O2 Concentrator instead of O2 tank
Old December 2nd 06, 06:28 AM posted to rec.aviation.piloting
tom
Default O2 Concentrator instead of O2 tank
Does anyone use an oxygen concentrator to supply pilot and passengers
in a light plane flying over 14000 feet? A quick google did not turn
up anything but home units and a recent ruling that they can be used on
commercial airlines, but I did not find anything about their use on
private planes.
They don't require more than about 100 watts, so an aircraft electrical
system could keep them going as long as the engine was running.
Internal batteries would keep it alive in an emergency.
Seems like a nice solution to elimination of messing with refilling
tanks.
tom
Old December 2nd 06, 11:42 AM posted to rec.aviation.piloting
Neil Gould
Recently, tom posted:
on commercial airlines, but I did not find anything about their use on
private planes.
electrical system could keep them going as long as the engine was
running. Internal batteries would keep it alive in an emergency.
I can see a couple of possible difficulties with this related to the
required power. I presume that the home units are intended to supply a
single person? If so, a 4-pax installation would require 4x the power. At
12v, 100w = 8.3 amps; 400w = 33.2 amps (half those for 24v systems).
That's a lot of juice to draw.
Neil
Old December 2nd 06, 02:16 PM posted to rec.aviation.piloting
Larry Dighera
On Sat, 02 Dec 2006 11:42:08 GMT, "Neil Gould"
wrote in
At 12v, 100w = 8.3 amps; 400w = 33.2 amps (half those for 24v systems).
I thought about that too, but IIRC cigar lighters are fused at 10A,
and the pilot alone can operate on oxygen up to 15,000' for thirty
minutes without oxygen for passengers:
§ 91.211 Supplemental oxygen.
(a) General. No person may operate a civil aircraft of U.S.
registry—
(1) At cabin pressure altitudes above 12,500 feet (MSL) up to and
including 14,000 feet (MSL) unless the required minimum flight
crew is provided with and uses supplemental oxygen for that part
of the flight at those altitudes that is of more than 30 minutes
duration;
(2) At cabin pressure altitudes above 14,000 feet (MSL) unless the
oxygen during the entire flight time at those altitudes; and
(3) At cabin pressure altitudes above 15,000 feet (MSL) unless
each occupant of the aircraft is provided with supplemental
oxygen.
Old December 2nd 06, 02:29 PM posted to rec.aviation.piloting
Bill Denton
O2 Concentrators work by removing nitrogen from the ambient air, leaving the
oxygen, which comprises 21% of the air.
At altitude, the air still contains 21% oxygen. But since the air is
"thinner", it contains less oxygen than does the air at sea level.
So removing the nitrogen doesn't actually provide any additional oxygen at
altitude.
So, would a concentrator even provide any benefits?
"Larry Dighera" wrote in message
wrote in
registry-
duration;
oxygen.
Old December 2nd 06, 02:56 PM posted to rec.aviation.piloting
Vaughn Simon
"Bill Denton" wrote in message
t...
altitude.
Yes, because you are breathing air with a higher concentration of oxygen,
wich will result in higher blood oxygen saturation levels. My wife has used
one of those battery operated concentrators for commercial air travel with great
results. They are a fairly new product, and cost around 5 AMUs.
To solve the power problem, it would be theoretically possible to build a
concentrator with a belt-driven compressor as a permanent installation in a
aircraft. It would not be cheap, but it would be far cheaper than
pressurization. Perhaps some clever engineer could build a dual vacuum
pump/compressor to bolt on the same engine pad as your vacuum pump. With an
installation like that, you could afford to fly with oxygen always and enjoy the
better eyesight and quicker thinking that comes with 100% blood oxygen
saturation.
Vaughn
Old December 2nd 06, 03:33 PM posted to rec.aviation.piloting
Peter Dohm
private planes.
tanks.
tom
This is done in military helicopters--oxygen for the crew and dry nitrogen
for the air space in the fuel tanks. By now, it is almost certainly done in
some other aircraft as well.
I have believed for some that this would be a good primary method to supply
oxigen in light civil aircraft--with "candles" such as the airlines use as
emergency backup.
Try a Google or WebCrawler search with the argument: oxygen + concentrator
(or) oxygen + concentrator + aircraft
Peter
Old December 2nd 06, 03:35 PM posted to rec.aviation.piloting
Jim Macklin
If you don't increase the concentration of oxygen, but are
merely removing N, the partial pressure of the oxygen will
not increase.
Pure O2 in a tank, delivered to a mask to displace some of
the ambient air and replace the displaced portion certainly
raises the O2 partial pressure. But an O2 concentrator
doesn't seem to have a pressure function or am I missing
something?
"Vaughn Simon" wrote in
message
news |
| t...
since the air is
sea level.
| altitude.
My wife has used
5 AMUs.
possible to build a
installation in a
cheaper than
a dual vacuum
blood oxygen
| saturation.
| Vaughn
Old December 2nd 06, 03:38 PM posted to rec.aviation.piloting
Peter R.
I flew at 14,000 once with O2 for myself and co-pilot only and the boy in
the back seat vomited into a bag about halfway into the trip.
At that point I realized it was wrong of me to assume that just because the
FARS allow it that it must be safe. Never again.
Peter
Old December 2nd 06, 03:51 PM posted to rec.aviation.piloting
Mxsmanic
"Jim Macklin" writes:
not increase.
If you remove N, the concentration of everything else necessarily
increases, at constant pressure.
Old December 2nd 06, 04:10 PM posted to rec.aviation.piloting
Jose[_1_]
altitude.
Sure it does. With (some of) the nitrogen gone, the air is thinner, and
lower pressure. The surrounding air squeezes it all together, including
the oxygen, which is now more concentrated. Ultimately, volume does not
remain constant, but pressure does.
"There are 3 secrets to the perfect landing. Unfortunately, nobody knows
what they are." - (mike).
wing tank fuel guage D H Home Built 7 October 18th 06 03:32 AM
My Ercoupe is flyin' again... (long) Greg B Owning 13 August 30th 06 12:01 AM
Night bombers interception in Western Europe in 1944 Bernardz Military Aviation 205 July 22nd 04 05:31 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
