Neil Gould schrieb:
distinguish between design defects and design _trade-offs_ Agreed. for example would you prefer 3-axis trim or better avionics and moving map GPS? Personally, I'd choose the trim without having to contemplate one second. That's why I actually think that the lack of a three axis trim is a defect. But then, I also think that an engine which has a dispacement of 360 cubic inch and burns 10 US gallons per hour only to produce a mere 180 hp (actually much less in cruse) should be called defect in the 21th century. But I'm getting OT. Stefan |
Recently, Stefan posted:
Neil Gould schrieb: distinguish between design defects and design _trade-offs_ Agreed. for example would you prefer 3-axis trim or better avionics and moving map GPS? Personally, I'd choose the trim without having to contemplate one second. That's why I actually think that the lack of a three axis trim is a defect. But then, I also think that an engine which has a dispacement of 360 cubic inch and burns 10 US gallons per hour only to produce a mere 180 hp (actually much less in cruse) should be called defect in the 21th century. But I'm getting OT. Then, I guess we disagree on the meaning of the term "defect". It may be a defect if it is an unintentional outcome, but I fail to see how simply being a different choice or priority qualifies under the definitions I know of. For example: Dictionary.com Unabridged (v 1.0.1) - Cite This Source defect /n. Pronunciation Key - Show Spelled Pronunciation[n. dee-fekt, di-fekt; v. di-fekt] Pronunciation Key - Show IPA Pronunciation –noun 1. a shortcoming, fault, or imperfection: a defect in an argument; a defect in a machine. 2. lack or want, esp. of something essential to perfection or completeness; deficiency: a defect in hearing. (rest snipped) ---------- #2 might seem closer to your usage, but if that is gauge, then all manufactured items are defective, and the term becomes meaningless or at least redundant. Neil |
Neil Gould writes:
The question becomes which options a buyer might find more attractive, for example would you prefer 3-axis trim or better avionics and moving map GPS? How about a three-axis autopilot with three-axis trim? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Recently, Mxsmanic posted:
Neil Gould writes: The question becomes which options a buyer might find more attractive, for example would you prefer 3-axis trim or better avionics and moving map GPS? How about a three-axis autopilot with three-axis trim? On your salary? You must be joking. Neil |
Neil Gould writes:
On your salary? You must be joking. How many people here have bought their own Barons on their salaries? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Stefan writes:
The most simple solution would be the possibility to trim all three axis. Hmm ... is trim in all three axes uncommon? The Baron has aileron, elevator, and rudder trim. On the more expensive level (much more expensive, I would guess), you can overcome the P-factor effects by using two contra-rotating coaxial propellors. This would not only overcome the effects of the P-factor, but also those caused by torque. Kamov helicopters are an example of such a design. With a single powerplant turning in one direction, there would still be some residual torque from the engine itself. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic schrieb:
Hmm ... is trim in all three axes uncommon? The Baron has aileron, elevator, and rudder trim. We were talking about singles. Of course, you can always fly the baron on one engine... With a single powerplant turning in one direction, there would still be some residual torque from the engine itself. Yawn. You're talking to a former Moto Guzzi driver. Stefan |
Light twins not using contra-rotating propellers | RomeoMike | Piloting | 6 | December 2nd 06 01:47 AM |
Light twins not using contra-rotating propellers | Newps | Piloting | 0 | November 30th 06 07:40 PM |
Light twins not using contra-rotating propellers | Greg Farris | Piloting | 0 | November 30th 06 07:25 PM |
HOW MANY GLIDER PILOTS DOES IT TAKE TO CHANGE A LIGHT BULB | Mal | Soaring | 59 | October 4th 05 05:39 AM |
The light bulb | Greasy Rider | Military Aviation | 6 | March 2nd 04 12:07 PM |
