Recently, nrp posted:
It may be a more tricky task than it appears, since to degauss the object one has to apply exactly? Degaussers work from line power by generating a strong 60 Hz alternating flux which is slowly decreased in intensity by removing the degausser coil away from the subject. My over-generalization was in response to the typical use of a magnetic tape degausser where the size of the coil is much larger than the item being degaussed and the purpose is only to randomize the magnetic alignment of the oxide particles. In that use, residual magnetism isn't critical, but I don't think it would be the same for magnetized bars (the braces) that are much *larger* than the coil. I'd remove the compass and any electronics first though for that reason. I'd think a strong or larger degausser could be temporarily made from a 500 ft coil of three conductor (plus ground) # 14 romex wiring cable. The ends should be connected to make a 2000 ft coil, and the whole mess tied together with tie wraps. As an alternate the whole mess could be made with 3 conductor extension cords. & a suicide plug/socket arrangement. Has anyone ever tried something like this? Well... I still think it would be better to remove the braces from the plane first. Using that size coil in-situ sounds risky. Neil |
Degaussing a Warrior | DavidM | Owning | 22 | November 8th 05 12:01 AM |
