Mxsmanic wrote:
From what I understand, icing protection should be turned on if the outside temperature is 5° C or less. However, what is the reason for not having it on all the time? Some ice protection equipment uses a fluid that is of limited quantity on-board, not to mention that it costs money. Other ice protection devices can put a drain on a smaller aircraft's power. Turbine drivers might chime in with their reasons, I don't know them. Ice protection isn't always needed when it's cold, you also need moisture to create ice. |
"B A R R Y" wrote in message
et... Mxsmanic wrote: From what I understand, icing protection should be turned on if the outside temperature is 5° C or less. However, what is the reason for not having it on all the time? Some ice protection equipment uses a fluid that is of limited quantity on-board, not to mention that it costs money. He can always pause and go to the fridge for more fluids. Other ice protection devices can put a drain on a smaller aircraft's power. He's running on 220VAC. Sholdn't be an issue. |
"Steve Foley" wrote in news:BRlbh.12790
He can always pause and go to the fridge for more fluids. Better yet, use the hot water from his sink. |
A Lieberma wrote in
. 18: "Steve Foley" wrote in news:BRlbh.12790 He can always pause and go to the fridge for more fluids. Better yet, use the hot water from his sink. Or pee. |
Maybe he can rig a 200 pound CO2 bottle that can blast him,
simulating flight into a CB at the freezing level. "Steve Foley" wrote in message news:BRlbh.12790$d42.8443@trndny07... | "B A R R Y" wrote in message | et... | Mxsmanic wrote: | From what I understand, icing protection should be turned on if the | outside temperature is 5° C or less. However, what is the reason for | not having it on all the time? | | Some ice protection equipment uses a fluid that is of limited quantity | on-board, not to mention that it costs money. | | He can always pause and go to the fridge for more fluids. | | Other ice protection devices can put a drain on a smaller aircraft's | power. | | He's running on 220VAC. Sholdn't be an issue. | | |
Jim Macklin wrote:
Maybe he can rig a 200 pound CO2 bottle that can blast him, simulating flight into a CB at the freezing level. And end up looking like Dr. Evil's cat? G |
True, cold and in cloud or precip.
BTW, TKS systems make the plane and floor slippery, don't fall and break a leg. "B A R R Y" wrote in message et... | Mxsmanic wrote: | From what I understand, icing protection should be turned on if the | outside temperature is 5° C or less. However, what is the reason for | not having it on all the time? | | Some ice protection equipment uses a fluid that is of limited quantity | on-board, not to mention that it costs money. Other ice protection | devices can put a drain on a smaller aircraft's power. Turbine drivers | might chime in with their reasons, I don't know them. | | Ice protection isn't always needed when it's cold, you also need | moisture to create ice. |
B A R R Y writes:
Ice protection isn't always needed when it's cold, you also need moisture to create ice. But without a measurement of humidity on board, how do you know if there's moisture out there (apart from the obvious case of visible clouds or fog)? -- Transpose mxsmanic and gmail to reach me by e-mail. |
This is where training and experience start to play a part in flight
planning... If the temperature spread between the air temperature and the "dew" point get close (like only 3 deg difference) the possibility of the moisture in the air causing ice at or close to freezing temps becomes a factor. In air pilot reports (PIREPS) are useful as well. This information is obtained when you look at the weather forcast for your intended route, and get a weather briefing from the weather people before flight. We have had several days of this here, temps +3 on the ground,- 5 at alt, dew point -1 on the ground. Last weekend we had this, and a PIREP from a Dash 8 reporting moderate Rime Ice decending thriugh 6000 2 hrs earlier... Ugh! Dave On Wed, 29 Nov 2006 23:05:23 +0100, Mxsmanic wrote: B A R R Y writes: Ice protection isn't always needed when it's cold, you also need moisture to create ice. But without a measurement of humidity on board, how do you know if there's moisture out there (apart from the obvious case of visible clouds or fog)? |
![]() "Mxsmanic" wrote in message ... crap snipped... It's been my experience that any aircraft once exposed to ice, will naturally seek out warmer air below. Al G |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
FAR 91.157 Operating in icing conditions | O. Sami Saydjari | Instrument Flight Rules | 98 | December 11th 03 06:58 AM |
