Light twins not using contra-rotating propellers
Old December 1st 06, 01:40 AM posted to rec.aviation.piloting
Kev
Default Light twins not using contra-rotating propellers
Mxsmanic wrote:
I do wish that things were different. I consider the effects of
P-factor and torque to be design defects.
You can't design out P-factor or torque, but I don't think they're that
critical anyway in flight for most low-powered GA craft. The propeller
slipstream has more effect on both the rudder and elevator, and that
can be reduced with canted tailfin, and more or less fixed with dual
booms and T-tail.
There are centerline push-pull twins, like the Cessna Skymaster or the
current Adam A500. They eliminate the engine-out yaw problem. As
long as both are running, torque etc should cancel out since the
engines essentially counter-rotate because of their facing fore and
aft.
Kev
Old December 1st 06, 01:55 AM posted to rec.aviation.piloting
Newps
Christ your an idiot. Until you change the laws of physics you're stuck
with those 'design defects'.
Old December 1st 06, 06:41 AM posted to rec.aviation.piloting
Mxsmanic
Newps writes:
Then twins with propellers that turn in opposite directions would seem
to have already violated the laws of physics.
Old December 1st 06, 11:02 AM posted to rec.aviation.piloting
Neil Gould
Recently, Mxsmanic posted:
Newps writes:
stuck with those 'design defects'.
There is no violation at all. Such twins are designed to take advantage of
Neil
Old December 1st 06, 07:27 PM posted to rec.aviation.piloting
Mxsmanic
Neil Gould writes:
Then the design defect of propellers that rotate in the same direction
is not a violation of the laws of physics, QED.
Old December 1st 06, 08:09 PM posted to rec.aviation.piloting
Neil Gould
Neil Gould writes:
advantage of the laws of physics.
Your paraphrase is incorrect. It should be, "The design using propellers
that rotate in the same direction is not a defect".
Neil
Old December 1st 06, 03:17 PM posted to rec.aviation.piloting
Stefan
Newps schrieb:
I consider the effects of P-factor and torque to be design defects.
Be extra careful before calling names! Even when you don't like the poster.
Of course the effects of the P-factor can be overcome by appropriate
design. The most simple solution would be the possibility to trim all
three axis. As this seems to be a pretty straight forward and cheap
solution, I've never understood why this isn't offered in all airplaes.
Sure would make flying a light single more enjoyably. Yes, I even agree
that this avoidance could be called a design defect.
On the more expensive level (much more expensive, I would guess), you
can overcome the P-factor effects by using two contra-rotating coaxial
propellors. This would not only overcome the effects of the P-factor,
but also those caused by torque. Kamov helicopters are an example of
such a design.
Contra-rotating coaxial propellors not only solve the P-factor and
torque, but they make the propellor more efficient, too. Probably too
little effect compared to the additional cost and complexity, so it has
been realized only rarely. Tupolev 114 is an example. (In marine
applications, you find contra-rotating coaxial propellors more often.)
Stefan
Old December 1st 06, 03:34 PM posted to rec.aviation.piloting
Kingfish
three axis.
Yaw damping does wonders in the Pilatus. Of course your typical GA
aircraft doesn't have 1200hp - and doesn't cost $3.5M.
such a design.
Effective, yes, but very complex, heavy and expensive. I recall seeing
an ad for Breitling watches that had a P-51 with contra-rotating props.
I think it was a one-off aircraft with a RR Griffon engine?
IIRC Tu-95/114 was the fastest prop aircraft of its category. I think
the cruise speed was near 500mph? I think that was a combination of
high-shp Kuznetsov turboshafts and the efficiency of the contra props.
Pretty amazing aircraft IMO.
Old December 2nd 06, 09:41 PM posted to rec.aviation.piloting
Capt.Doug
"Kingfish" wrote in message
That aircraft was modified for Unlimited racing at Reno. It also had the
bobbed canopy and clipped wings.
D.
Old December 1st 06, 05:08 PM posted to rec.aviation.piloting
Neil Gould
Recently, Stefan posted:
poster.
airplaes. Sure would make flying a light single more enjoyably. Yes,
I even agree that this avoidance could be called a design defect.
I think it would be a good idea to distinguish between design defects and
design _trade-offs_ in this kind of discussion. Many GA planes have 3-axis
trim, but, as in other areas, this option comes at a cost. The question
becomes which options a buyer might find more attractive, for example
would you prefer 3-axis trim or better avionics and moving map GPS?
Neil
Light twins not using contra-rotating propellers RomeoMike Piloting 6 December 2nd 06 01:47 AM
Light twins not using contra-rotating propellers Newps Piloting 0 November 30th 06 07:40 PM
Light twins not using contra-rotating propellers Greg Farris Piloting 0 November 30th 06 07:25 PM
HOW MANY GLIDER PILOTS DOES IT TAKE TO CHANGE A LIGHT BULB Mal Soaring 59 October 4th 05 05:39 AM
The light bulb Greasy Rider Military Aviation 6 March 2nd 04 12:07 PM
