"Andrew Sarangan" wrote in message
ups.com... I don't know why you would need to write them down with such precision. Is it for tax purposes? Or is it an employer requirement? If it is just for the personal logbook, I don't see why you need a PDA to do this. Just remember it in your head, or write it down on a scrap piece of paper until you get home. BG wrote: Does anyone use a PDA to record in a small spreadsheet the departure airport, your destination airport, and the Hobbs & Tach readings when you land? If so, what would be the brand and the main features of the PDA? Thanks I have a PocketPC with a small version of Excel. I have a W&B (including the chart) customized for my plane. The Lake is somewhat CG limited. It's easy to be too far aft starting out. And just as easy to be too far forward after fuel burns off. So anything other than typical loads gets put in to check the range as fuel burns. My chart plots the line from starting fuel down to 5 gal. remaining. I figure if I have less than 5 gal, a little forward CG is the least of my problems. I do have an Excel file with my flight information. I use it as an easier way to determine flight currency for medical applications, insurance forms, IFR currency, and the trivial passenger currency. It's also a backup, in case I lose my logbook. It's kind of nice to be able to crunch Excel formulae to determine, for example, how many hours do I have in C172s? in the last six months. At night. Solo. I have a section at the bottom that lists the typical currency numbers and displays colored text to warn me that I need to, for example, get some IFR approaches in before it's too late. I do copy this chart to my PocketPC but I don't enter numbers using the PDA. Too small and I really want the master on my PC anyway. I have flight note sheets in my kneeboard that have a customized form at the top with room for start-up/shutdown time, start-up/shutdown tach, start-up/shutdown hobbs, and othe stuff. One sheet per flight. I collect them and transfer the info to my logbook and the Excel file periodically. ------------------------------- Travis Lake N3094P PWK |
fwd: For Hobbs | Jack | Soaring | 9 | November 26th 06 05:28 AM |
Engine noise recording in Motor Gliders | Ian Strachan | Soaring | 2 | October 16th 06 12:32 PM |
Hobbs Day 3 7-06 # 711 reporting | TomnKeyLargo | Soaring | 12 | July 9th 04 04:38 AM |
Tach Vs. Hobbs Time | John Roncallo | Owning | 33 | January 7th 04 12:42 AM |
