Yea, same here. Often we'll get lots of frost on the top of the plane,
almost never on the bottom. I wasn't sure if the difference was temp or moisture. The bottom is subject to radiation heating from the pavement. Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
"Jose" wrote in message
. net... Yea, same here. Often we'll get lots of frost on the top of the plane, almost never on the bottom. I wasn't sure if the difference was temp or moisture. The bottom is subject to radiation heating from the pavement. Jose Zactly - radiation depends on what the surface is exposed to. I park my mini-van next to a big pine tree in the driveway - the tree side is clear in the morning- it "see's" the tree. The other windows are frosted over (even if the overnight low is still a bit above freezing) - they are exposed to the sky. It's a real problem with telescopes too. Since they are pointed directly at the sky (on clear nights) the objective lens cools off rapidly and will fog up. Look up "telescope heater". The earth surfaces cool first through radiation, which, in turn, cools the air (which is reasonably "transparent" to a lot of wavelengths). That's what makes clear nights colder than cloudy nights - more heat loss to space via radiation. And having the air cooled by the surface of the earth is what causes surface winds to often die down at sundown - you get a layer of cold, heavy, air that just sits there under the warmer air that is moving around the high and low pressure areas. During the daytime, of course, radiation from the sun warms the surface, which then warms the air. The nice thing about that is that it is the mechinism that triggers the thermals that keep glider pilots aloft (dragging it back to aviation content, eh?). But to get back to the orignial post - just ask the guy in the next hanger, he/she ought to know if they have been in the area a few years, right? -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote:
But to get back to the orignial post - just ask the guy in the next hanger, he/she ought to know if they have been in the area a few years, right? In the several months since starting my hangar contract at that airport I have yet to meet any of the fellow hangar lessees. Either they don't fly a lot or my arrival/departure timing is out of sync with theirs. Most likely the latter. -- Peter |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
