![]() -----Original Message----- From: Newps ] Posted At: Sunday, December 10, 2006 9:59 AM Posted To: rec.aviation.ifr Conversation: Flight Following question Subject: Flight Following question .... What he meant was to file an IFR flight plan except to put VFR as the altitude. That would generate a strip just like an IFR aircraft but when you put that transponder code in the data block on the radar scope shows you as a VFR aircraft. That's pretty cool. So if I understand correctly now, I can file an IFR flight plan, but specify the enroute altitude as VFR/065 (6500') and that will generate a strip. Can I then call CD and pick up an IFR clearance to VFR enroute with flight following? Since I'm still an analog guy in a digital world and like to talk to the FSS guys on the phone (makes 'em feel needed don't ya know), I've been filing with them. Do you think they will understand how to take this type of flight plan? |
![]() Jim Carter wrote: That's pretty cool. So if I understand correctly now, I can file an IFR flight plan, but specify the enroute altitude as VFR/065 (6500') and that will generate a strip. Can I then call CD and pick up an IFR clearance to VFR enroute with flight following? Just file a regular IFR and pick it up how you normally do. When you get to the point you want to be VFR tell the controller you want to cancel and receive FF. |
![]() -----Original Message----- From: Newps ] Posted At: Sunday, December 10, 2006 6:37 PM Posted To: rec.aviation.ifr Conversation: Flight Following question Subject: Flight Following question .... Just file a regular IFR and pick it up how you normally do. When you get to the point you want to be VFR tell the controller you want to cancel and receive FF. Duh!! That makes perfect sense; I don't know why I was following the VFR altitude for IFR plan thread. Of course that prompts another question: if its that easy to get FF then why bother with the IFR / VFR finagle to start with? Why not just do as you suggest and file IFR with the intention of cancelling over to FF after departure? It can't be that we've got non-instrument rated pilots filing IFR plans can it? |
![]() Jim Carter wrote: Of course that prompts another question: if its that easy to get FF then why bother with the IFR / VFR finagle to start with? Why not just do as you suggest and file IFR with the intention of cancelling over to FF after departure? You have to be an instrument pilot to start out IFR. It can't be that we've got non-instrument rated pilots filing IFR plans can it? It's OK to file, not OK to accept an IFR flight plan. |
On 12/10/06 18:45, Jim Carter wrote:
-----Original Message----- From: Newps ] Posted At: Sunday, December 10, 2006 6:37 PM Posted To: rec.aviation.ifr Conversation: Flight Following question Subject: Flight Following question ... Just file a regular IFR and pick it up how you normally do. When you get to the point you want to be VFR tell the controller you want to cancel and receive FF. Duh!! That makes perfect sense; I don't know why I was following the VFR altitude for IFR plan thread. Of course that prompts another question: if its that easy to get FF then why bother with the IFR / VFR finagle to start with? Why not just do as you suggest and file IFR with the intention of cancelling over to FF after departure? It can't be that we've got non-instrument rated pilots filing IFR plans can it? Consider also that departing IFR may mean delays and departure routes contrary to what you may be able to get if you depart VFR. -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
![]() -----Original Message----- From: Mark Hansen ] Posted At: Monday, December 11, 2006 9:22 AM Posted To: rec.aviation.ifr Conversation: Flight Following question Subject: Flight Following question .... Consider also that departing IFR may mean delays and departure routes contrary to what you may be able to get if you depart VFR. -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA Very true Mark. In the case of KLIT however, the IFR departures seem to get the routes they want and the VFR departures all get R or L turn to 270, maintain 2000' or lower until further advised. Seeing you're from SAC I suspect things are quite a bit different on that side of the hill. |
On 12/11/06 17:20, Jim Carter wrote:
-----Original Message----- From: Mark Hansen ] Posted At: Monday, December 11, 2006 9:22 AM Posted To: rec.aviation.ifr Conversation: Flight Following question Subject: Flight Following question ... Consider also that departing IFR may mean delays and departure routes contrary to what you may be able to get if you depart VFR. Very true Mark. In the case of KLIT however, the IFR departures seem to get the routes they want and the VFR departures all get R or L turn to 270, maintain 2000' or lower until further advised. Seeing you're from SAC I suspect things are quite a bit different on that side of the hill. I dunno, really ;-) My only IFR departures so far have been training or local practice flights, most of which head straight for the local VOR station before going on course anyway. However, I was speaking in generalities. I'm sure there are some airports where this won't be an issue, but I thought it was worth consideration while planning what type of departure is appropriate for the flight. Best, -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
![]() "Newps" wrote in message . .. Jim Carter wrote: That's pretty cool. So if I understand correctly now, I can file an IFR flight plan, but specify the enroute altitude as VFR/065 (6500') and that will generate a strip. Can I then call CD and pick up an IFR clearance to VFR enroute with flight following? Just file a regular IFR and pick it up how you normally do. When you get to the point you want to be VFR tell the controller you want to cancel and receive FF. When I make my initial call to the departure facility, they usually just ask me to confirm that I want VFR flight following, and then just say something like "maintain VFR at all times, proceed on course, climb to requested VFR altitude". They have all the other information already. At most, I have to tell them that I want VFR flight following to destination, and that there should be a proposal strip on me. Never any IFR clearance involved. |
![]() Stan Prevost wrote: When I make my initial call to the departure facility, they usually just ask me to confirm that I want VFR flight following, and then just say something like "maintain VFR at all times, proceed on course, climb to requested VFR altitude". That's a little overboard. A simple "maintain VFR" is all that's needed. |
IFR use of handheld GPS | [email protected] | Instrument Flight Rules | 251 | May 19th 06 02:04 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
ramifications of new TSA rules on all non-US and US citizen pilots | paul k. sanchez | Piloting | 19 | September 27th 04 11:49 PM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
