Photos from Winter
Old December 11th 06, 02:13 AM posted to rec.aviation.soaring
Eric Greenwell
Default altimeter errors
HL Falbaum wrote:
The guy at 18,500 is a) IFR, b) alt set on 29.92, c) his ALT should have had
a static check for IFR, d) in contact with ATC, squawking ALT on his mode C
transponder. e) moving fast and bigger than you!
If you are there ---you should have a TPAS or TCAS or a transponder.
And I believe ATC won't allow him to fly at FL185 if that is only 500
feet above 18,000 msl. Isn't the minimum clearance to 18,000'msl at
least 1000 feet?
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
Old December 11th 06, 02:49 AM posted to rec.aviation.soaring
HL Falbaum
news:H93fh.3320$Z67.2248@trndny02...
had a static check for IFR, d) in contact with ATC, squawking ALT on his
mode C transponder. e) moving fast and bigger than you!
And I believe ATC won't allow him to fly at FL185 if that is only 500 feet
above 18,000 msl. Isn't the minimum clearance to 18,000'msl at least 1000
feet?
I think youy are right, but it depends on the sea level barometric
pressure---might be more than 1000'. But that was the altitude proposed in
the discussion.
Just to add to the discussion---some years ago, while prospecting for the
diamond at Minden, I flew several ships--6 wave flights in five
days---finally got it right! One of the ships had a 57mm Winter ALT. On the
face was the inscription "20,000 ft". The hands stopped at 24,000 ! The
vario still showed "up" so I continued. The Replogle eventually recorded
27,000 ft. The hands started moving again on the way down, after a while. I
guess the movement runs out of excursion.
Hartley Falbaum
DG800B "KF" USA
soaring photos on-line [email protected] Soaring 2 November 15th 05 02:15 AM
====---- Willow Grove NAS Airshow Photos 2005 ---==== SITE BACK UP TopGunHank Naval Aviation 0 June 4th 05 12:12 AM
~ PHOTOS FROM THE FALLUJAH MASSACRE [won't find *these* photos on TekTeam26 Military Aviation 0 April 12th 04 01:49 AM
MT. DIABLO HIGH SCHOOL CONCORD, CA PHOTOS MT. DIABLO HIGH SCHOOL PHOTOS Home Built 1 October 13th 03 03:35 AM
FS: Aviation History Books Neil Cournoyer Military Aviation 0 August 26th 03 08:32 PM
