![]() "A Lieberma" wrote in message . 18... Severe clear today, so other then the safety net of ATC services, weather wasn't an issue. Coming back from HBG (Hattiesburg MS) to MBO (Madison MS) encountered the following exchange with ATC. I was already told to expect the visual approach in my inital contact with approach controller. Frequency, while not wall to wall traffic, was busier then normal. ATC Sundowner 1943L, descend and maintain 2000, report Madison in sight. Me 43L will report Madison in sight. Me Approach 43L, has Madison in sight ATC 43L radar services terminated, squawk VFR, have a good evening Me Uh, 43L would like to cancel IFR at this time. ATC 43L radar services terminated, squawk VFR. Me, Uh, will assume IFR cancellation received, squawking VFR, good evening. I change to Unicom and land as normal. After landing, switch over to Clearance and Delivery (CD) to see if indeed my IFR cancellation was received, but it was busy with the controller handling approach and departure traffic (one guy does all I guess?) so I didn't interrupt the frequency. Took my time tying down and hung around for a bit just in case ATC called the airport, in which they did not (seen this done many times when IFR traffic forgets to call CD) so I felt comfortable that the airspace was re-opened for arrivals. Queston one: I never was cleared for the visual which caught me off guard on my forth line, and since it was severe clear, I figured go ahead and cancel my IFR thus negating my need for the visual clearance. No biggie, but shouldn't I have been cleared for the visual before radar services are terminated? Yes. Somewhere between "Sundowner 1943L, descend and maintain 2000, report Madison in sight." and "43L radar services terminated, squawk VFR, have a good evening." the controller forgot you were operating IFR. Question two: While I wanted on the tapes that IFR cancellation was received (see last transmission by me), was I truly and properly cancelled out of the IFR system? Since the frequency was busy, figured to let sleeping dogs rest, but I wasn't comfortable with the fact that I didn't hear the buzz words "IFR cancellation received". Properly? No. But you're at the end of the line anyway. If the approach controller believes you're VFR you're out of the IFR system. Question three: Is this worthy of ASR filing? No safety issue by any means, but there were areas left wide open for miscommunication (I.E. not getting the airpsace freed up for the next IFR arrival). Any anomaly is worthy of filing. |
Does "Sundowner 1943L, descend and maintain 2000, report Madison in sight."
imply the controller thought he was IFR? Wouldn't he say the same thing with VFR flight following (traffic advisories)? you 'da man! "Steven P. McNicoll" wrote in message ink.net... snip Yes. Somewhere between "Sundowner 1943L, descend and maintain 2000, report Madison in sight." and "43L radar services terminated, squawk VFR, have a good evening." the controller forgot you were operating IFR. snip |
![]() "dlevy" wrote in message ... Does "Sundowner 1943L, descend and maintain 2000, report Madison in sight." imply the controller thought he was IFR? Yes. Wouldn't he say the same thing with VFR flight following (traffic advisories)? No. Recall that he was told to expect a visual approach on initial contact with Jackson approach. Only an IFR arrival would be told to expect a visual approach. The controller told him to report Madison in sight so that he could issue the visual approach clearance, so he's still thinking IFR at that point. |
On 2006-12-08, Steven P. McNicoll wrote:
"dlevy" wrote in message ... Does "Sundowner 1943L, descend and maintain 2000, report Madison in sight." imply the controller thought he was IFR? Yes. Why? You can get an altitude assignment while VFR and Seattle center usually asks me to report the field in sight (PAE) even when I'm VFR before terminating radar services. -Milen |
![]() "Milen Lazarov" wrote in message ... Why? You can get an altitude assignment while VFR and Seattle center usually asks me to report the field in sight (PAE) even when I'm VFR before terminating radar services. Yes, you can get an altitude assignment while VFR, but you can't (properly) get one from Seattle Center while VFR. Reporting the field serves a purpose if you're IFR, but not if you're VFR. |
Yes, you can get an altitude assignment while VFR, but you can't (properly) get one from Seattle Center while VFR. Reporting the field serves a purpose if you're IFR, but not if you're VFR. When I get flight following from New York Approach, they always ask me to report the field in sight. (This is for both controlled and uncontrolled fields.) This is for airports that are NOT in the Bravo airspace -- they're either near or underneath it. I assume the purpose it serves is it tells them when they can terminate flight following. .... Alan -- Alan Gerber PP-ASEL gerber AT panix DOT com |
Alan Gerber wrote in
: I assume the purpose it serves is it tells them when they can terminate flight following. Alan, VFR flight following is workload permitted basis. So, like you, I have experienced the same, approach asking me to advise airport in sight. Approach can tell you to squawk VFR, have a good day well before you have a visual on VFR flight following. In my area, I have never had that done except once when I was arriving after the ATC shut down for the night. Generally IN MY AREA, if it's that busy, approach much rather you squawk and talk then not. But I am only dealing with C airspace. For IFR, a visual approach requires sight of the airport / runway environment, and ATC cannot terminate your IFR until you request it (I.E cancel IFR like in my case at an uncontrolled airport) or land at a controlled airport. Allen |
![]() Alan Gerber wrote: When I get flight following from New York Approach, they always ask me to report the field in sight. (This is for both controlled and uncontrolled fields.) This is for airports that are NOT in the Bravo airspace -- they're either near or underneath it. I assume the purpose it serves is it tells them when they can terminate flight following. They can't terminate flight following if the aircraft hasn't reported the field in sight? |
On Thu, 7 Dec 2006 21:10:15 -0800, Milen Lazarov
wrote: On 2006-12-08, Steven P. McNicoll wrote: "dlevy" wrote in message ... Does "Sundowner 1943L, descend and maintain 2000, report Madison in sight." imply the controller thought he was IFR? Yes. Why? You can get an altitude assignment while VFR and Seattle center usually asks me to report the field in sight (PAE) even when I'm VFR before terminating radar services. I don't think the above state (descend and maintain) implies IFR. However, earlier in the post, the controller told the pilot to expect the visual. That is very much an IFR procedure, and not a VFR one. So at least at that point the controller thought the original poster was IFR. |
"dlevy" wrote: Does "Sundowner 1943L, descend and maintain 2000, report Madison in sight." imply the controller thought he was IFR? Assignment of an altitude pretty much means IFR. |
Lyc. O-360 cylinder question | JB | Owning | 13 | November 27th 04 09:32 PM |
Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 03:07 PM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Question | Charles S | Home Built | 4 | April 5th 04 09:10 PM |
Partnership Question | Harry Gordon | Owning | 4 | August 16th 03 11:23 PM |
