Flight Following question
Old December 10th 06, 01:12 PM posted to rec.aviation.ifr
Jim Carter[_1_]
Default Flight Following question
-----Original Message-----
Posted At: Saturday, December 09, 2006 11:23 PM
Posted To: rec.aviation.ifr
Conversation: Flight Following question
Subject: Flight Following question
He did not say to file a VFR flight plan, he said an ATC flight plan
for
VFR
flight following - you check the IFR box, put VFR or VFR/altitude in
altitude box.
-Milen
Do you have any quick references for that Milen? I've never heard of an
IFR flight plan with "VFR" in the enroute altitude box. Or are you
referring to filing VFR-on-top? If so, that's a lot different than just
requesting flight following for VFR flights.
Old December 10th 06, 02:50 PM posted to rec.aviation.ifr
A Lieberma
"Jim Carter" wrote in news:000601c71c5c$d669dee0$4b01a8c0@omnibook6100:
Hey Jim,
Did a little research myself and found the following
http://72.14.209.104/search?q=cache:...&ct=clnk&cd=13
See 1155 A. Flight planning.
Sounds to me that what he is doing is fudging the system by filing an IFR flight plan
and annotating it with VFR references in the remarks.
I know when you select the IFR box, it does generate a flight strip to ATC, and that
would be an IFR filing naturally.
Selecting VFR does not generate a flight strip to ATC, nor is a filing with ATC to obtain an
ATC clearance.
To my knowledge, you don't get clearances on VFR operations EXCEPT for class B entry, take offs and landings.
Canada on the other hand does use ATC flight plan for VFR operations. See
http://72.14.209.104/search?q=cache:... ct=clnk&cd=1
Allen
Old December 10th 06, 04:05 PM posted to rec.aviation.ifr
Newps
No, he puts "VFR" into the altitude box, not in the remarks.
Putting VFR in the altitude box does generate a strip to ATC, 30 minutes
prior to the P time.
Old December 10th 06, 04:23 PM posted to rec.aviation.ifr
A Lieberma
Newps wrote in
minutes prior to the P time.
But he is SELECTING in box 1.type IFR. I was always told that if you
select VFR in box 1, no strip is generated to ATC, thus an IFR filing.
Altutude is box 7 on the FAA flight plan.
Allen
Old December 10th 06, 05:42 PM posted to rec.aviation.ifr
Newps
A Lieberma wrote:
Newps wrote in
Irrelavant for ATC. The altitude box takes precedence.
That's true. It's a routing question. We are a regional cargo hub for
UPS and DHL. We have lots of small aircraft running cargo. Twin
Cessnas, Barons, Beech 99's and 1900's, Metroliners, etc. They all have
prefiled IFR flight plans that spit out the same time every day. They
always go VFR when they can, which is about 90% of the time. For those
who's ops specs require flight following we simply change the altitude
on their IFR strip to a VFR one. Change 120 to VFR/125. The altitude
box holds 7 characters. When he tags up on the radar there is now a V
on the tag indicating he is VFR.
Same as on the FAA computer controllers use.
Old December 10th 06, 02:59 PM posted to rec.aviation.ifr
Stan Prevost
As Milen says, check IFR (it is not an IFR flight plan, that is just a
routing flag for ATC vs FSS), put VFR or VFR/120 for 12,000 feet or whatever
your filed altitude is. I also add VFR Flight Following in Remarks to
clarify my intent for some controllers who are not very familiar with the
practice. I recommend only doing this through DUAT/S, as most FSS personnel
are unfamiliar with it.
Stan
"Jim Carter" wrote in message
news:000601c71c5c$d669dee0$4b01a8c0@omnibook6100.. .
for
VFR
altitude box.
-Milen
Old December 10th 06, 03:08 PM posted to rec.aviation.ifr
A Lieberma
"Stan Prevost" wrote in
Call it what you want, but the form on top says FAA Flight plan.
1.Type is either VFR or IFR.
If you select IFR, you are filing a IFR flight plan. No grey zone about
it, all you are doing is fudging the system to get a plan routed to ATC.
VFR flight plans are not routed to ATC period.
Allen
Old December 10th 06, 04:12 PM posted to rec.aviation.ifr
Newps
You're wrong. Do it as he says and I get a strip printed for me. That
is the exact procedure I use when I enter a flight plan into the system
for a pilot. There's no IFR/VFR box to check so the altitude
information is the only way the computer knows if you are IFR or getting
VFR flight following.
Old December 10th 06, 04:31 PM posted to rec.aviation.ifr
A Lieberma
Newps wrote in
That is the exact procedure I use when I enter a flight plan into the
system for a pilot. There's no IFR/VFR box to check so the altitude
getting VFR flight following.
Please see the FAA flight plan form the pilot completes. See box 1. type.
It's either VFR ir IFR.
If I check IFR on 1.type of the FAA flight plan, I get a center control
number that is filed into the ATC system via DUATS.
I DO NOT get a center control number when I FILE VFR. I get a remark the
plan is forwarded to the servicing FSS.
Maybe FSS forwards something to you when I file through FSS, but when I
file via DUATS, it's a very distinct difference on the electronic response.
There may not be any IFR / VFR box on your end, but there sure is on the
pilot's end filing the plan.
I also notice that the website Flight Aware NEVER picks up my VFR flight
plan filings, where as when I file IFR, it shows scheduled one hour before,
so I know there is some meat to my theory in that VFR selection on the FAA
flight plan does not get passed on to the ATC system.
Allen
Old December 10th 06, 05:50 PM posted to rec.aviation.ifr
Newps
A Lieberma wrote:
Newps wrote in
Irrelavant what you receive. Checking IFR doesn't make you IFR.
"Cleared to...." makes you IFR.
Right.
FSS doesn't forward VFR flightplans.
I understand that. It's a routing issue. Perhaps DUAT doesn't allow
you to file VFR/125 as your altitude on your IFR flightplan. That is a
limitation written into the computer program, not anything from FAA.
If you can file a plan as I stated above and see if it shows up in the
proposed list.
IFR use of handheld GPS [email protected] Instrument Flight Rules 251 May 19th 06 02:04 PM
ramifications of new TSA rules on all non-US and US citizen pilots paul k. sanchez Piloting 19 September 27th 04 11:49 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
