Dan, it's not an important point, but from the physics/theromdynamics
side of the issue, the top surface of the wing is really at risk of radiational cooling. The wing's leading edge's shape would allow convective warming, as the warmer air in contact with the surface would cool and flow downward. |
![]() writes: On a clear night the skin temperature can go BELOW the air temperature due to the radiation losses into space. Tony wrote: Dan, it's not an important point, but from the physics/theromdynamics side of the issue, the top surface of the wing is really at risk of radiational cooling. The wing's leading edge's shape would allow convective warming, as the warmer air in contact with the surface would cool and flow downward. And that's where we see frost forming: on top of the wings, fuselage and stabilizer. Mxmanic wrote: The temperature of the aircraft won't drop below the temperature of the ambient air, as long as the aircraft is dry. You really should read the textbooks. Try this website: http://www.islandnet.com/~see/weathe...nts/frost1.htm I quote from this article from the above site: "Frost forms first on rock, glass, or metal surfaces that lose heat more rapidly through radiative cooling than the surrounding air. This is why car windshields frost over before frost forms on surrounding vegetation. If the surface on which it forms has a temperature below the frost point, frost may even appear when the officially reported air temperature is above freezing." The aviation weather textbooks teach the same thing. Another website, this time by NASA: http://aircrafticing.grc.nasa.gov/co...4_2_1a_RI.html Now try to tell people the dry surface temp won't drop below the air temp. Dan |
Yea, same here. Often we'll get lots of frost on the top of the plane,
almost never on the bottom. I wasn't sure if the difference was temp or moisture. The bottom is subject to radiation heating from the pavement. Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
"Jose" wrote in message
. net... Yea, same here. Often we'll get lots of frost on the top of the plane, almost never on the bottom. I wasn't sure if the difference was temp or moisture. The bottom is subject to radiation heating from the pavement. Jose Zactly - radiation depends on what the surface is exposed to. I park my mini-van next to a big pine tree in the driveway - the tree side is clear in the morning- it "see's" the tree. The other windows are frosted over (even if the overnight low is still a bit above freezing) - they are exposed to the sky. It's a real problem with telescopes too. Since they are pointed directly at the sky (on clear nights) the objective lens cools off rapidly and will fog up. Look up "telescope heater". The earth surfaces cool first through radiation, which, in turn, cools the air (which is reasonably "transparent" to a lot of wavelengths). That's what makes clear nights colder than cloudy nights - more heat loss to space via radiation. And having the air cooled by the surface of the earth is what causes surface winds to often die down at sundown - you get a layer of cold, heavy, air that just sits there under the warmer air that is moving around the high and low pressure areas. During the daytime, of course, radiation from the sun warms the surface, which then warms the air. The nice thing about that is that it is the mechinism that triggers the thermals that keep glider pilots aloft (dragging it back to aviation content, eh?). But to get back to the orignial post - just ask the guy in the next hanger, he/she ought to know if they have been in the area a few years, right? -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote:
But to get back to the orignial post - just ask the guy in the next hanger, he/she ought to know if they have been in the area a few years, right? In the several months since starting my hangar contract at that airport I have yet to meet any of the fellow hangar lessees. Either they don't fly a lot or my arrival/departure timing is out of sync with theirs. Most likely the latter. -- Peter |
You'll notice some have claimed to observe frost forming as I had
suggested it might, When theory and observations differ, it's the theory that should change. On Dec 8, 7:47 pm, Mxsmanic wrote: writes: You really should read the textbooks.I have. Try this website: http://www.islandnet.com/~see/weathe...nts/frost1.htm I quote from this article from the above site:The above site is not a textbook. "Frost forms first on rock, glass, or metal surfaces that lose heat more rapidly through radiative cooling than the surrounding air. This is why car windshields frost over before frost forms on surrounding vegetation. If the surface on which it forms has a temperature below the frost point, frost may even appear when the officially reported air temperature is above freezing."Surfaces such as metal and glass cool more during the night because of radiative cooling. However, they emit in the infrared, and water vapor, CO2, and other gases in the atmosphere absorb it, so it doesn't get very far. Early in the morning, as temperatures rise, the air may be filled with moisture but slightly warmer than surfaces that have cooled greatly during the night and conduct heat well (such as metal). The moisture in the air may condense (and even freeze) on such surfaces. But there isn't much radiation loss at ground level unless the air temperature is lower than surface temperatures. Remember that not only does the atmosphere absorb infrared, but it also emits it. The aviation weather textbooks teach the same thing. Another website, this time by NASA: http://aircrafticing.grc.nasa.gov/co.../4_2_1a...This site requires Flash, so I can't read it. Now try to tell people the dry surface temp won't drop below the air temp.I already have. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Tony wrote:
You'll notice some have claimed to observe frost forming as I had suggested it might, Agreed. It's quite common for frost to form on glass and metal surfaces that are exposed to a clear night sky even when the local air temperature never drops below 35F at any time. When theory and observations differ, it's the theory that should change. But in this case the observations are in good agreement with the theory of radiant heat transfer to a clear night sky. The effect is well known to amateur astronomers since it causes the optics of their telescopes to cool down below the dew point and have water condense on them even though the air temperature remains well above the dew point. Various solutions are used such as slight heating of the optical elements or installing tubes (dew caps) that extend well past the end of the telescope and therefore don't allow as much heat radiation to the cold, clear night sky. |
peter writes:
But in this case the observations are in good agreement with the theory of radiant heat transfer to a clear night sky. How much frost do you see condensing on Styrofoam? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
