd hardly call it a new, let alone "totally new" concept.
Like a whisky compass it does not give the proper heading at all
times. You still have the lead and lag in turns and it won't set
still in turbulence, but it has far less movement than the whisky
compass in turbulence.
Swinging one is about the same. Just don't use runway headings unless
you know they are right. Ours are about 6 degrees plus so 360 is
really 006 and 060 is really 066. Hence the compass rose at some
airports and that set of tools in the instrument shop.
www.rogerhalstead.com
Old November 26th 06, 09:51 AM posted to rec.aviation.owning
Roger[_4_]
On Sat, 25 Nov 2006 20:14:12 -0700, "Matt Barrow"
I've been flying behind one for a long time and they suffer from the
same errors. You just don't see them tipping like the whisky compass.
Old November 26th 06, 11:17 AM posted to rec.aviation.owning
Bob Noel
In article .com,
it."
compass?
Nope. not even one GPS. not even a handheld.
Bob Noel
Looking for a sig the
lawyers will hate
Old November 26th 06, 02:18 PM posted to rec.aviation.owning
Matt Barrow
"Roger" wrote in message
m...
ps Check out:
I'd say about one-fourth the movement in any case. What surprised me was how
much less overshoot/undershoot there was during turns. I suspect it's from
being mounted in a jeweled gimbal (?) which dampens movement, instead of
floating in water
The only times (I think) that a whiskey compass is any good is on the ground
or in dead still air during 1.0G accell/decell.
How pilots used to navigate with them alone (wait for some cementhead to say
"they used watches and maps, too") is a testament to their skills.
Old November 26th 06, 02:19 PM posted to rec.aviation.owning
Matt Barrow
"Bob Noel" wrote in message
In article .com,
bought
it."
compass?
Infidel!!
Old November 27th 06, 01:50 AM posted to rec.aviation.owning
Stache
Roy Smith wrote:
I've got AC 43.13-1B, which describes the procedure to swing a compass.
What I can't find is the bureaucratic stuff -- who can do it (any pilot?),
and what paperwork follow-up is required (airframe logbook entry, or is
just making the new compass card sufficient?).
Recently the compass rose has come up office conversation and who,
when, how, and what type of compass survey should be accomplished. I
can assure everyone reading this not all airport have a surveyed
compass rose (calibrated). Many airports have compass roses that may
not be accurate due to underground pipes or other metal objects that
will affect the accuracy of the survey.
The FAA has published a document FAA No. 405, Standards for
Aeronautical Surveys and Related Products that explains why and how a
compass rose should be surveyed.
Next who can perform the calibration to your onboard compass installed
in your aircraft? Only a Repair station with the proper ratings with
the proper training, current manuals available, and proper tooling.
This is where it may get sticky for some. FAR 65 Subpart D for
Mechanics does NOT allow Airframe rated mechanic to calibrate
compasses. Only a repair station with the proper rating can perform
this task. FAR 65.81(a) excluded airframe mechanics form performing
maintenance, major repairs to, and major alterations of, propellers,
and any repair to, or alterations of instruments. FAR 1.1 under
maintenance explains calibrations are considered a repair. So this
just leaves repair stations to adjust your compass.
Needless to say a pilot cannot perform this task as it is not
considered preventive maintenance.
AC 43.13-1B does explain how to perform a compass swing and is
acceptable data however the compass rose has to be surveyed to make it
legal. The repair station will make an airframe record entry stated
what data the followed such as AC 43.13-1B, chapter 1, section 3. FAR
23.1327 explain the installed compass has to be accurate and all
compasses are classified as instruments.
Bottom line is the compass rose has to be surveyed (check with your
local airport) and a repair station has to perform the compass swing
and make a airframe record entry.
Stache
Do you use your magnetic compass? Roger Long Piloting 42 May 25th 04 12:08 PM
Strange compass behavior me Owning 10 February 14th 04 04:24 AM
Swinging the compass George A. Gross Jr Owning 1 September 12th 03 03:07 AM
Compass turning error Marty Ross Piloting 3 August 21st 03 02:53 PM
