Light twins not using contra-rotating propellers
Old December 1st 06, 07:32 PM posted to rec.aviation.piloting
Mxsmanic
Default Light twins not using contra-rotating propellers
Steve Foley writes:
By your standards, are bicycles poorly designed because they are unstable at
slow speeds?
They aren't unstable at slow speeds.
Old December 1st 06, 07:35 PM posted to rec.aviation.piloting
Steve Foley
Default MXX - Light twins not using contra-rotating propellers
"Mxsmanic" wrote in message
Steve Foley writes:
at
slow speeds?
I see you know about as much about bicycles as you do about airplanes
Old December 1st 06, 07:46 PM posted to rec.aviation.piloting
Mxsmanic
Steve Foley writes:
I think I know slightly more about airplanes, but I do know the basic
principles of bicycles.
Old December 1st 06, 09:30 PM posted to rec.aviation.piloting
Steve Foley
Steve Foley writes:
When you approach stop, a bicycle will fall over to one side or the other.
(unless yours still has training wheels).
- Note - MXX is intended as a flag to anyone wishing to block my responses
to Anthony.
Old December 1st 06, 09:43 PM posted to rec.aviation.piloting
Mxsmanic
Steve Foley writes:
As long as the rear wheel is powered and both wheels have traction,
the bicycle cannot fall over. The usual reasons for a bicycle falling
over are a loss of traction or a complete absence of propulsive power
to the rear wheel.
Exactly the same principle applies to motorcycles, scooters, etc.
Old December 1st 06, 10:21 PM posted to rec.aviation.piloting
Mxsmanic
Greg Farris writes:
And what, precisely, do you expect the "propulsive power" to be accomplishing
if the bicycle is stopped?
He said "when you approach stop." If the bicycle is still moving and
there is power to the wheel, it won't fall.
Do we reject, then, the notion that the gyroscopic stability provided by the
wheels in motion helps to keep the bicycle upright?
No, but kinetic energy in the bicycle keeps it from falling over. In
order to fall over, it has to have no kinetic energy--it has to stop.
But as long as there is power to the wheel and traction, it cannot
stop, therefore it cannot fall over (which would require a loss of
energy that cannot occur).
It is only a question of
"propulsive power" available to the rear wheel (specifically) while both wheels
must have "traction". As long as this is present the bicycle "cannot" fall
over.
Right. It should apply to both wheels, actually, but I haven't
considered that possibility.
Old December 1st 06, 10:53 PM posted to rec.aviation.piloting
Newps
It most certainly can.
to the rear wheel.
The main reason is the rider loses his balance.
Old December 1st 06, 11:48 PM posted to rec.aviation.piloting
Mxsmanic
Newps writes:
No, it can't. Watch closely. The bicycle always falls because the
tires slip or because it comes to a stop.
Old December 1st 06, 11:39 PM posted to rec.aviation.piloting
Steve Foley[_2_]
to the rear wheel.
Well, that sounds like your definintion if design flaw. It falls down due
to a loss of traction.
Light twins not using contra-rotating propellers RomeoMike Piloting 6 December 2nd 06 01:47 AM
Light twins not using contra-rotating propellers Newps Piloting 0 November 30th 06 07:40 PM
Light twins not using contra-rotating propellers Greg Farris Piloting 0 November 30th 06 07:25 PM
HOW MANY GLIDER PILOTS DOES IT TAKE TO CHANGE A LIGHT BULB Mal Soaring 59 October 4th 05 05:39 AM
The light bulb Greasy Rider Military Aviation 6 March 2nd 04 12:07 PM
