![]() Robert Chambers wrote: Really, then how does the system know you landed and not crashed on approach? ATC as in approach takes no overt action. The tower controller hits the land line to approach and says "N12345 is on the ground" end of IFR flight. He does no such thing. No calls, whatsoever. There's no need to. |
![]() Newps wrote: Robert Chambers wrote: Really, then how does the system know you landed and not crashed on approach? ATC as in approach takes no overt action. The tower controller hits the land line to approach and says "N12345 is on the ground" end of IFR flight. He does no such thing. No calls, whatsoever. There's no need to. I've been in a tower cab when this happened. I've also been there when they've hit the button, called the tracon and gotten a release. Were they special occasions? I don't know I don't spend a lot of time visiting. Explain how it happens at your location. |
![]() Robert Chambers wrote: He does no such thing. No calls, whatsoever. There's no need to. I've been in a tower cab when this happened. I've also been there when they've hit the button, called the tracon and gotten a release. Were they special occasions? I don't know I don't spend a lot of time visiting. Explain how it happens at your location. When I worked at what is now a class D it happens as I said. Airplane lands and I tell him to contact ground control. No calls to the facility that was our approach control. There was no need to. For releases it depends on what you have worked out with your approach control. At that facility we had to call for each release. There could just as easily have been a letter of agreement allowing me to release IFR aircraft on certain headings at my discretion. I work at a class C now. The tower controller is, by definition, an approach controller here. Everything is automatic. The only time you call for a release is when you want to launch someone opposite direction and then only if you are running standard procedures. Many of us just make a quick verbal agreement between tower and approach that I as a tower controller can launch aircraft anytime, anywhere and the approach controller will accept them. |
Newps writes:
Robert Chambers wrote: Really, then how does the system know you landed and not crashed on approach? ATC as in approach takes no overt action. The tower controller hits the land line to approach and says "N12345 is on the ground" end of IFR flight. He does no such thing. No calls, whatsoever. There's no need to. Are you saying that a telephone call isn't made or are you saying that nobody in the tower closes the flight plan? |
![]() Everett M. Greene wrote: He does no such thing. No calls, whatsoever. There's no need to. Are you saying that a telephone call isn't made or are you saying that nobody in the tower closes the flight plan? Both. Nobody does anything. |
![]() Everett M. Greene wrote: Are you saying that a telephone call isn't made or are you saying that nobody in the tower closes the flight plan? What is so hard about this? When you cancel IFR inflight all controllers down the line from whatever point you cancelled must be notified that you have cancelled. This is normally done by the computer, controllers receive a "remove strips" message for your flight. When you land at a controlled field you're at the end of the line. There are no controllers down the line to advise that you've cancelled because you're at the end of the line. |
Steven P. McNicoll wrote:
Everett M. Greene wrote: Are you saying that a telephone call isn't made or are you saying that nobody in the tower closes the flight plan? What is so hard about this? When you cancel IFR inflight all controllers down the line from whatever point you cancelled must be notified that you have cancelled. This is normally done by the computer, controllers receive a "remove strips" message for your flight. When you land at a controlled field you're at the end of the line. There are no controllers down the line to advise that you've cancelled because you're at the end of the line. Does the last computer to handle your IFR flight simply can it after some time period has expired? I'm just curious what event removes the last trace of my IFR flight from the ATC computers. Matt |
Matt Whiting wrote: Steven P. McNicoll wrote: Everett M. Greene wrote: Are you saying that a telephone call isn't made or are you saying that nobody in the tower closes the flight plan? What is so hard about this? When you cancel IFR inflight all controllers down the line from whatever point you cancelled must be notified that you have cancelled. This is normally done by the computer, controllers receive a "remove strips" message for your flight. When you land at a controlled field you're at the end of the line. There are no controllers down the line to advise that you've cancelled because you're at the end of the line. Does the last computer to handle your IFR flight simply can it after some time period has expired? I'm just curious what event removes the last trace of my IFR flight from the ATC computers. Matt There is an anti-flight plan floating around in a parallel universe. When your wheels touch the ground the two universes come into contact and the flight plan and the anti-flight plan annihilate each other. |
Roy Smith wrote:
There is an anti-flight plan floating around in a parallel universe. When your wheels touch the ground the two universes come into contact and the flight plan and the anti-flight plan annihilate each other. And a photon is emitted (either that or the end of the universe occurs). |
"Ron Natalie" wrote in message ...
Roy Smith wrote: There is an anti-flight plan floating around in a parallel universe. When your wheels touch the ground the two universes come into contact and the flight plan and the anti-flight plan annihilate each other. And a photon is emitted (either that or the end of the universe occurs). Ha! And if something other than wheels touch ground, that photon is LARGER. |
Lyc. O-360 cylinder question | JB | Owning | 13 | November 27th 04 09:32 PM |
Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 03:07 PM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Question | Charles S | Home Built | 4 | April 5th 04 09:10 PM |
Partnership Question | Harry Gordon | Owning | 4 | August 16th 03 11:23 PM |
