Jim Macklin wrote:
You are officially "in the hold" the first time you cross the fix {in this case the NDB or a VOR} and if you're established on the inbound course after intercepting the course after your teardrop or direct entry, you can proceed inbound or you have the option at pilot's discretion to go around until you're established and ready. If the hold is for course reversal in lieu of a procedure turn (bold type, and you have been cleared for the approach, you are only allowed one circuit in the hold unless you obtain a clearance for more than one circuit. (AIM 5-4-9 a 4) |
if the altitude change requires more than 500 fpm, the pilot
should request the extra turns. Further the pilot should not be rushed, if not properly established the options are to request extra turns or go missed. At a busy airport, the miss may be needed because of traffic, at a place where you are the only traffic, ATC will approve what ever you need. A pilot should know his limitations and those of his airplane. If you have a lot of altitude to loose, you know that before you get to the fix and should ask for time and distance to allow this. Most controllers will as a routine clearance authorize long legs on the initial clearance if the airplane is not already at the initial approach altitude. "Sam Spade" wrote in message ... | Jim Macklin wrote: | You are officially "in the hold" the first time you cross | the fix {in this case the NDB or a VOR} and if you're | established on the inbound course after intercepting the | course after your teardrop or direct entry, you can proceed | inbound or you have the option at pilot's discretion to go | around until you're established and ready. | | If the hold is for course reversal in lieu of a procedure turn (bold | type, and you have been cleared for the approach, you are only allowed | one circuit in the hold unless you obtain a clearance for more than one | circuit. | | (AIM 5-4-9 a 4) | |
Jim Macklin wrote:
if the altitude change requires more than 500 fpm, the pilot should request the extra turns. Further the pilot should not be rushed, if not properly established the options are to request extra turns or go missed. At a busy airport, the miss may be needed because of traffic, at a place where you are the only traffic, ATC will approve what ever you need. A pilot should know his limitations and those of his airplane. If you have a lot of altitude to loose, you know that before you get to the fix and should ask for time and distance to allow this. Most controllers will as a routine clearance authorize long legs on the initial clearance if the airplane is not already at the initial approach altitude. If the pilot needs it, requests it, and is granted the clearance, that is fine. But, if he arrives at the course reversal hold on altitude, criteria will protect him from high descent rates. |
That is true, if at the altitude. For example in the case
of the Hendrick crash, the BE 200 was at 5.000 and the initial is 3600. Then the crew got lost over the LOM and just did a 360 and never went outbound. "Sam Spade" wrote in message ... | Jim Macklin wrote: | | if the altitude change requires more than 500 fpm, the pilot | should request the extra turns. Further the pilot should | not be rushed, if not properly established the options are | to request extra turns or go missed. At a busy airport, the | miss may be needed because of traffic, at a place where you | are the only traffic, ATC will approve what ever you need. | | A pilot should know his limitations and those of his | airplane. If you have a lot of altitude to loose, you know | that before you get to the fix and should ask for time and | distance to allow this. Most controllers will as a routine | clearance authorize long legs on the initial clearance if | the airplane is not already at the initial approach | altitude. | | If the pilot needs it, requests it, and is granted the clearance, that | is fine. | | But, if he arrives at the course reversal hold on altitude, criteria | will protect him from high descent rates. |
Jim Macklin wrote:
That is true, if at the altitude. For example in the case of the Hendrick crash, the BE 200 was at 5.000 and the initial is 3600. Then the crew got lost over the LOM and just did a 360 and never went outbound. You're a thousand feet high on both counts. They were told to hold at 4,000 and both the initial (minimum holding altitude) and intermediate altitudes are 2,600. From the NTSN report: "As the airplane approached MTV, an air traffic controller advised the flight crew that the airplane was second in line for the localizer runway 30 approach. The controller instructed the pilots to hold 'as published' on the localizer course at 4,000 feet mean sea level (msl)2 and to expect a 28-minute delay in the holding pattern. The flight crew requested 5-mile legs in the holding pattern, and the controller pproved 5- or 10-milelegs at the crew’s discretion." "At 1224:19, while the accident airplane was still turning right to the outbound leg of the holding pattern, the controller asked the flight crew if the airplane was established in the holding pattern, and the crew confirmed, 'we’re established.' At 1224:26, the controller cleared the airplane for the localizer runway 30 approach and requested that the flight crew advise him when the airplane was inbound on the approach. The airplane then completed a continuous right turn toward the inbound course and crossed the BALES LOM at an altitude of 3,900 feet." In a case like this the holding pattern's primary purpose was to absorb a traffic delay with course reversal being adjunct to that requirement. The crew had just turned outbound when they received an unexcepted early approach clearance, and they were not much higher than the two feeder altitudes. Under AIM 5-9-4, they received the approach clearance *after crossing the course-reversal/holding fix so they were cleared to fly a full 1 minute pattern (the 10 mile pattern may have applied only at 4,000). So, with 3 minutes to loose 1,400 feet, they should have been able to do that, but they did need the full 1-minute pattern to do that. And, if they though 467 feet per mile was too steep (within the maximum permitted by TERPs, though) they could have request yet another circuit. |
.... so if you enter teardrop, turn and establish yourself inbound, you just continue inbound? The teardrop entry counts as a circuit? Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
Jose wrote:
If the hold is for course reversal in lieu of a procedure turn ... so if you enter teardrop, turn and establish yourself inbound, you just continue inbound? The teardrop entry counts as a circuit? Jose Yep! |
On Tue, 28 Nov 2006 15:18:18 -0800, Sam Spade
wrote: Jose wrote: If the hold is for course reversal in lieu of a procedure turn ... so if you enter teardrop, turn and establish yourself inbound, you just continue inbound? The teardrop entry counts as a circuit? Jose Yep! Established inbound is a reporting point as I recall. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Roger wrote:
On Tue, 28 Nov 2006 15:18:18 -0800, Sam Spade wrote: Jose wrote: If the hold is for course reversal in lieu of a procedure turn ... so if you enter teardrop, turn and establish yourself inbound, you just continue inbound? The teardrop entry counts as a circuit? Jose Yep! Established inbound is a reporting point as I recall. Only if ATC requests it. |
Sam Spade wrote:
Jose wrote: If the hold is for course reversal in lieu of a procedure turn ... so if you enter teardrop, turn and establish yourself inbound, you just continue inbound? The teardrop entry counts as a circuit? Jose Yep!\ THE WORDS FROM THE AIM: The holding pattern maneuver is completed when the aircraft is established on the inbound course after executing the appropriate entry.\ |
24 Feb 2006 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | February 25th 06 06:55 AM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
Backup gyros - which do you trust? | Dan Luke | Piloting | 23 | July 17th 03 08:06 PM |
