![]() Mxsmanic wrote: Peter R. writes: A question for those of you more adept at chemistry/physics than I: How fast does the aluminum skin of the standard single engine GA aircraft take to cool to surrounding air temperatures? For example, how long would it take for the skin to cool from a heated hangar at 65 degrees F to outside air at 20 degrees F? On a clear night the skin temperature can go BELOW the air temperature due to the radiation losses into space. We regularly see that here, and it's what causes frost to form so quickly. Dan |
Mxsmanic opined
writes: On a clear night the skin temperature can go BELOW the air temperature due to the radiation losses into space. The temperature of the aircraft won't drop below the temperature of the ambient air, as long as the aircraft is dry. Actually, it can. I have seen frost on metal surfaces (like wings) when the air temp is above freezing. Taxiing will sometimes melt frost. A clear night sky is /cold./ -ash Cthulhu in 2005! Why wait for nature? |
Ash Wyllie writes:
Actually, it can. I have seen frost on metal surfaces (like wings) when the air temp is above freezing. What was the temperature profile of the air during the preceding hours, and at the exact time of the observation? If the air is warming up and moist, metal surfaces might well be below that temperature and below the dew point. A clear night sky is /cold./ Yes, because large masses of water vapor have a moderating effect on temperature, making warm days cooler and cold days warmer. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic opined
Ash Wyllie writes: Actually, it can. I have seen frost on metal surfaces (like wings) when the air temp is above freezing. What was the temperature profile of the air during the preceding hours, and at the exact time of the observation? If the air is warming up and moist, metal surfaces might well be below that temperature and below the dew point. It was before dawn, and the temp had dropped over night (and was still dropping). A clear night sky is /cold./ Yes, because large masses of water vapor have a moderating effect on temperature, making warm days cooler and cold days warmer. Look up _radiational cooling_ . Space is in the single digits absolute, and the atmosphere is pretty much transparent to radiation. Objects will radiate energy trying to heat up interstellar space, and cool in the process. You might drop in on some of the amatuer telescope groups. They have the same problem. -ash Cthulhu in 2005! Why wait for nature? |
Ash Wyllie writes:
Look up _radiational cooling_. I'm familiar with it, and with blackbody radiation. Space is in the single digits absolute, and the atmosphere is pretty much transparent to radiation. The atmosphere not only absorbs and reflects the blackbody radiation emitted by most objects on the ground at ordinary temperatures, it also emits radiation of its own (as does anything with a non-zero absolute temperature). Objects will radiate energy trying to heat up interstellar space, and cool in the process. The surface of the planet is not part of interstellar space. Everything on the surface of the Earth cools through emission of radiation, but aircraft do not do this to any greater extent than anything else, and they don't cool to subfreezing temperatures in air that is above freezing. -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() "Ash Wyllie" wrote in message ... Look up _radiational cooling_ . Space is in the single digits absolute, and the atmosphere is pretty much transparent to radiation. Objects will radiate energy trying to heat up interstellar space, and cool in the process. Ash, I'd like to expand a bit on your statements. In the 3-5 and 8-12 micrometer region of the electromagnetic spectrum, atmospheric transmission is, like you said, close to 100% transparent. Outer space, in those bands, is to photons like a Hoover is to dust in the carpet - it just sucks heat right out. The rate at which the transfer of photons occurs is dependent on, among other things, the emmissivity of the surface and the thermal conductivity from the mass to that surface. The perfect case is a gaussian emmissivity of one, and since perfection is difficult, the closest you can come is a bunch of nines behind the decimal point. A pure white specular surface is at the opposite end of the scale. One good example to back up your statement is in the winter time. We have all felt the phenomena when the sky is clear that the nights are much colder than when the sky is overcast. That is because interstellar space is sucking the heat off the planet's surface. The adjacent atmosphere loses a lot of its energy to the surface and its temperature decreases also. Please, don't confuse the cloud cover effect with the so-called "greenhouse" effect. I always used the term "radiative cooling" (not radiational) to keep in tune with NASA's glossary: (http://eobglossary.gsfc.nasa.gov/Lib...seg=q&segend=s) radiative cooling Cooling process of the Earth's surface and adjacent air, which occurs when infrared (heat) energy radiates from the surface of the Earth upward through the atmosphere into space. Air near the surface transfers its thermal energy to the nearby ground through conduction, so that radiative cooling lowers the temperature of both the surface and the lowest part of the atmosphere. Oh, did I mention that I spent the better part of two decades doing infrared measurements using a Michelson Interferometric Spectrometer? [Don't try saying that with more than two drinks under your belt.] A lot of that dealt with radiative transfer. |
![]() "Ash Wyllie" wrote Look up _radiational cooling_ . Space is in the single digits absolute, and the atmosphere is pretty much transparent to radiation. Objects will radiate energy trying to heat up interstellar space, and cool in the process. You might drop in on some of the amatuer telescope groups. They have the same problem. Why on earth are you arguing with this BoZo? He doesn't know **** from shinola, and has proven it on many occasions and many subjects, yet still he argues with people that do know, and then tells them that they are not qualified to make statements on xyz subject. You only contribute to him overstaying his welcome even longer! -- Jim in NC |
Morgans opined
"Ash Wyllie" wrote Look up _radiational cooling_ . Space is in the single digits absolute, and the atmosphere is pretty much transparent to radiation. Objects will radiate energy trying to heat up interstellar space, and cool in the process. You might drop in on some of the amatuer telescope groups. They have the same problem. Why on earth are you arguing with this BoZo? He doesn't know **** from shinola, and has proven it on many occasions and many subjects, yet still he argues with people that do know, and then tells them that they are not qualified to make statements on xyz subject. I've quit doing so here. Mx is impervious to experience, and science. You only contribute to him overstaying his welcome even longer! -ash Cthulhu in 2005! Why wait for nature? |
On 8 Dec 2006 18:39:30 -0500, "Ash Wyllie" wrote:
Mxsmanic opined writes: On a clear night the skin temperature can go BELOW the air temperature due to the radiation losses into space. The temperature of the aircraft won't drop below the temperature of the ambient air, as long as the aircraft is dry. Actually, it can. I have seen frost on metal surfaces (like wings) when the air temp is above freezing. Taxiing will sometimes melt frost. As usual, mxsmanic is both right and wrong (as in 'a little knowledge can be a dfangerous thing"). When the skin radiates, it cools down, and will cool the air in contact with its surface. This creates a thin inversion layer, which (in the absence of any appreciable wind) is stable. The air temperateure a few millimeters above the skin will be significantly warmer. A clear night sky is /cold./ -ash Cthulhu in 2005! Why wait for nature? |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
