#11
On Sun, 3 Dec 2006 19:54:32 -0800, "BT" wrote:
AL, with the manual flaps, drop the flap handle to the floor.. remember.. those beeches say "do not use maximum braking with full flaps" I've seen more than one beech skip down the runway flat spotting the tires Be careful with the term "Beech". A short filed landing with a Bo is, plant the mains on, let the nose down, get on the brakes and *haul* back on the yoke. That actually puts pressure on the mains. The flaps stay at full. For one reason they are slow enough that they will spend more time in the added lift region right when you don't want it when coming up. If I hit the up switch when I have it planted on, I'll be to a stop about the same time the flaps reach full up. BTW A non transitioning pilot is unlikely to hit the wrong switch. Switching to a plane with the switches reversed would worry me. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
On Sun, 3 Dec 2006 22:33:20 -0500, "Dudley Henriques"
wrote: Hi Dudley, Couple of points: Applying forward pressure during the rollout is a bad idea. It can cause a slew (no pun intended :-) of problems. Just concentrate on maintaining directional control with rudder and let the nosewheel settle in naturally at touchdown . The whole Beech family is very good at imitating wheel barrows. :-)) If they aint ready to land they'll end up running down the runway on the nose gear. The same thing is true of taking off. If it's ready to fly you can't hold it on without imitating a wheelbarrow unless everything including trim is neutral. They can be a real bear tying to do touch and goes. If needed, you should be holding some aileron in for wind correction during this process. Retracting the flaps and holding in some back pressure will help firm your mains. With his mechanical flaps that works very well. With my electric flaps it doesn't. I end up reducing drag and increasing lift which will actually increase my roll out a bit. (I can be stopped by the time they are full up) I'm a great believer of not using forward pressure during touchdown and rollout on landings in trikes. Shouldn't be necessary and it's dangerous. Hold back pressure on the rollout. That will increase the pressure on the mains and desensitize the nose wheel. On most trikes its important that the Nose wheels are expensive and for steering during taxi. Mains are strong for landing. nose wheel be straight at touchdown. Correct for drift with aileron and maintain directional control with opposite rudder. The magnitude of the pressure required to do this properly will also vary during the approach. Just keep the speed a bit higher than normal for the crosswind and fly the airplane. If you do everything right, the nose wheel will take care of itself and be positioned correctly at touchdown. Think of it this way; if your rudder work is good, and your alignment is set up and executed correctly, and your aileron work is good and compensating correctly for the drift, the nosewheel should be just fine. :-) Dudley Henriques Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
On 3 Dec 2006 19:45:19 -0800, "Andrew Sarangan"
wrote: There should never be any forward pressure on the yoke/stick during landing. The yoke is always held back, never pushed forward. Perhaps you mean reducing the back pressure. In that case, yes, it would be proper to relax the back pressure somewhat quicker during a crosswind landing to quickly transfer the weight from the wings to the wheels. Howvever this technique is not really necessary except in the worst crosswind (ie when it exceeds rudder authority). In most Beech singles that rudder has more authority than the nose gear unless going really slow. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
So, this damage is a result of slamming the nosewheel down, or applying
forward pressure after the wheels are firmly on the ground? It would seem that forward pressure on the stick would not actually _push_ the nosewheel down, but simply allow the weight of the engine to settle onto the nosewheel sooner.. Does pushing actually apply more downward force on the nosewheel than when the plane is sitting on the ramp? I think that getting the flaps up immediately will help my technique also. (PA28s w/ manual flaps.) --Dan Wheel barrowing is a common occurance on landing when a pilot forces the airplane to land before it is ready. Common evidence of wheel barrowing in Cessna's is damage to the lower fire wall, sometimes to the point that day light is seen through the seperation. BT "Dan" wrote in message ups.com... All, When touching down in a crosswind, after the mains and the nosewheel have all touched down firmly and are rolling, would it be proper procedure to apply slight forward pressure to get better steering from the nosewheel? Often, noseweel steering seems ineffective, and this seems to have helped my control on rollout. Any cautions? I have heard about "wheelbarrowing" but is that more of a takeoff issue than landing issue? Under what circumstances would "wheelbarrowing" occur? --Dan |
OK, so by bringing the yoke/stick full aft, aren't you increasing the
angle of attack, generating more lift and _removing_ wieght from the mains? (Sure, the aerodynamic braking does help). This was discussed in a thread he http://groups.google.com/group/rec.a...bbacd8005c3a8/ but it seems to be something that everyone has an opinion on.... --Dan A Lieberma wrote: "Dan" wrote in news:1165200901.919197.150950@ 16g2000cwy.googlegroups.com: Under what circumstances would "wheelbarrowing" occur? Anytime the plane is rolling too fast, the potential for wheelbarrowing can happen whether it be landing or take off. For me, I do the opposite in my Beechsundowner. After landing, after all three wheels are firmly on terra firma, WHENEVER POSSIBLE, I hold the yoke full aft until the plane slows down enough that the stabilator has no effect on keeping the pressure off the nosewheel (similar to a softfield landing technique). I want the weight to remain on the mains as long as I can so I can prevent the chance of nosewheel shimmy as well as wheelbarrowing down the runway. Allen |
My impression that the elevator applied varying levels of downward
force to balance the plane about the center of lift. I am not aware that the elevator could even produce _upward_ force on the tail. If it can't produce upward force, then the rear of the plane could be made no lighter than when it is standing still, therefore it could transfer no _additional_ weight to the nosewheel no matter what the control inputs. Where is this logic flawed (seriously, I want to understand if this is wrong...) --Dan Crash Lander wrote: "Dan" wrote in message ups.com... So, this damage is a result of slamming the nosewheel down, or applying forward pressure after the wheels are firmly on the ground? It would seem that forward pressure on the stick would not actually _push_ the nosewheel down, but simply allow the weight of the engine to settle onto the nosewheel sooner.. Does pushing actually apply more downward force on the nosewheel than when the plane is sitting on the ramp? No, it doesn't, but when travelling at speed down the runway, pushing the stick forward increases the angle of attack of the tail plane, (obviously), and in effect, transfers more weight to the front of the a/c by making the rear lighter. (I think I'm explaining this right!) Oz Lander |
![]() "Roger" wrote in message ... On Sun, 3 Dec 2006 22:33:20 -0500, "Dudley Henriques" wrote: With his mechanical flaps that works very well. With my electric flaps it doesn't. I end up reducing drag and increasing lift which will actually increase my roll out a bit. (I can be stopped by the time they are full up) We had an old V Tail Bo on the line around the Jurassic Period that we used for charter once in a while. After touchdown, she was pretty well planted unless you brought it in a bit fast. Very stable on landing; in fact, I always liked the way the Bo handled on landings. Solid as a rock! My procedure with the Bo was to NOT touch the flaps during the rollout until the airplane had left the runway, then I'd LOOK at the switch, TOUCH the switch, REPEAT verbally to myself, "Flaps UP!", THEN I'd raise the flaps. :-)) Dudley |
No... this is the point at which there is more gravity acting on the
plane than lift... the wing cannot lift the plane off the gorund. Putting more pressure on the mains will let you brake quicker. On Dec 3, 7:34 pm, "Dan" wrote: OK, so by bringing the yoke/stick full aft, aren't you increasing the angle of attack, generating more lift and _removing_ wieght from the mains? (Sure, the aerodynamic braking does help). This was discussed in a thread hehttp://groups.google.com/group/rec.a...owse_frm/threa... but it seems to be something that everyone has an opinion on.... --Dan A Lieberma wrote: "Dan" wrote in news:1165200901.919197.150950@ 16g2000cwy.googlegroups.com: Under what circumstances would "wheelbarrowing" occur? Anytime the plane is rolling too fast, the potential for wheelbarrowing can happen whether it be landing or take off. For me, I do the opposite in my Beechsundowner. After landing, after all three wheels are firmly on terra firma, WHENEVER POSSIBLE, I hold the yoke full aft until the plane slows down enough that the stabilator has no effect on keeping the pressure off the nosewheel (similar to a softfield landing technique). I want the weight to remain on the mains as long as I can so I can prevent the chance of nosewheel shimmy as well as wheelbarrowing down the runway. Allen- Hide quoted text -- Show quoted text - |
On Mon, 4 Dec 2006 00:58:48 -0500, "Dudley Henriques"
wrote: "Roger" wrote in message .. . On Sun, 3 Dec 2006 22:33:20 -0500, "Dudley Henriques" wrote: With his mechanical flaps that works very well. With my electric flaps it doesn't. I end up reducing drag and increasing lift which will actually increase my roll out a bit. (I can be stopped by the time they are full up) We had an old V Tail Bo on the line around the Jurassic Period that we used for charter once in a while. Your's was that new? After touchdown, she was pretty well planted unless you brought it in a bit fast. Even then those big flaps slow them down in a hurry. What surprises most people is the light wing loading. About the same as a Cherokee 180 and about 2# lighter than a Mooney although that figure varies a lot depending on model and year. Very stable on landing; in fact, I always liked the way the Bo handled on landings. Solid as a rock! My procedure with the Bo was to NOT touch the flaps during the rollout until the airplane had left the runway, then I'd LOOK at the switch, TOUCH the switch, REPEAT verbally to myself, "Flaps UP!", THEN I'd raise the flaps. Ah, yes. Look at it, point at it, Identify it, say it, and THEN do it. OTOH I'm that way on any retract as all of them except the Bo are backwards. :-)) Actually, once you get used to the interconnected rudder (ruddervators on V-tails) and ailerons they are one of the easiest planes to land out there. :-)) Dudley Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Best place for CG along roll axis | Mxsmanic | Piloting | 42 | September 28th 06 04:40 AM |
Crosswind landing | Ron Webb | Home Built | 23 | June 10th 06 03:43 AM |
Cuban Missle Crisis - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 0 | June 2nd 05 09:14 PM |
Tailwheel Crosswind Landing | Piloting | 32 | December 6th 04 02:42 AM | |
Strong crosswind landings! | Toks Desalu | Piloting | 12 | April 19th 04 07:43 PM |
